Old 1st Aug 2011, 8:42 pm   #81
murphyv310
murphyv310's Avatar
Default Re: HMV 900 TV restoration.
Brilliant Progress David, I am sure it will be all sorted (Cabinet Wise) in two weeks.
Progress is slow here I am afraid as I am awaiting the return of the EHT transformer. The engineering shop has supplied me with a new CRT unit cover and some small brackets for the chassis, I also have as far as I can tell have a full list of what I need to complete the RF & sync sections. So once I have the EHT transformer back it will be full steam ahead.
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is online now
Old 1st Aug 2011, 11:17 pm   #82
chipp1968
chipp1968's Avatar
Cannot wait to see it all finished .It will be an amazing transformation.
chipp1968 is offline
Old 8th Aug 2011, 5:51 pm   #83
FERNSEH
FERNSEH's Avatar
Before I do anymore work on this cabinet something must be done about the right side cabinet front and the side panel joint. The first picture shows the gap between the two sections.
By using adjustable cramps the gap has been closed and now the cabinet is a much stiffer structure.
The next stage is to apply more veneers.
DFWB.
ID:	54864   Click image for larger version
ID:	54865   Click image for larger version
FERNSEH is offline
Old 8th Aug 2011, 6:32 pm   #84
Mikeymushradio
Mikeymushradio's Avatar
That is looking good, i thought it may be a problem getting it back together as waterlogged sprung apart joints often dont want to go back as they were, usully due to ingress of muck hardened glue etc but that looks brilliant well done David.
I will try and get down to see you this week.
Mike
Mikeymushradio is offline
Old 8th Aug 2011, 6:33 pm   #85
ThePillenwerfer
ThePillenwerfer's Avatar
If those sah cramps didn't get it back into shape nothing would!
Thanks for the update and education.
- Joe
ThePillenwerfer is offline
Old 12th Aug 2011, 1:31 am   #86
FERNSEH
FERNSEH's Avatar
Hi PillenWerfer,
I've used those sash cramps on many occaisions to repair and assemble TV cabinets. They certainly make tight joints.
Today, I applied new veneer on the front right side of the cabinet. I found a piece of veneer which is a good match of the other side.
DFWB.
FERNSEH is offline
Old 12th Aug 2011, 8:18 pm   #87
Ian B
Excellent progress David, I look forward to the next instalment.
Keep up the good work!
Best wishes,
Ian
Ian B is offline
Old 12th Aug 2011, 8:36 pm   #88
mark pirate
mark pirate's Avatar
Looking great, I wish I had those cabinet restoring skills, really looking forward to the end result, well done
Mark
mark pirate is offline
Old 16th Aug 2011, 7:49 am   #89
Big Band Heaven
I don't often comment on things here as my knowledge base is a basic level only and therefore prefer to just digest what is said...however I would be very interested David to see how you put your excellent skills to work on the vaneer problems that this cabinet presents. Where to obtain matching vaneer, matching up with what is there and just how you do it. If you would be prepared to share that I would be very grateful and it would be very interesting. Have to say that the transformation so far is simply amazing.
Big Band Heaven is offline
Old 19th Aug 2011, 10:52 pm   #90
FERNSEH
FERNSEH's Avatar
Work continues on the HMV cabinet. I've come to the tricky stage of the restoration, that is inserting pieces of veneer into the top front of the cabinet. There is no chance that the replacement veneers will match the original so the wood grain will have to be painted on.
The third picture shows that I have been lucky to salvage a piece of the original veneer for the front upper right panel of the cabinet. The wood grain effect can be copied for the left panel.
The dark veneer at the bottom front of the cabinet has been tidied up, new veneer pieces inserted where necessary.
DFWB.
ID:	55290   Click image for larger version
ID:	55291   Click image for larger version
FERNSEH is offline
Old 19th Aug 2011, 10:58 pm   #91
murphyv310
murphyv310's Avatar
Hi David.
You are doing great, what a transformation! You must have the patience of a saint. I certainly cannot wait till I see the finished article.
The chassis work has come on nicely with most resistors now done that were wrong, the caps have also been done in the "sync" sections.
The dampness though has caused havoc with the mica caps in the TRF sections.
Cheers,
Trevor.
Old 20th Aug 2011, 11:35 am   #92
brianc
WOW! Trevor's right about the patience of a saint. Seeing how the set is coming together is fantastic and having been put off by the state of it at the NVCF, I now wonder whether I was stupid not appreciating what could be done - hindsight is a wonderful thing! I'm looking forward to more, David.
brianc is offline
Old 20th Aug 2011, 12:33 pm   #93
FERNSEH
FERNSEH's Avatar
Hi Trevor and Brian,
I think I'm on the home straight now (to use a horse racing term). Sure there is a number of tasks to do on the cabinet but another week should see the job done.
DFWB.
FERNSEH is offline
Old 20th Aug 2011, 1:21 pm   #94
PJL
Hi David, fantastic work. I would be interested to know what you will use to paint the grain on?
PJL is offline
Old 20th Aug 2011, 1:39 pm   #95
FERNSEH
FERNSEH's Avatar
Hi PJL,
In the past I've used modelling paints to create the wood grain effect. Usual colours being brown and black. As has been mentioned before it's the background wood dye that is the difficult part.
Might have a go at the job this weekend.
DFWB.
FERNSEH is offline
Old 27th Aug 2011, 9:36 am   #96
murphyv310
murphyv310's Avatar
Hi.
I received the EHT Transformer back from Mike Barker yesterday and what a beautiful job it is, a total work of art.
I also have David Boynes here for the weekend (he came last evening) then I start my new job on Monday so progress is likely to be slow, I am off on Thursday/Friday so may get some time then although the usual things will need to be done!
I will keep in touch though.
Cheers,
Trevor.
Old 2nd Sep 2011, 11:13 pm   #97
FERNSEH
FERNSEH's Avatar
I've not been able to do much work this week. Just that Premier radio set, the job is nearly done.
However, today, I managed to do some work on the HMV 900. My attention has been centred on the front panel. A fake wood grain effect has been created for the right side of the front. I think it looks quite convincing. When I'm satisfied with the artwork it will photographed in mirror form and then I'll be able to create a similar effect for the left panel.
DFWB.
ID:	55852   Click image for larger version
FERNSEH is offline
Old 3rd Sep 2011, 10:09 am   #98
Patrick Dixon
That's very good.
Will you just use the mirrored photo as a guide to do the other side freehand, or do you have an 'easier' method?
Patrick Dixon is offline
Old 3rd Sep 2011, 1:04 pm   #99
peter_scott
peter_scott's Avatar
DFWB.
I think it looks very convincing!
Do you do art forgeries as well?
Peter
peter_scott is offline
Old 3rd Sep 2011, 2:10 pm   #100
IJK2008
IJK2008's Avatar
Fantastic art work.
Ian
IJK2008 is offline
