11th Jan 2009, 9:10 pm | #1 |
Ekco CT101 is alive (Actually a CT100(M))
Hi everyone.
The big old Ekco colour set is now alive, although still needing a fair amount of work. On initially powering the set up last week there was a very dull half-width raster which faded out after a few minutes and then never returned until today. On removing the EL300 line output valve and measuring the voltage on the screen grid pin there was 200V (in line with what was expected) but checking the control grid revealed a lack of any line pulses, although there was a fair amount of noise from somewhere. The voltage readings round the line oscillator were kind-of okay (considering the oscillator wasn't running) so some cold resistance and continuity checks were made. Everything seemed in order so the few capacitors which made up the "tuned-circuit part" of the blocking oscillator were checked and hey-presto a 250pF capacitor came away before I'd even had a chance to touch the soldering iron on it. Remaking the connection and connecting the set back up revealed some nice big line pulses, so the EL300 was plugged back in and a nice(ish) blank raster was revealed. Among the other things that need to be sorted out are: - Focus is very bad although it is adjustable - just not enough - There is only a blank raster and slightly crackly sound - The UHF / VHF switch appears to do nothing - There is a blue band down the left hand side of the picture The tube doesn't seem half bad, although it's difficult to make much of any judgement with a blank out-of-focus raster. Working on the set is very awkward, the only real way is to get to anything is like working on a car - by lying underneath. The trouble is that as my tired 37-year-old eyes can't focus in as closely as once they might, I'm constantly working in a slightly out-of-focus fuzz. Anyway, I'll post some more when I get to the bottom of some of the other problems. Thanks everyone. Kind regards. From Mike.
G7TRF |
11th Jan 2009, 9:17 pm | #2 |
Re: Ekco CT101 is alive
Congrats Mike,
Im sure I would not want to be dealing with this monster! - there is one hell of a lot of stuff in there! Cheers Sean
11th Jan 2009, 9:20 pm | #3 |
It looks in lovelly condition . re the eyes , get some cheap specs for a few quid from the chemist , work wonders on the vision .My eyes are ok close up but i borowed some to take out a splinter and it was amazing improvement , just right to do this sort of work .
11th Jan 2009, 9:37 pm | #4 |
Thanks Sean. It can be a little bit intimidating to start with, but no more so than a Philips G6. After a while though the image and layout seems to kind-of sink-in and it doesn't worry you quite so much.
G7TRF |
11th Jan 2009, 9:44 pm | #5 | |
Ive got one of those headband things with two magnifying glasses for each eye. There's not a huge amount of magnification so focus is good, I think CPC do them for about a fiver well worth it though. Keep us posted. Cheers. Trevor
11th Jan 2009, 9:45 pm | #6 | |
As for the cabinet, it is pretty good really - There are one or two cracks in the (cellulose?) laquer on the top, but generally it's not bad at all. It does look like a mid-late 1950s set, but it's actually 1964-ish.
G7TRF |
11th Jan 2009, 9:49 pm | #7 |
Lovely to see that working - be excellent when done fully! No manual?
Sean - just break it down into separate bits. Easy to do. Cheers, Steve P.
11th Jan 2009, 10:02 pm | #8 | |
I'm really looking forward to seeing it working too; I just hope I get some more time soon to carry on with it, especially as my hall looks like a bomb has hit the place now.
G7TRF |
11th Jan 2009, 10:04 pm | #9 |
1 word summs that up Mikey - Superb !
I'll be following this one with interest. Regards Dr. Dave
Do you have the scope to be a TV repair man |
11th Jan 2009, 10:07 pm | #10 |
That may be the answer Trevor - I guess they might be designed to fit over normal glasses - I'll have a look on the CPC site tomorrow.
G7TRF |
11th Jan 2009, 10:13 pm | #11 |
Brilliant news Mike Very much looking forward to seeing this old beauty fully up and running.
I bet your well pleased so far, i would be Once again a very hearty pat on the back mate Regards, Marcus. |
11th Jan 2009, 10:17 pm | #12 |
I didn't really do very much to get it going Marcus, but thank you anyway. I certainly am most pleased with the results so far though.
G7TRF |
11th Jan 2009, 10:19 pm | #13 |
Great news Mike
I agree with Sean's comments but when I read your reply about the layout etc sinking in, I agree with that too. This could well turn out to be the jewel in the crown of your collection. I can't wait for the next instalment. Best wishes, Tas PS Have you tried improving the lighting in your hall for close up work? |
11th Jan 2009, 10:21 pm | #14 | ||
G7TRF |
11th Jan 2009, 10:23 pm | #15 |
Might be worth investing in one of those fluorescent torches, which give a very bright and even illumination. Forum member Zelandeth has a website dedicated to torches, and ISTR he thought highly of a cheap Osram(?) one stocked by Screwfix.
11th Jan 2009, 10:26 pm | #16 |
Hmmm...not so sure about that Mike...and I'm a fan of those Pye Hybrids
All the very best, Tas |
11th Jan 2009, 10:36 pm | #17 |
Hi Mike,
Good to see you've made progress. Are you still using the toaster as a lamp limiter? I'll be looking forward to more pictures as you continue with it. Good luck Mate. Trev
I'd just like to say "Good luck, we're all counting on you" |
11th Jan 2009, 10:40 pm | #18 |
Tube looks great. I've got a spare 'crawling board' that I use to get under the trucks if its any help.... Great project. Regards, John.
11th Jan 2009, 10:41 pm | #19 |
Thanks Dave. I'll keep you posted.
G7TRF |
11th Jan 2009, 10:44 pm | #20 |
Not using the toaster any more Trev. I need it for making toast.
G7TRF |
