24th Mar 2024, 1:37 pm | #21 |
Re: Resettable fuse equivalent to 500 mA glass fuse ?
Normal fuses and PTC devices operate quite slowly, fast enough to prevent a fire, but probably not fast enough to protect semiconductor devices.
The Energiser Ultimate Lithium (Lithium Iron not Lithium Ion) 1.5V AA cells include a protective PTC in each cell to protect against the cell, or presumably several cells in series, being shorted out and causing a fire. Around £7~8 for 4 from most supermarkets. Expensive way to buy the PTC, but no postage charges! Stuart |
24th Mar 2024, 2:37 pm | #22 |
If you do happen to have a picture of a dismantled lithium iron battery with its fuse, can you please share it. It would be interesting to know what rating of PTC fuse they have used.
24th Mar 2024, 2:56 pm | #23 | |
Much as I suspected ... a thermister 'of sorts'. I've now fixed the unit with a replacement cannibalized part - but it seems a pity to abandon/scrap a good TX with all three secondary rails intact and a blown 'fuse' on the primary eh? (I may yet cut it open ....).
Red to red, black to black. Throw the switch and stand well back! |
24th Mar 2024, 3:10 pm | #24 |
Congratulations on your successful repair. Do keep us posted if you are able to locate the 'fuse' in your scrapped transformer. I have a whole bunch of scrapped transformers myself and just cannot throw them away ( :
24th Mar 2024, 10:49 pm | #25 |
No, I haven’t disassembled one of those Lithium AA cells. From the data sheet, I think they trip at around 2A, low enough to prevent a fire, but way above your 500mA fuse. Energiser talk about 3A pulse loads and say it’s affected by temperature, proximity to other cells, etc.
It is just there as a safety cutout to protect the battery, a bit like the consumer unit for household mains. Protecting the load would be something else, and probably dependant on the individual projects you intend to use the battery to power. Stuart |
25th Mar 2024, 12:24 am | #26 | |
No worries. Thanks for delving into this. I might be able to obtain some polyfuses that have a hold current of 170 mA and trip at 340 mA. I can also source ones that trip at 200 mA, but I guess they are probably not suited for the current requirements of my circuit. Last edited by Jolly 7; 25th Mar 2024 at 12:25 am. Reason: Typos |
