9th Mar 2008, 5:24 pm | #1 |
Missing Sets?
Tell you some other models that aren't around much these days...
Thorn 8800 Thorn 9000 - all models. The Cylops PSU seems to have vanished without trace! Cheers, Steve P
9th Mar 2008, 6:51 pm | #2 |
Re: Missing Sets?
Hi.
How about the Murphy V510 from 1960 I haven't seen one since the early 70's, even the 410 has got very thin on the ground but there still is plenty of the older 310's about. Trevor
10th Mar 2008, 12:20 am | #3 |
Re: Missing Sets?
The BRC 9000 series were excellent receivers, introduced in late 1975 these Ferguson and Marconi sets displayed the very best pictures to be seen anywhere. The first UK set to employ the PIL CRT.
As for the 8800, who cares? Best forgotten. Even worse, the 9800 series. Trevor. Yes, there seems to be plenty Murphy V310s about, but as for the much better V410, I have not seen one for years. DFWB. |
10th Mar 2008, 8:41 am | #4 |
Re: Missing Sets?
the 9800 with it diode split transformer and the inerca start circuit
i liked the 9000 have not seen one for years the syclops circuit was a good one but the mazda tubes use to go quick probably the way it was driven |
10th Mar 2008, 9:01 am | #5 |
Re: Missing Sets?
Philips G9 (fortunately!)
I agree with all said about the 8800 and 9800; an 8000 with ideas above its station. They won't be missed by me. I always found the 9000 an excellent and reliable chassis, and fairly simple in terms of component count. The "ssshyump" noise on switch-on was unmistakable in a crowded shop! Not many 9600s around either - they were good. Wonder how many ITT-KB CVC2s there are left?
Mike. |
10th Mar 2008, 9:29 am | #6 |
Re: Missing Sets?
Has anyone seen an ITT CVC20 recently? They aren't even mentioned much (if at all) on this forum so they must be scarce. The same goes for the CVC30 and 32, did the useless line transformers claim them all?
I can't quite beleive that all the 9000's are gone, we used to sell loads of those. The 9600 was always rather rarer, shame because it was a much better proposition than the 9000 (or the 9800, though didn't that use a diode-split LOPT that look like the one in the G11? Progressive stuff for BRC if it is true). Something that I never saw much of even at the time was the GEC Starline. There seemed to be two sorts, a 20" one with a Hitachi tube (like the TX9) and a 22" one with a 20AX. I remember the big one as being particularly nicely styled with nice rounded corners, black trim around the front and neatly recessed thumbwheel controls. They all seemed to be a pleasant pale wood effect colour which made the mucky brown plastic BRC sets we had look a bit tacky, do any survive? |
10th Mar 2008, 11:49 am | #7 |
Re: Missing Sets?
Well, there's at least one left! I acquired it fairly recently but, as some forum members will know, I had been actively looking for quite some time without even a hint of one turning up. So they certainly do appear to be thin on the ground.
It's a 20" Thorn Television Rentals Model 773 badged for the Multibroadcast chain. Ultrasonic remote control (sequential channel change & sound mute only) with nixie tube channel indication (nice!). I'll attach some pictures. It was in a bit of a state as found, but has cleaned up a little and works well after some fairly minor repairs. Very luckily, it has a nice bright Thorn New-Life CRT. More cosmetic restoration will be required. I also have a 22" 8800 in the form of one of those rather nice bevelled edge wooden HMV models. I like it, but, as the general consensus seems to be they're only good for fire wood, I'll keep that one to myself! ScreenSaver Last edited by ScreenSaver; 10th Mar 2008 at 11:56 am. |
10th Mar 2008, 12:03 pm | #8 |
Re: Missing Sets?
Wonder if anyone's got a Finlux Peacock?
Is it me, or is the G8 a lot more common now than the G11? Mikey405 has a CVC2 and I think so has System A. Cheers, Steve P.
10th Mar 2008, 2:57 pm | #9 | |
Re: Missing Sets?
I worked on a couple of these (9000) in the beginning of the 90's. Haven't seen any since. Did the 8800, 9600, 9800 look similar to the 9000? |
10th Mar 2008, 3:01 pm | #10 |
Re: Missing Sets?
I have recently unearthed a CVC 20 from the loft and it still works well. Needed a very thorough clean inside and out though - extremely dusty!
