30th Sep 2020, 3:14 pm | #421 |
Re: BBC TV: The Repair Shop
Just the cabinet as far as I could see. One of the worst electrical "repairs" so far - and these have generally been much less satisfactory than the other restorations anyway.
30th Sep 2020, 3:49 pm | #422 |
Generally they try to retain as much originality as possible so it is odd that they whipped out the radio. I suppose that someone soldering new components or testing voltages is not as televisual as someone carving a new section of a piece of furniture or restoring a painting so maybe it wasn't considered appropriate to repair the radio.
Paul |
30th Sep 2020, 3:56 pm | #423 | |
Mark Stuckey always seems to do an excellent job. |
30th Sep 2020, 4:22 pm | #424 |
Trouble is - TV watching "Jo Public" ( or to keep things pc - Joanna Public) sees these mammery appendages fannying about with old radios - and gets stuck with the impression that all the vintage radio fraternity behaves the same. I.e. we get tarred with the same brush !
The whole "Repair Shop" set-up is as truely factual as "Gold Divers". I spent a number of years as a commercial diver, and reckon both "Shows" are a load of twonk, reality-wise. Regards, David Last edited by David Simpson; 30th Sep 2020 at 4:48 pm. Reason: spelling |
30th Sep 2020, 4:29 pm | #425 |
In these things, I always tend to think "what did the thing's owner say he/she wanted it to do after the repair?" - in which case 'taking the guts out and replacing them with something more modern' could be a totally-rational path to follow if the requirement was to reliably play music streamed from something-21st-century while not risking burning the house down if you forget to switch it off when you go out for the day.
30th Sep 2020, 4:30 pm | #426 | |
30th Sep 2020, 4:49 pm | #427 |
These were from the donor. The original had one missing and one damaged.
That is precisely why I put "repair" in inverted commas - because it was merely claimed as a repair.
30th Sep 2020, 4:56 pm | #428 |
What an awful thing to do! They just scrapped a (presumably) working radiogram and built the parts into the owners case! Why not repair the original chassis ? As others have said I can understand why the deck needed to be changed and the damaged speaker if it was unrepairable but to change the radio chassis for one that wasn't even the same model...
What they have ended up with is a complete bodge and have destroyed the original "donor" in the progress... At least they used the same make to use for parts so maybe the speakers and deck are possibly the correct type.. I once went a long way to buy a vintage TV set which had been restored by its owner, when I got there I found the "restoration" consisted of a different chassis from another set had been fitted,different make, wrong tube. I asked if the chap had the original parts as I would have put it back to original but he told me that he had "chucked them" as they were no good... He still had the cabinet from the donor set though! Which had been a nice vintage set in it's own right! I wonder what the repair shop did with the original chassis ? Did the owner notice the refurbishment now meant that the set had slider controls? Oh and sounded dreadful..? They may as well have just ripped the guts out and made it into a box to house a Crossley crap-o-gram. I do doubt how expert some of these people are the restored cylinder player sounded terrible, they couldn't fix that jukebox, The GEC radiogram was a bit of a shambles.. I do like the "bear ladies" though. |
30th Sep 2020, 4:57 pm | #429 |
At one end of the professional spectrum they choose highly experienced folk like tho horologist & his sister. Also the art restorer & the two fabric wifies. At the other end is the presenter who ponces about in his pristine leather apron, then the "radio mannies". Why oh why didn't the producers approach the BVWS commitee & ask them to recommend someone ?
Regards, David |
30th Sep 2020, 5:17 pm | #430 |
They might have been picked for presentational reasons, or maybe a friend of the producer's second cousin.
Imagine if they's had Gerry Wells. David
30th Sep 2020, 5:26 pm | #431 |
Did I imagine this? To remove the deck he appeared to screw the deck transit screws out, until the end clips broke. There was someone admitting to doing this a month or two ago on this forum. Also was "new" deck held in with a Pozidrive screw through deck?, I could not be sure on this one. I generally enjoy the program but was cringing with this item.
John.
My favourite text message "I'll be there in five minutes, if not read again" |
30th Sep 2020, 6:18 pm | #432 |
I gave up part way through. It was seeing the Grundig on screen made me start watching as I can't stand this put on show normally. Some people seem to be craftsmen though, some outright bodgers. Just have to remember it is for entertaining the masses and not really for knowledgeable enthusiasts. Accuracy and true craftsmanship is in the minority. It is not restoration like a lot of forum members on here would recognise.
Typical BBC entertainment output these days at minimal cost. Rob
Apprehension creeping like a tube train up your spine - Cymbaline. Film More soundtrack - Pink Floyd Last edited by CambridgeWorks; 30th Sep 2020 at 6:20 pm. Reason: extra info |
30th Sep 2020, 6:29 pm | #433 |
Well, actually he did. At the owner's request he replaced a Smith's mains electric movement with a battery quartz one. He didn't seem too happy about it though. Arguably not as bad as replacing a fully mechanical movement I suppose.
Paul |
30th Sep 2020, 6:38 pm | #434 |
The Repair shop is one of my favorite programs on TV.
Probably my Favorite, full stop. At least at the moment. The skills of Steve and Suzie Fletcher, Brenton West and William Kirk especially, are a Joy to behold as they say. These are really very talented people. I can't help but notice though, on the latest series, they seem to spend less time on the actual craftmanship. Almost rushing through the restorations, which I'm sure didn't happen in the previous series! I have had the pleasure, to actually meet Amanda Middleditch and Julie Tatchell personally. These are two fantastic Ladies. Very down to Earth, very friendly and very happy to talk about the subject. Ian |
30th Sep 2020, 6:48 pm | #435 |
Gerry was a one off, an enigma. He was capable of the most serious of restorations but was not above 'fixing' a set by correcting an incorrect voltage on a valve by hooking it up to HT via a suitable resistor. I've seen him do it. But yes, he would have been the ideal Repair Shop man to fix radios and the like; affable, knowledgeable, talkative, photogenic, sense of humour..
30th Sep 2020, 6:55 pm | #436 |
I forgot to say, that the Radiogram was not their finest moment!
Lets get another Radiogram in fairly good shape, and rip everything out to repair another. Very disapointing, but at least the owner was happy, which I guess has to be remembered. Ian |
30th Sep 2020, 7:01 pm | #437 | |
It's entertainment, not educational as such. I love it, much better than the usual reality drivel that we're force fed.
30th Sep 2020, 7:03 pm | #438 | |
But was she? she looked rather underwhelmed to me, probably with the awful sound it made. Peter |
30th Sep 2020, 7:39 pm | #439 |
I have to agree with Steve. The standard of craftsmanship is usually very high with a lot of work done behind the scenes. I enjoy the programme to see professional restorers doing a very good job. It would be very nice just to send something off to be soda blasted, re-chromed or a bespoke piece of glass cut without thinking about the cost though.
Paul |
30th Sep 2020, 7:56 pm | #440 |
I haven't seen many episodes, just a few. I hardly watch TV but I like seeing the restorations. It is TV land though. Most of those restorations would cost a small fortune in the real world. They emphasis is on the history and the story behind the object. Quite right too. Nice to see the skills that the restorers have.
