Old 9th Apr 2010, 12:57 pm   #141
oldticktock
Default Re: Tv62
Ok Jeffrey will do,
just found one other which is 12v 1.25A would it suit better or does it really not matter as you say.
oldticktock is offline
Old 9th Apr 2010, 1:45 pm   #142
ppppenguin
ppppenguin's Avatar
Default Re: Tv62
Really doesn't matter. Whatever's more convenient. Just try to measure the voltage on load to check it isn't above 14V DC.
ppppenguin is offline
Old 9th Apr 2010, 2:03 pm   #143
oldticktock
Default Re: Tv62
I decided to put the new electrolytics in place to see how they would fit and how I would arrange them. Lucky for me the 100+100uF slotted into the old can position nicely. The 220uf was clipped to chassis just behind, whilst it was all there I thought might as well solder it in place.
So now the fun begins, just going to reinstall back in the case and fire up I will report back with results.
Chris
ID:	34284   Click image for larger version
Old 9th Apr 2010, 4:01 pm   #144
oldticktock
Default Re: Tv62
Ok Set switched on The big bad hum is gone.
Now with volume on max I just get the usual volume hum.
nothing on screen no life from EY86
Chris
Old 9th Apr 2010, 4:12 pm   #145
ppppenguin
ppppenguin's Avatar
Default Re: Tv62
Any buzz from the frame timebase? Any whistle from the line timebase? Adjust the frame and line holds up and down to make them more audible. If something's audible that's a very good start.
Any visible distress? Especially in the LOP valve. If there is, need to switch off and track it down.
If no audible evidence of timebases, since you've had the set apart it's worth poking around with a meter to see that HT is getting to where it ought.
At this point, if HT is present, since I'm really a design engineer rather than a TV service guy I tend to dig out the 'scope and see what I can find. John W, Trevor and others with far more experience will have simpler methods.
The worry now is that you could be dealing with extra problems, caused by dismantling and reassembly.
Old 9th Apr 2010, 4:21 pm   #146
oldticktock
Default Re: Tv62
I now have a whistle, variac was only set at 200 now at 240
A pale purple glow in the EY86 and I mean very pale, it started brighter and I saw a little spark going round then it stopped now the glow has settled and is only best seen with the lights off.
Crt now has a pale glow at base where connector is assume the heater. When I adjust the line hold the whistle increases in intensity when rotated clockwise and decreases when turned anti clockwise.
all valves nicely glowing
Chris
Old 9th Apr 2010, 4:49 pm   #147
ppppenguin
ppppenguin's Avatar
Default Re: Tv62
This is sounding better. The line whistle should actually change pitch as you adjust the line hold. A change in loudness is incidental. Using a well insulated screwdriver you should be able to draw sparks from the LOP anode and bigger sparks from the EY86 anode. DO NOT EARTH THE SCREWDRIVER. You should also be able to draw thin yellowish sparks from the EHT, either at the CRT or EY86 cathode.
EHT present? Good. If not, we need to sort that before anything else. Can you see anything on the screen as you adjust the brightness control? No? Time for further tests.
Measure the voltages on the CRT base. They should be on either the Bush or trader bumph. The cathode should have video on it, DC level probably a few 10s of volts. The grid voltage shoudl vary with the brightness control. The first anode should have a few 100 volts on it.
Old 9th Apr 2010, 4:58 pm   #148
oldticktock
Default Re: Tv62
Ok LOP i think you mean for me the PL81 TC so I did and got a little blue spark
EY86 anode i touched the lead wire where it hits the solder point, got a little blue spark.
nothing on screen when brightness adjusted
Is it alright to measure with my bench meter all pins on the CRT base? and what is the pin order?
Ok looking at the connector working clockwise from the connector notch
pin1 63v
pin2 12.5v
pin3 154v
pin4 12.6v
pin5 2.8v
pin6 154v
pin7 4.1v
pin8 98v
pin9 98v
pin10 121v
pin11 97v
pin12 4.7v
Old 9th Apr 2010, 5:27 pm   #149
Boom
Default Re: Tv62
Chris, I'd play on the safe side and use a stabilised PSU. I have seen warnings on the Aurora site that the device could be damaged if the input is too high and some of these cheap PSUs can go way up. Personally I use a switched 1A output device on 9V.
Dave
Boom is offline
Old 9th Apr 2010, 5:38 pm   #150
ppppenguin
ppppenguin's Avatar
Default Re: Tv62
Most of the CRT pins are irrelevant here. It's just like an octal base but with 12 pins so pin 1 next to the locator notch, clockwise round to pin 12.
Cathode: pin 11, 72V
Grid: pin 2, 0-200ish, varies with brightness control
1st anode: pin 10, 380V
Heater 1&12, should be 6.3VAC across these
Pin 3: No pin. Used as connection point only.
pin 6: Says A2+A4 but seems to be unconnected on Bush circuit. i'm a bit confused here. EDIT: It's the focus anode. COnnected to pin 1, 3 or 10 for 0V, about 200V or about 380V. Not critical at this stage.