Its badged as 'Aristocrat', a non remote model from 1981-2. |
10th Mar 2008, 4:25 pm | #11 |
Re: Missing Sets?
In 1978 another version of the 9000 series appeared. The Mazda/RCA CRT was replaced by the Brtitish made Mullard A51-570X. About the same time the PCB artwork was done by CAD. The 9000 series got even better.
Mullards received a grant from the Goverment to make a 20" CRT in the UK. The aim was to reduce the amount of imported 20" CRTs. The 9600 series was a brilliantly over engineered creation. Ferguson TV designers could always come up with clever ideas. The cleverest was the 2000 series. DFWB. |
10th Mar 2008, 4:39 pm | #12 |
Re: Missing Sets?
Although it was a daring step to make the world's first all transistor colour TV the actual design is really quite simple and conservative. Yes, it was pushing the technology to do the solid state LOP but that forced the designers to use separate EHT which in turn gave professional monitor grade performance in that area. The downside, apart from nasties like the edge connectors, was cost. It's difficult to see how they ever made a profit from the 2000.
At the opposite extreme are very clever though possibly misguided designs such as thyristor LOP, syclops and heaven knows what else to give the service guys a headache. |
10th Mar 2008, 6:02 pm | #13 |
Re: Missing Sets?
And to get transferred from the "for Tritel" shelf to my car boot .....
Mike. |
11th Mar 2008, 9:52 am | #14 | |
Re: Missing Sets?
There was also a "monitor-styled" version of this chassis with a quite comprehensive remote control unit that pushed into the front. Does anyone have a picture of this model? |
11th Mar 2008, 10:04 am | #15 |
Re: Missing Sets?
I work at two bus garages in London and at our Harrow Garage the engineers mess(very appropriate) room has one of these very sets (I think) still in action and on for most of the day everyday. I'll take a couple of pictures when I'm there later this week.
All the very best, Tas |
11th Mar 2008, 11:43 am | #16 |
Re: Missing Sets?
there was a 9000 monitor style multibroadcast which looked very good
it came in white as well silver had a tint controll at the front and a tone control also search tuining with auto memory and a pocket to house the remote control the 9800 did have a diode split transformer like the G11 but with a delta gun tube it was a c**p set which had a bowed front cabinet Last edited by gec2110; 11th Mar 2008 at 11:46 am. Reason: add a sentace |
11th Mar 2008, 12:48 pm | #17 | |
Re: Missing Sets?
Can't be any of these receivers still service. DFWB. |
11th Mar 2008, 12:50 pm | #18 | |
Re: Missing Sets?
Wasn't the slightly nicer 9000 with the Philips tube and the search tuner called the 9200, or was that something else? |
11th Mar 2008, 2:35 pm | #19 | |
Re: Missing Sets?
The 9300 was specifically for the Irish market and incorporated the twin tuners, but without the nixie. The other major 'feature' of this version was a modification to provide a customer adjustable vertical hold control. This was deemed necessary in the Irish market due to greater co-channel interference problems. I think you've got to wait for the 9600 for sweep tune, but I could very easily be wrong (again!). I'm sure there were some 9400 variants. I've got a set of the service manuals used by Thorn Television Rentals for the 9600 series, and it lists no fewer than 33 offered model variations. These cover chassis types 9570, 9600, 9600B, 9602, 9606, 9641, 9643, 9650, 9653, 9670, 9700...there's probably more but I'll stop there! Quite a few of these have twelve button tuning options, full remote, sweep tune and teletext. Many of these variations are for rental uses only - some are standard retail re-badges. Therfore this backs up the many recollections of features and variations associated with 9000 series sets! Is it possible the bargain basement 9800 was the last UK sold set to use a Delta Gun CRT? ScreenSaver Last edited by ScreenSaver; 11th Mar 2008 at 2:41 pm. |
11th Mar 2008, 2:40 pm | #20 |
Re: Missing Sets?
I THINK it was designated the 9004 for some reason. How well did the A51-570 last? They didn't last in KT3s and Decca 80s, but did in KT4 and CTX chassis. I know there was a -580 in the TX9 which didn't do so well...
The cabinet on the poverty rental models was 'blotting paper' chipboard with a Fablon coating - a slightly damp workshop (yes, there is such a thing!) resulted in the finish peeling off and refusing to go back! Glyn |
