Old 4th Jul 2020, 8:15 pm   #1
Raptornet
Default Model 3V38 - Looking for advice
I’ve been offered a Ferguson Videostar, in reasonably good nick, apart from the fact it plays for a few seconds and then stops.
Before I agreed to anything, I wanted to know if this was a common fault, brought on by tired belts. I’ve never worked on a VCR before, but I’m no stranger to taking stuff apart. Sometimes when I put them back together, I even find I don’t have any screws left over
Just looking for advice.
Raptornet is offline
Old 5th Jul 2020, 8:20 pm   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: Model 3V38 - Looking for advice
I've never had one, but worked on JVC-based models from that era (early half of the 1980s).
I think your supposition may be correct, or that the rotation of the take-up spool isn't being sensed correctly.
I suspect a full service and replacement belts/idlers would restore it to good health, but I must reiterate that I'm not an expert, just a keen dabbler.
Nickthedentist is online now
Old 5th Jul 2020, 8:30 pm   #3
martin.m
martin.m's Avatar
It could be something simple like the take up spool not rotating in play mode. Try and have a look with the top removed.
Regards
Martin
martin.m is offline
Old 6th Jul 2020, 9:25 am   #4
Welsh Anorak
Welsh Anorak's Avatar
As Martin suggests. it's more likely to be the idler than belts if it does actually play and show a picture for a few seconds. Then it's staightforward fault finding - put it in pause and see if it stops. If not it'll be the take-up not working or its sensor. If it stops before it starts, if you see what I mean, then the loading belt is to blame. I'd get the machine as it shouldn't be too difficult to get going again.
Glyn
www.gdelectronics.wales
Welsh Anorak is offline