You won't see anything on screen unless the grid voltage is fairly close to the cathode. You can short them together with a clip lead to force the CRT to conduct. Make sure the brightness control is about midway first.
PS: David I agree a stabilised supply is the way to go but provided it's under 16V on load you won't hurt the Aurora. For continuous running then 7 to 12V on load is ideal. The off load voltage of an unregulated supply may be quite a bit higher than the on load voltage. If you're nervous use a 47R 5W resistor as a dummy load to check the on load voltage. I use an anonymous 9V 1A wall wart which happened to be in my box. Don't even know if it's stabilised but it's fine.
Old 9th Apr 2010, 5:56 pm   #151
ppppenguin
ppppenguin's Avatar
Default Re: Tv62
Couple more things. Is this bent gun tube? Bush bumph says no ion trap but Mullard data says it needs one. If the gun structure is obviously wonky looking then there should be an ion trap magnet which adds another complication.
Also sounds like the EHT is a bit weedy. Should be a good zap from the EY86 anode. Then a rather weak looking spark from the DC at the EHT connector or EY86 cathode.
Old 9th Apr 2010, 6:05 pm   #152
oldticktock
Default Re: Tv62
Looks straight to me unless we are talking a subtle bend, I cannot see one.
Have a look at pic
Shall I change the EY86? I'm new to TV's but i was expecting a much more vigorous glow from the EY86
Old 9th Apr 2010, 6:08 pm   #153
julie_m
Default Re: Tv62
Rectifiers aren't supposed to glow purple. That could be a bad sign!
If you can get hold of a BY8424, you might be able to use that as a temporary substitute.
julie_m is offline
Old 9th Apr 2010, 6:11 pm   #154
oldticktock
Default Re: Tv62
I have many spare EY86's/87's
Old 9th Apr 2010, 6:47 pm   #155
oldticktock
Default Re: Tv62
Ok changed the EY86 and now I have I believe what you TV guys call a raster, its off-set and the width pot does not bring it right across. I'm wondering if I need to adjust that picture centering device but I guess I've got more going on with it being a single squashed line.
John W I believe the screen is talking to me but I don't yet speak its language
The raster has shrunk a bit
Chris
ID:	34288   Click image for larger version
Old 9th Apr 2010, 7:00 pm   #156
ppppenguin
ppppenguin's Avatar
Default Re: Tv62
Great! You haven't got a raster yet because the frame timebase isn't dong its job yet. Keep the brightness down so you don't burn a line across the CRT.
Check the voltages around V2b and V3, the frame timebase valves.
Don't worry about fine adjustments of width etc until you've got a picture on the screen. Doesn't matter if it's distorted and offset, just get a picture of some kind.
Old 9th Apr 2010, 7:02 pm   #157
oldticktock
Default Re: Tv62
see I told you I don't know what i'm talking about
I have kept the brightness down the camera makes it look high.
Ok i'm confused v2b is that the ecc82? on the main deck?
Old 9th Apr 2010, 7:12 pm   #158
Top Cap
Top Cap's Avatar
Default Re: Tv62
Hi Chris, your TV62 appears to have frame collapse so you need to look into the frame oscillator/output stages. The set also appears to have an Ion Trap magnet fitted, it is the clip located around the crt neck close to the base and it carries a small magnet.
Be careful about adjusting this as miss adjustment can cause you to lose the picture, panic and wonder what the hell is wrong. I have known engineers to spend hours trying to find a fault only to discover the Ion trap magnet was out of adjustment. Best wait until you have a full screen raster at least!
Les
Whether the Top Cap is Grid or Anode - touching it will give you a buzz either way!
Top Cap is offline
Old 9th Apr 2010, 7:25 pm   #159
oldticktock
Default Re: Tv62
OK checked ecc82 voltages.
Bench meter to read ac/dc
pin1 98
pin2 2.6
pin3 5.7
pin 4&5 strapped together (heaters) this cannot be right 79v
pin6 110
pin7 cannot get a stable reading meter goes hay wire
pin8 2.5
pin9 84
Sean Williams had a similar fault on his and it was the PCL83 frame oscillator although he did not have whistle which i do. He replaced the pcl83 and it worked
Old 9th Apr 2010, 7:34 pm   #160
ppppenguin
ppppenguin's Avatar
Default Re: Tv62
Originally Posted by Top Cap View Post
The set also appears to have an Ion Trap magnet fitted,...
I think it's a centring magnet. OTT reckons it's a straight gun CRT.
BTW, forget about measuring heater voltages at this stage. You know they're OK. (Pins 4, 5, 9 on the ECC82, 4 and 5 on most B9A valves.
PS: Set the meter to read DC. You'll confuse us all if you try to read AC. If you have an analogue meter then better still, it won't be confused by pulse signals.
