Old 30th Apr 2010, 2:45 pm   #21
oldticktock
Default Re: Pye v4
Upon removing everything from the case , giving me easy access I have found a date stamp it reads " 2nd September 1953"
oldticktock is offline
Old 30th Apr 2010, 4:43 pm   #22
oldticktock
Default Re: Pye v4
New CRT fitted, scan coils fitted and ION trap aligned. Later after tea, I will snip the filter cap and bring it up on the Variac.
ID:	35181   Click image for larger version
ID:	35182   Click image for larger version
ID:	35183   Click image for larger version
ID:	35184   Click image for larger version
Old 30th Apr 2010, 5:09 pm   #23
Sideband
Sideband's Avatar
Default Re: Pye v4
The emergency services are on alert.....
Rich.
Sideband is offline
Old 30th Apr 2010, 5:23 pm   #24
Tazman1966
Tazman1966's Avatar
Default Re: Pye v4
Wow Chris, you really have got the bug now! Looking forward to seeing what happens.
All the very best,
Tas
Tazman1966 is offline
Old 30th Apr 2010, 6:46 pm   #25
oldticktock
Default Re: Pye v4
metered the main AC input for continuity, nothing need to check the heater chain like the TV63.
Old 30th Apr 2010, 6:52 pm   #26
murphyv310
murphyv310's Avatar
Default Re: Pye v4
Hi.
Check after the switch it may be lazy contacts, they usually clean up with some power applied!
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is offline
Old 30th Apr 2010, 6:59 pm   #27
Boom
Default Re: Pye v4
Let me know when you get around to Pye B18T's Chris and you can finish mine off.
Dave
Boom is offline
Old 30th Apr 2010, 7:42 pm   #28
oldticktock
Default Re: Pye v4
This may take sometime.
I've tested all the valves heaters....ok
I've checked F3...ok
I've checked the On/off...ok
The CRT heater was up and running on Davids CRT tester, so that's ok.
I will now have to delve into the rats nest and check the physical wires on the chain,grrr stupidly i was hoping to get at least past this stage, hey ho!
Chris
Old 30th Apr 2010, 10:00 pm   #29
oldticktock
Default Re: Pye v4
Strange I've checked the heater chain wiring, all bar 2 EF80's which are buried under a shielded, under chassis box unless its one of those two (unlikely) then I cannot fathom why this baby won't light up. Checked R138 and the parallel Thermistor and R137 which are in the chain and they are ok too.
Calling quits for tonight, will check R134,R135 & R136 tomorrow with a fresh head maybe I will see clearly.
Chris
P.s Take that all back just tried again and I have heater lights and line whistle
Old 30th Apr 2010, 10:22 pm   #30
oldticktock
Default Re: Pye v4
Ok full mains applied, line whistle present but blank screen.
Tried the screwdriver on the EY51 and I can draw a spark, not so on the PL81 or the PY81 which I beleive, I should be able to.
Could it be the ION trap position it's lined-up with pin 3 with the arrow pointing towards the screen maybe swing it round 360 I seem to remember David suggesting this.
Could it be brightness bias down to chassis?
Am i right that there are only 3 things which can cause blank screen,
1. heater power
2. grid bias if down to chassis causes
3. EHT supply
possible 4 if fly-back EHT is used then line TB,LineTB Osc weak & line TB freq low
I think I read so much lately I can't see the wood for the trees, perhaps it's the simple one the ION trap, perhaps the PL81/PY81 is the clue (no spark) heaters lit though
Tomorrow, I need to sleep.
Chris
Old 30th Apr 2010, 10:40 pm   #31
murphyv310
murphyv310's Avatar
Default Re: Pye v4
Don't worry about the spark on the PL/PY81 the EY51 is the important one, does it light up? If so remember that the tube you got may be low emission so adjust the ion trap with the brightness well up and the "lights" off in the attick!!!!
Cheers,
Trevor.
Old 30th Apr 2010, 10:48 pm   #32
Boom
Default Re: Pye v4
Chris. There MIGHT be a (faint) line painted on the tube neck. The Magnet lines up with this line with the arrow pointing towards the front of the screen. It is not present on all tubes though.
