Old 8th Jul 2020, 10:36 pm   #1
Burnt wire
Burnt wire's Avatar
Default Scopex 4D10a
Hi there all,
I've just got a Scopex 4D10a and I didnt get any probes with it, so I purchased some probes and I'm damned if I can find out how to do the compensation on the scope ! If any one can give some info I'd appreciate it. they have 1x and 10x switch.
Burnt wire is offline
Old 8th Jul 2020, 11:41 pm   #2
PETERg0rsq
PETERg0rsq's Avatar
Default Re: Scopex 4D10a
Pretty sure there is no option for probe compensation on this scope.
Channels can be compensated internally, but reference is made to do it with a Scope calibrator connected directly to the chanel inputs.
If you are after a manual, look for one for a Racal 9386, as they are the same scope.
If you can't find it on the web, I can send a pdf copy.
SPECIALIST.....Knows everything about nothing
EXPERT..........Knows nothing about everything
PETERg0rsq is offline
Old 9th Jul 2020, 8:13 am   #3
ajgriff
ajgriff's Avatar
Most probes have their own compensation adjustment. Look for a small screw on the probe body.
Alan
ajgriff is offline
Old 9th Jul 2020, 8:41 am   #4
David G4EBT
David G4EBT's Avatar
Maybe I’m missing something, but as Alan says, every scope probe I’ve had has a small screw to tweak to adjust the compensation.
As often as not the probes have come with instructions and some included a small screwdriver.
Some info re the necessity for compensation here:
https://www.electronics-notes.com/ar...mpensation.php
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 9th Jul 2020, 8:41 am   #5
Neutrino
Neutrino's Avatar
The photos show:
• Probe Compensation Instructions
• Trimmer tool pointing to the trimmer
• Scopex 4D10A with probe having been adjusted (Note the excellent book propping up the scope!)
Most scopes have a probe adjust output that provides a square wave but the Scopex 4D10A doesn’t. I use my Aneng AN8008 which is reviewed here:
https://www.vintage-radio.net/forum/...d.php?t=138122
ID:	210618   Click image for larger version
ID:	210619   Click image for larger version
Neutrino is offline
Old 9th Jul 2020, 10:18 am   #6
Ambientnoise
If you’ve bought x1 probes (as opposed to x10 or x100), they almost certainly will not have an adjustment on the probe.
Ambientnoise is offline
Old 9th Jul 2020, 10:25 am   #7
ajgriff
ajgriff's Avatar
If they are switchable x1/x10 probes as stated they should have compensation adjustment.
Alan
ajgriff is offline
Old 9th Jul 2020, 3:11 pm   #8
DonaldStott
DonaldStott's Avatar
My probes have an adjustable x1/x10 slider switch:-
BVWS Member
DonaldStott is offline
Old 9th Jul 2020, 3:38 pm   #9
ajgriff
ajgriff's Avatar
..... and the compensation adjustment screw can be seen just next to the switch.
Alan
ajgriff is offline
Old 9th Jul 2020, 6:35 pm   #10
Burnt wire
Burnt wire's Avatar
Thanks for the input, I've found out the Scopex has its probes hooked up to an external square wave generator to adjust compensation. So I have managed to find one and when it arrives I'll be able to sort it out..
