20th May 2021, 2:22 pm | #1 |
Vintage Electrolux Microwave.
Afternoon
Many years ago, I bought a first generation (650W) microwave oven. Its an Electrolux (made in USA) model 56-0 884-10 - strange model number, I know. It has a very large cooking cavity, a 1KW browning element and a plug in temperature probe. It's still in regular use. The other day the internal lamp which illuminates the cavity went o/c (40W MES) and having sourced a replacement, I was obliged to remove the cabinet in order to replace it. On doing so, I discovered that the belt that drives the stirrer fan in the "roof" had disintegrated (it does not have a rotating turntable.) This is, of course, an appliance specific part (unlike the bulb) and sourcing a substitute is proving a problem. Googling the model number produces no hits whatsoever, even an image search produces nothing even similar. So, I'm a bit screwed (!) It's brown with a wood effect metal case and has a touch keypad and a green display. Anyone ever heard of this model?
Thermionic Emission, warms the cockles of your tubes. |
20th May 2021, 2:29 pm | #2 |
Re: Vintage Electrolux Microwave.
What form of belt is it? Generic belts are available on eBay or you can make your own using 'O' Ring cord.
20th May 2021, 7:59 pm | #3 |
Yes - that green round-section belting which you join with a hot knife, is really good stuff and the joint is very strong indeed. I have bought several lengths of different cross section from ebay - but only useful if you can use a round-section belt.
"The best dBs, come in 3s" - Woody Brown |
20th May 2021, 9:49 pm | #4 |
Another vote for hot melt polyurethane cord. I bought a range of diameters some years ago from RS and it has been very useful, not only for drive belts, but for O ring seals. The RS stuff was available in both smooth and rough, and in red and green. I found the barrel of my Henley Solon ideal for melting it.
24th May 2021, 9:50 am | #5 |
Thanks for the suggestions. Any idea where one might obtain a modest quantity of said hot melt polyurethane cord? All I've come up with thus far is a Chinese based seller on Ebay offering min 2mm diam min length 1m.
Using RS would be prohibitive (can't find reference to same in any event.) All / any contributions most gratefully received