Dave
Boom is offline
Old 30th Apr 2010, 10:56 pm   #33
oldticktock
Default Re: Pye v4
Sussed why the set was not powering up.
On the back you have to make connection on a panel
for 240 it should be 1,2 & 5 on this setting its dead,
for 250 1,3&5 dead
I moved it to 1,2 &4 (220) it fires up
Old 30th Apr 2010, 11:05 pm   #34
FERNSEH
FERNSEH's Avatar
Default Re: Pye v4
Hi Cris,
The EY51 filament does not seem to lit so there's a possiblity that the CRT anode volts are not present. You could try drawing a spark from the filament end of the EY51. I think the corona ring is connected to the EHT lead. If the EHT voltage is about 10KV the spark drawn should be in the order of 12mm. Use an insulated screwdriver to do this, the metal shaft must be connected to the chassis.
Check that the A1 volts are present at pin 11 of the CRT base, it should be something like 300 to 400 volts.
Remember that in certain CRTs the adjustment of the ion trap magnet can be very critical.
The CRT was removed from a McMicheal TM54 15 years ago.
DFWB.
FERNSEH is offline
Old 1st May 2010, 6:50 am   #35
oldticktock
Default Re: Pye v4
Having to run this via the variac on 223V due to the odd voltage selector issue
Your right I cannot see a glow in the EY51, although I can draw a spark about 7mm long.
Not being familiar with the EY51 rectifier (only experience is with EY86's) I find it strange that the EHT wire is coming out of the bottom end of the valve (see pic). I thought that end which has the two wires was the heater end, the other end with the single thicker wire being the business end and where I would have expected the EHT lead to be attached, is it wired correctly? to me it looks like its coming off the heater, there appears to be 3 connection points at this end, two next to each other (Heaters?) an one below them, should it not be on the one below or the other end of the valve? I'm probably barking wrong though.
The CRT results:-
pin2 105V
pin5 77V
pin6 77V
pin7 77V (this bank of 3 are strapped together)
pin8 75V
pin10 135V
pin11 76V
I think the above explains why the screen is blank
ID:	35213   Click image for larger version
Old 1st May 2010, 8:10 am   #36
audiomagpie
audiomagpie's Avatar
Default Re: Pye v4
Hi Chris
If you look up inside 'the bell' of the EY51 you should see a normal orange heater glow.
But it won't light up until the L/O stage starts to operate. Otherwise disconnect the two thinner legs at the EHT end and check heater continuity. It was open circuit on my Fergy. I Have a spare EY51 if you need one, Sean (our mod) very kindly sent me two!
Greg
Greg
BVWS committee chairman
audiomagpie is offline
Old 1st May 2010, 8:20 am   #37
Kevin19
Default Re: Pye v4
Hi Chris
Always wanted one of these but have been put of by the complexity of the set! I'm sure you will crack it and any way I do have two other Pye sets waiting in the wings. Had just the same problem with the VT2 re the mains adjuster resistor think on the V4 Trader sheet that's R134 135 136 in fact mine went bang for some reason! Very big bang to! which was interesting! Its a 3 section wire wound job on the VT2 so assume would be much the same on the V4. And yes that's quite right as you set is re the EHT take off from the EY51 if you look and the Trader sheet and V11 you an see the EHT coming off there going to the CRT.
Best of luck will follow progress.
Kevin
Kevin19 is offline
Old 1st May 2010, 10:28 am   #38
oldticktock
Default Re: Pye v4
I have not disconnected the EY51, continuity checked in situ.
1.There is continuity between the filaments.
2.There is continuity between the EHT connection/filament joint and the anti corona ring
3. There is continuity between the two end of the EHT lead
Old 1st May 2010, 10:52 am   #39
Boom
Default Re: Pye v4
You can't do that. You need to remove the EY51 and check it.
Dave
Boom is offline
Old 1st May 2010, 10:57 am   #40
oldticktock
Default Re: Pye v4
Oh, ok will do
