Old 1st Feb 2007, 9:46 pm   #1
FERNSEH
FERNSEH's Avatar
Default Ferguson 59P7: A British Predicta?
I'll have to find a picture of the set.
Ferguson produced this set from 1990 to 1991. Like the Teleavia and the Predicta, the upper part of the cabinet was designed to follow the shape of the CRT. The lower part had the appearance of a plinth.
It was a clever piece of design form. However, the set employed the ICC5 chassis and just about every TV engineer in the land could not wait to get rid of them. Someone out there must still have one.
DFWB.
FERNSEH is offline
Old 1st Feb 2007, 10:02 pm   #2
Steve_P
Steve_P's Avatar
Default Re: Ferguson 59P7: A British Predicta?
Well I'll get in first and say NO!! Welsh Anorak might have, though.
This set was designed by THOMPSON CSF in France, and it was a very unpleasant wake up call for TV Engineers across the country. I saw one of these in a TV shop in Wigan, but that was years ago.
I thought I was mad...
Cheers,
Steve P
Steve_P is offline
Old 1st Feb 2007, 10:17 pm   #3
FERNSEH
FERNSEH's Avatar
The chassis of the 59P7 was made by Thomson in France or Germany but the cabinet was designed and made in England and final assembly was at the Gosport factory. A typical date label on a set would be G90 XX indicating the build year 1990 at Gosport.
I think one of my customers still has a 59P7. If so I'll take a picture of it.
When you see the pictures you'll see how interesting the set was/is. At least it's appearance.
DFWB.
FERNSEH is offline
Old 2nd Feb 2007, 12:19 am   #4
stuie319
stuie319's Avatar
59P7 yuk! and the ICC5 within it
Our boss bought loads of these for rentals, and I reckon this set marked the
beginning of the end, since the later Thomson chassis' got even worse.
The design of the thing if I recall correctly meant that once the back was
removed the set had no mechanical stability at all, and once the chassis
was out even less, the whole weight of the tube supported by a flimsy plastic surround.
If you had to deal with one in the field and it was bolted to
its stand it was even worse.
Was this the one that used to burn up around the EW modulator coil?
Nurse? Nurse!......
stuie319 is offline
Old 2nd Feb 2007, 2:08 am   #5
FERNSEH
FERNSEH's Avatar
Hi Stuie,
OK, the ICC5 chassis was awful and the construction of the cabinet was somewhat flimsy but you have to admit it looked different when it was compared with the rather bland looking products offered by other manufactures.
I'll take pictures of a 59P7 tomorrow.
DFWB.
FERNSEH is offline
Old 2nd Feb 2007, 7:26 am   #6
dsergeant
dsergeant's Avatar
Personally I have repaired loads of ICC5s over the years and never really found them that bad - the odd fault I had to scratch my brain over, but most fairly straightforward. Much better than the current strain of Vestel sets, and certainly a lot better than some of the Sharp nightmares.
Dave
dsergeant is offline
Old 2nd Feb 2007, 10:40 pm   #7
FERNSEH
FERNSEH's Avatar
Here are the pictures of the Ferguson 59P7.
Without doubt the cabinet designer was inspired by the shapes of the Predicta and Teleavia 111.
Is the set worth considering as a collectable sometime in the future?
DFWB.
ID:	8029   Click image for larger version
ID:	8030   Click image for larger version
ID:	8031   Click image for larger version
FERNSEH is offline
Old 2nd Feb 2007, 10:53 pm   #8
Nickthedentist
Nickthedentist's Avatar
That's interesting David - though not as striking as the Predicta.
There was also a little 14" TX90 in a vaguely similar cabinet (Fergy 14M01) with a tube-hugging upper section (albeit with a squarer, stepped profile) atop a rectangular box which housed the chassis and transformer. The two bits were designed to look as if they were separate units, a bit like the cheap pseudo-stacking hifi systems of the same era. Coincidentally, I found one of these TX90-based sets in some communal bins only this week, but it gave off a horrible burning smell when I powered it up so I put it back where it came from and it was taken away this morning. Wish I'd taken a picture now
Nick.
Nickthedentist is online now
Old 2nd Feb 2007, 11:05 pm   #9
ppppenguin
ppppenguin's Avatar
That looks very much like my main telly! Mine is a 21" set with a TX98 chassis. Bought it ex rental in about 1995 and had to replace the LOPT a couple of years ago.
Really doesn't look anything special to me. Just yet another black plastic box.
ppppenguin is offline
Old 13th Feb 2007, 1:53 pm   #10
Tazman1966
Tazman1966's Avatar
Sure enough Brian, a very good picture. The set has now gone to a new home. A friend of mine has taken it for his elderly Aunt for use in her bedroom. That's left some space for something else!
Tas
Tazman1966 is offline
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
