Old 3rd Jul 2020, 12:17 pm   #1
Dave757
Default Parmeko model 9000/65B Mains Transformer
I have one of the above transformers and would welcome
some advice on its use.
It has three separate 6.3V windings, 1 amp, 2 amp, and 3 amp.
I would like to parallel the 2 amp and 3 amp windings as I need a 3.5A
heater supply, but there is no indication of the start of the windings,
so what is the best way of going about it?
Also, the HT supply is rated at 0.1A DC (CD). Does the CD perhaps mean
continuous duty? If it is, what would the intermittent rating be?
I am wary of using this as the power requirement for the receiver I
am thinking of using it with ( A Rees Mace CAT) is .135A.
Kind regards
Dave
Dave757 is offline
Old 3rd Jul 2020, 1:09 pm   #2
John_BS
John_BS's Avatar
Default Re: Parmeko model 9000/65B Mains Transformer
If you wire the winding in series you can then easily detemine the phases:
0V out: the two starts are connected
12.6V out: you have a finish connected to a start.
Re intermittent rating: if it's quite a large transformer, it will have a reasonably large thermal mass, so 35% overload would probably be fine for 10 to 20 minutes or so.
John
John_BS is offline
Old 3rd Jul 2020, 1:42 pm   #3
Dave757
Hi John,
Many thanks for that, I should have thought a bit harder about it.
Re the HT, although it is a very hefty transformer, I was thinking I
might get away with it as the radio has a 2W audio output, and I
would be lucky to use a fraction of that into headphones.
Then the grey cells kicked in momentarily, and I realised that if I turned
the volume down to nothing, it might save about 10mA at 245VDC.
Ah well!
Kind regards
Dave
Dave757 is offline
Old 3rd Jul 2020, 1:55 pm   #4
snowman_al
snowman_al's Avatar
Ah well!
Err, not if the amp is operating in Class A.
I do not know the circuit, but if it has a single output valve (6CH6?) then it draws (virtually) the same current regardless of volume.
Never Leave Well Enough Alone...
snowman_al is offline
Old 4th Jul 2020, 10:57 am   #5
Dave757
Hi Snowman,
Just shows how much I don't know about amplifiers!
I'd already decided that I didn't like the idea of drawing
more than the rated current. so as I still have work to
do on the set anyway, I will sort out a different HT source.
Many thanks for your reply
Kind regards
Dave
Dave757 is offline
