1st Jun 2020, 12:21 pm | #1 |
Philco remote control radio!
The restoration was finished a while ago , I had the cabinet restored , replaced all the usual capacitors , made a new battery pack for the remote , the remote sends a pulsing sig to the remote receiver seen on the right , the sig actuates a solenoid like a stepper motor , connected to a rotary switch , which in turn selects ,a pre set coil ,I had fun with the remote it didn't always work , I found the rotor was returning to quick sending pulses to fast , the solenoid couldn't keep up , an adjustment on the air brake cured the problem , I didn't like the sound too much bass , even at min on the tone control, so I fitted a tweeter and a mid range , plus a crossover from an old Philips speaker. much better now . A 120 volt tx fitted on it's own little shelf on the left. It must have been made for the UK/ European market ,as it has a long wave pre set coil.
1st Jun 2020, 12:23 pm | #2 |
Re: Philco remote control radio!
More pictures ,
1st Jun 2020, 1:35 pm | #3 |
A very comprehensive description of how the remote works can be found on the Radiomuseum Google Philco 39-116rx. Mick.
1st Jun 2020, 8:05 pm | #4 |
Mick.
As always outstanding work, and seeing the radio and the remote control to day I must say the quality just smacks you in the face. Kev. |
8th Jun 2020, 10:59 am | #5 |
Just how did you cut those apertures for the tweeter and mid range units - did you have to remove the grille cloth first?
Edward. |
8th Jun 2020, 2:46 pm | #6 |
Hi Edward the cloth had holes in it ,so it was no problem .Mick.
10th Jun 2020, 8:37 am | #7 |
What an interesting project Mick! Looks great.
Pete BVWS Member |
10th Jun 2020, 9:26 am | #8 |
Yes it was very interesting , I like a challenge ,I answer to Edwards question regarding the holes for the extra spk's , I should have made it clear that the speaker cloth had to be replaced .
I have fitted an input socket / pre amp ,to enable me to play my cassette /Dab radio/blue tooth through it . Mick. |
