Old 9th May 2020, 8:37 pm   #1
IKC2E51R8
Default Help With Vertical Circuit. Capacitor getting extremely hot
Hi Everyone,
turning to the experts for help as im stumped....
Im working on my little Dansai Portable TV I had some vertical on it but it was squashed, After turning it on and off a couple times while testing i now have a new fault that has me stumpted,
When its taken out of standby all i get is a Loud continuous screeching noise (coming from either the LOPTX or the Line Drive Transformer) after a few seconds these three capacitors C425, C424 & C420 Get Very Hot C420 is getting much hotter than the others, too hot to touch without getting burned. I've no idea whats causing this , I removed the vertical connection wires from CN401 and the set came on with Horizontal deflection working, reconnecting the wires brings the fault on again namely wire 4 it runs (soemtimes) with wire 3 connected and sometimes it doesnt.
Can you guys please help me or point me in the right direction.
Ive attached a picture of the vertical circuit taken from the manual. Red is the capactior thats getting the hottest, the other are in orange
Its using the ART-TECH GT9313 Chassis if thats any help to anyone
Cheers,
Luke
IKC2E51R8 is offline
Old 9th May 2020, 8:50 pm   #2
Heatercathodeshort
Heatercathodeshort's Avatar
Default Re: Help With Vertical Circuit. Capacitor getting extremly hot
Two possibles. The loud screech is the power supply overload due to a short on the 26v line. It looks as if it is derived from the lopt.
Probably due to a S/C frame output I/C or the supply diode/diodes in the 26V line.
Just a thought on first checks. John.
Heatercathodeshort is offline
Old 9th May 2020, 8:57 pm   #3
IKC2E51R8
Thanks John, the Supply Diode is D405, I'll change it and see what happens, Its a BYD33D so ive a few handy.
Cheers,
Luke
Old 10th May 2020, 9:05 am   #4
Welsh Anorak
Welsh Anorak's Avatar
I'd agree with John. it's odd that capacitors are overheating, and usually is due to excess voltage or ripple they can't cope with. So I'd change the diode, the three capacitors plus C434 and the IC.
Glyn
www.gdelectronics.wales
Welsh Anorak is offline
Old 10th May 2020, 4:05 pm   #5
IKC2E51R8
Ive changed the Diode and the screeching has stopped and the Capacitors are no longer overheating, i changed C420, i have a tiny tiny amount of vertical deflection if it runs for about 30 seconds, In the service manual C434 is listed as a 220uf 40v but fitted on the board is a 470uf 35v?
I'll have to check what i have and hopefully have the right size caps to replace them . The IC i think might be ok but ive a couple ordered anyway and will replace it just to remove all doubt about it, they should hopefully arrive tomorrow.
Cheers,
Luke
Old 11th May 2020, 9:04 am   #6
Welsh Anorak
Go with the 470/35v which should be ample on a 24v rail. I'd replace the others as well as they've been overheating and probably will be useless by now. These, together with a new IC should get things going again.
Glyn
Old 11th May 2020, 9:30 am   #7
Sideband
Sideband's Avatar
Default Re: Help With Vertical Circuit. Capacitor getting extremely hot
I would also change D407 to be on the safe side. You can probably use a 1N4148 if you dont have a BAX12
Sideband is offline
Old 11th May 2020, 8:11 pm   #8
IKC2E51R8
I changed those Capacitors and tried it, the first two times power was applied it made that screech again but on the third time it didnt and came on (still no vertical) so im going to change the D407 (I'll have to use a 1N4148 ive no BAX12) and the IC which i ordered two of two weeks ago should hopefully arrive tomorrow
Odd that it made that noise again but only twice and then powered up, could there be something else going on that im missing?
Cheers,
Luke
Old 12th May 2020, 9:58 am   #9
Welsh Anorak
Change the IC first then worry!
Glyn
Old 19th May 2020, 3:53 pm   #10
IKC2E51R8
Hi
Replaced the IC today and same result, i have vertical but its squashed at the top with the OSD Shruken, its still tempermentle with that noise, sometimes it starts fine others it just does the screech and that capacitor gets hot again
Cheers,
Luke
Old 19th May 2020, 3:58 pm   #11
Heatercathodeshort
Use the correct rectifier supply diode. It needs to be a fast switching type due to line frequency and of the correct spec for current and voltage. J.
Old 19th May 2020, 4:01 pm   #12
IKC2E51R8
The BAX12A that i fitted is the same as the original and the diode on the supply line was a BYD33D and ive fitted the same. Ive also replaced every capacitor in the vertical circuit and this is the result...
Cheers,
Luke
Old 20th May 2020, 7:31 pm   #13
Heatercathodeshort
The only other test would be to run the fop stage from an external variable power supply and see how it performs. J.
Old 21st May 2020, 5:15 pm   #14
Welsh Anorak
What's the voltage on the +26v line at the IC?
Glyn
Old 4th Aug 2020, 11:06 pm   #15
IKC2E51R8
Hi All
still working on this tv, i ended up changing C418 (100n) and the screeching didnt come back but still hadnt got full vertical, I noticed R419 looked a bit worse for wear even though it measured good so i changed it today. screeching is back and wont stop and that same capacitor reaching boiling point after 3-4 seconds, cant leave it powered on long enough to read the voltgage on the +26v line cause that cap will go boom, ive wasted 5 of those caps trying to get this sorted (will have to order a bunch more) im honestly lost at this point, ive changed the Vertical IC, both diodes, Every capacitor, its only the resistors i havnt changed and that screeching still wont stop.
can anyone offer any more help with this, short of literally changing every component in the circuit AGAIN im lost
Cheers,
Luke
Old 5th Aug 2020, 1:36 am   #16
Refugee
Refugee's Avatar
Is the scan coil glued together with that brown glue?
Refugee is online now
Old 5th Aug 2020, 2:48 pm   #17
IKC2E51R8
Surprisingly its not
Cheers,
Luke
Old 11th Aug 2020, 6:38 pm   #18
Heatercathodeshort
A few seconds and it's boiling hot. Most odd. What is the voltage across it? J.
Old 11th Aug 2020, 11:59 pm   #19
IKC2E51R8
I haven't even left it on long enough to get my meter probe on it because the capacitor bulges within seconds, never let it get to the point it blows I will have to try though.
The cap that's in it now is bunched so I've ordered some new 2200u @35v, 10v higher than what's there at the moment and I'll see how they do, I've also ordered some new BYD33D for the supply diode (last time replacing this cured the blowing cap and screaming PSU albeit not for long)
the Diodes arrived today just waiting on the new caps before i try them out, hopefully it returns to at least just the squashed vertical so i can do some proper voltage measurements
Cheers,
Luke
Old 12th Aug 2020, 12:09 am   #20
IKC2E51R8
Probably wont be much help but heres a very short video of the sound, had i left it on 5-10 more seconds the BYD33D would be cooked and the Cap would probably go Boom not long after.
https://youtu.be/_JbRleW0AHo
Cheers,
Luke
