Old 26th Jan 2004, 4:10 am   #1
jsel84
Default IF cans in vintage tube radios 455??
Just a quick question on the IF cans in vintage tube radios
Were they all tuned to 455KC.
I was re-tuning a GE tube radio and it was very close to 450Kc
I was thinking maybe it was made that way.
I heard that the IF cans are tuned too 455. Is this true for all radios in order for them to work correctly.
Thanks for any advise on this subject
Jim
jsel84 is offline
Old 26th Jan 2004, 6:03 am   #2
Norm_Leal
Default Re: IF cans in vintage tube radios 455??
Hi Jim
No they were not all tuned to 455Kc. Older radios used 175Kc & 256Kc. Later radios used 455, 456, 465Kc and other similar frequencies. Use a frequency that gives the best tracking across the dial.
Norm
Norm_Leal is offline
Old 30th Jan 2004, 10:19 am   #3
jsel84
Thanks Norm
" Use a frequency that gives the best tracking across the dial. "
can you expand on this a little
jsel84 is offline
Old 30th Jan 2004, 4:35 pm   #4
Norm_Leal
Hi
Schematics call out frequencies around 455Kc. It doesn't always give the best tracking. Sometimes a slightly different IF frequency is better.
A radio oscillator operates the IF Frequency above a received signal. The higher the oscillator frequency the less capacity change required to cover a range of frequencies.
If IF is set high so is the oscillator frequency. This compresses the stations closer together on the dial. A low IF Frequency cause stations to be farther apart. By adjusting the IF & oscillator frequency you may get better tracking?
Norm
Old 31st Jan 2004, 10:45 am   #5
jsel84
Thanks for the advise. Will try it on some older radios I have.
Keep you posted
jim
jsel84 is offline
