Old 7th Feb 2007, 1:39 am   #1
Steve_P
Steve_P's Avatar
Default Ferguson 3V29 VCR
No 12v - Fixed.
Still no deck action. Bulb Changed - still nothing. Now what??
Cheers,
Steve P
Steve_P is offline
Old 7th Feb 2007, 8:12 am   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: Ferguson 3V29 VCR
Steve,
Try the transistor that feeds the lamp, apparently Q1 on the deck terminal 1 board, a BC307 is said to work.
See Joe Cieszynski's superb article in the Jan. 92 issue of Television. PM me with e-mail address if you want a copy.
Nick.
Nickthedentist is offline
Old 7th Feb 2007, 5:02 pm   #3
Mikey405
Mikey405's Avatar
How about checking the "Dew" sensor Steve(?) Also try covering up the end sensors with tape if you have the lid off.
From Mike.
Mikey405 is offline
Old 23rd Feb 2007, 7:13 pm   #4
Steve_P
Steve_P's Avatar
Default Ferguson 3V29 VCR Problem
Put a tape in, press play. Laces up, but for the capstan, which sits there and does nowt. Any ideas.
(I've never got on with Videos!)
Cheers,
Steve P
Steve_P is offline
Old 23rd Feb 2007, 7:35 pm   #5
rank-bush-murphy
Default Re: Ferguson 3V29 VCR Problem
i have had dead spots on the capstan motor on a lot of early thorn and hitachi machines check its supply voltage if ok check that it is drawing current
rank-bush-murphy is offline
Old 23rd Feb 2007, 7:53 pm   #6
System A
System A's Avatar
Hi Steve , have you tried the loading belt . ?
Regards . GP .
System A is offline
Old 23rd Feb 2007, 8:44 pm   #7
Steve_P
Steve_P's Avatar
This gets sillier. Only does it when warm. From cold, no trouble!!!
Cheers,
Steve P
Steve_P is offline
Old 23rd Feb 2007, 9:19 pm   #8
A_W_TYE
A_W_TYE's Avatar
Hi Steve
Try cleaning the belts and pullies they tend to slip
Alan
A_W_TYE is offline
Old 23rd Feb 2007, 10:13 pm   #9
stuie319
stuie319's Avatar
Hi Steve,
As system A says, its almost certainly the loading belt, specially if its ok from cold. When it starts to fail it just misses that last little bit of torque needed to close the mode switch. Bit of a sod to change from what I remember. Before removing the loading motor use some elaccy bands or summat to hold the guides in the unlaced position, else you run the risk of the loading rings jumping free and losing the mech timing.
Regards, Stu
stuie319 is offline
Old 24th Feb 2007, 11:10 am   #10
Mikey405
Mikey405's Avatar
Definitely the loading belt Steve. It does it on loads of those JVC / Fergie video models.
From Mike.
Mikey405 is offline
Old 24th Feb 2007, 7:32 pm   #11
Mike Phelan
Mike Phelan's Avatar
I really should have remembered 'bout the loading belt, Steve.
I seem to remember the grease on the loading rings getting gummy, as well.
Mike.
Mike Phelan is offline
