Old 22nd Apr 2020, 12:38 pm   #1
Outrun_uk
Default Curly cable restoration
Hi all,
Today decided to dig out an old computer which surprisingly worked on bootup, however the curly keyboard cable was stretched and has lost it’s “memory”.
Wrapped it around some dowel and immersed it into some boiling water. Going to let it cool and then will post the results later.
Kev
ID:	203694   Click image for larger version
ID:	203695   Click image for larger version
Outrun_uk is offline
Old 22nd Apr 2020, 4:46 pm   #2
Outrun_uk
Default Re: Curly cable restoration
...and the end result. The cable isn’t as springy as it would have been new but it’s a big improvement on how it was. Maybe another soak or direct heat from a hot air gun would improve it but I don’t want to take the risk as this keyboard is quite rare.
Kev
Old 22nd Apr 2020, 9:41 pm   #3
Tyso_Bl
Tyso_Bl's Avatar
What sort of keyboard is that, I've a B&W IBM keyboard about 15+years, not sure, find the black is reall good on the eyes.
Adapt, Improvise, Oh Bother.....
Tyso_Bl is offline
Old 22nd Apr 2020, 9:45 pm   #4
Dave Moll
Dave Moll's Avatar
Thanks for the tip. I might try it on a few telephone curly cords that have become rather out-of-shape.
Dave Moll is offline
Old 22nd Apr 2020, 10:23 pm   #5
ajgriff
ajgriff's Avatar
I've done this a good few times with curly telephone cords. Never used dowels but just dropped the entire cord into a pan of boiling water for a couple minutes. Any kinks or twists need to be removed first by runnng the cord through finger and thumb with a tight grip. Seems brutal but has always been successful. Good opportunity to clean off accumulated grime before boiling as well. Cords come up like new.
Alan
ajgriff is offline
Old 22nd Apr 2020, 10:25 pm   #6
Alistair D
Alistair D's Avatar
Kev
I usually use a powerful hairdryer for this. As well as the hairdryer I use a semi circular piece of metal held behind the coiled cable. That way the heat is distributed to all surfaces of the coil at the same time.
As a suggestion, a baked bean can cut down the middle should work OK.
Al
I won't tell you how I discovered that.
Alistair D is offline
Old 22nd Apr 2020, 10:52 pm   #7
Outrun_uk
The keyboard is from a Commodore CDTV which is an Amiga variant, one of ghe first attempts at a mass market multimedia system.
Old 22nd Apr 2020, 10:54 pm   #8
Outrun_uk
Kev
Al
I have a hotair gun at work that has a curved attachment, great for heat shrinking. May try it on something sacrificial but as for this one I’m happy enough with the results and don’t want to push my luck!
Old 23rd Apr 2020, 12:53 am   #9
Kyle__B
Rare thing that, A CDTV keyboard that hasn't had all it's keys pinched by a 1200 owner going through a goth phase. I wish it and you many years of safety.
Kyle__B is offline
Old 23rd Apr 2020, 1:37 pm   #10
ThePillenwerfer
ThePillenwerfer's Avatar
I wrap telephone cords 'round a ½" steel bar with the idea that will hold heat and warm it up from the inside as well. I then pour a kettleful of boiling water over it before running it under the cold tap. It's also a good chance to clean the cord with a soapy nail-brush.
Pictures can be seen here.
ThePillenwerfer is offline
