6th Aug 2022, 10:16 pm | #1 |
Mysterious capacitors.
Hi, the capacitors in the pics are mounted on the tone boards of an old electric organ, brand Farfisa. 1uF-40V.
They look like ordinary electrolytic capacitors but they are mounted on a yellow plastic cup....?...and they look to me a bit different from a common electrolitic. ...and they are mounted with the positive down on the pcb and the negative up...?... I suspect they are wet tantalum capacitors. What do you think about them? Is it possible to detect a capacitor with these info? Thank you in advance. Federica |
6th Aug 2022, 10:25 pm | #2 |
Re: Mysterious capacitors.
I think they are standard electrolytics. The yellow insulation cup is to give them some support on the PCB, if that wasnt there they would vibrate and eventually fall off the PCB. I would replace them with PCB mount low leakage caps of 1uF and 63 volts working.
Joe |
6th Aug 2022, 10:28 pm | #3 |
I've not seen wet tants that look like that. Is there any DC bias voltage? If so, then Al would be fine.
By the look of that resistor, somebody has been really expressing themselves... David
6th Aug 2022, 10:37 pm | #4 |
I think thats a germanium diode David. It made me look twice too!!.
Joe |
6th Aug 2022, 10:41 pm | #5 |
Yes they are standard aluminium types probably Philips. Just fit ordinary types. As Joe said, the yellow cap is to provide support. Lots of Philips circuits like that in the 70's.
7th Aug 2022, 7:52 am | #6 |
Wet tantalums are heavy, you can feel the difference in weight same as between steel and aliminium.
Andy.
7th Aug 2022, 9:01 am | #7 |
Yes, the capacitors are Philips.
Standard aluminium electrolytic ones. Jac |
7th Aug 2022, 12:58 pm | #8 |
They're standard aluminium electrolytics by Philips. They can be replaced by standard radial types.
Edit: What Jac says. |
7th Aug 2022, 1:15 pm | #9 |
Another vote from me. As said, those plastic mounts were quite widely used in the 60s and 70s.
7th Aug 2022, 1:38 pm | #10 |
I have restored 2 Farfisa organs, replacing these caps, and can also confirm that they are standard electrolytic types.
Martin BVWS member GQRP Club |
7th Aug 2022, 6:48 pm | #11 |
Thank you very much for the support and the expert answers....but there are some questions still open...I'll try to cut one of these capacitors and I'll show the result...it is strange the yellow little plastic cup...there is a lot of space and this organ is like a wardrobe....I saw sometimes these wet tantalum caps come with a strong plastic casing...?....for protection? a failure can be explosive?.....the voltage in this circuit is around 5 and 9 Volts DC so I think too low to make a cap vibrate....the Philips caps from 60's often are blue...I try to investigate more....I'll let you know....and thank you a lot.
7th Aug 2022, 6:51 pm | #12 |
Thank you...the plastic mounts were widely used? great!
7th Aug 2022, 8:11 pm | #13 |
As promised this is the inside of the capacitor and the last pic is about a common electrolytic cap...to cut the casing I wore gloves, a mask and glasses for protection....just forgot the earplugs....!....that's just for curiosity but I don't know if it says something interesting or relevant...after all I don't know nothing about the capacitors construction.
7th Aug 2022, 9:02 pm | #14 |
Axial wet tants are very heavy compared with ordinary aluminium capacitors, as has already been mentioned. Wet tants are also very expensive, due to the casing being made from tantalum or silver, these are the only materials that resist corrosion from the acid based electrolyte used, do not cut open wet tants.
Example of a failed wet tant from a Tek oscilloscope below, note the corrosion. However those are just cheap ordinary aluminium electrolytic capacitors from Philips, here are a whole bunch of them in a Philips car radio. David |
8th Aug 2022, 7:00 am | #15 |
Thank you David and thank to you all, guys....it was important for me because it is 30 years we plays this old Ballata Farfisa but recently the notes are going a bit down of tune....yes, there is a screw for adjusting the tones back in tune but it is a sign that after 50 years the electrolytic caps are failing and need to be replaced with the right ones.
I'm definitively convinced that Mr. Philips's wife was trying to sell out little yellow plastic caps unsuccessfully....that's the only explanation why they are there... |
8th Aug 2022, 7:31 am | #16 |
The vibration problem occurs from the speaker!! It is an organ after all. You don't mention if it has built in power amplifier, but many organs of this age did have built in speakers and power amplifiers.
Joe |
8th Aug 2022, 12:13 pm | #17 |
I am pretty sure that Phillips made axial mount capacitors with a longer negative lead and added the plastic caps for the remaining life of the tooling to make them.
After that they will have followed Japan and started making radial ones. I have seen those yellow mounts in TVs in the past. You might have to crank the leads a little bit in one or two crowded positions with modern radial parts. |
9th Aug 2022, 12:52 pm | #18 |
I agree, only producing axial caps (that would not mount easily and remain stable) was the main reason at the time for adding caps (pun intended).
9th Aug 2022, 12:57 pm | #19 |
I've seen those yellow caps in a Philips transistor radio (which paradoxically was assembled by Plessey).
