Old 23rd Jul 2003, 9:08 pm   #1
Mat
Default Discharging HV Capacitors.
Hi.
I don't want to use a screw driver; what is the best way to discharge caps?
Mat.
Old 23rd Jul 2003, 10:48 pm   #2
Paul Stenning
Administrator
Paul Stenning's Avatar
Default Re: DISCHARGE HV CAPACITORS.
For the HT caps in radios (250-350V DC) a 25W mains light bulb with a couple of flying leads is effective. The bulb initially flashes bright and quickly extinguishes. It limits the current and gives a nice visual indication that the caps were discharged.
I don't know what you'd do up at EHT levels. You could make up a chain of high voltage resistors (standard resistors are only rated at a few hundred volts), perhaps. I thought a screwdriver was the usual method of discharging EHT, but I do accept that the current surge is not good for the capacitors.
Paul Stenning
Forum Admin/Owner and BVWS Webmaster
Paul Stenning is offline
Old 23rd Jul 2003, 11:08 pm   #3
Duke_Nukem
Duke_Nukem's Avatar
Particular care is needed with EHT voltages. Just shorting with a screwdriver can cause a high current pulse which can be picked up in other wiring ; a proper valve telly won't notice (in fact drawing an arc from EHT to see if it was working was standard practice in the good old days) but the surges would cretainly risk destroying transistors.
TTFN,
Jon
Duke_Nukem is offline
