Old 24th Feb 2021, 9:58 am   #1
terrybull
Default Panasonic cf-27 problem.
Although I’m by no means an expert I can usually sort most pc issues out but this has me baffled.
When I boot this early Toughbook laptop it displays the message ‘save to disc feature disabled’. This is immediate, before any attempted boot. In the bios the primary master listing reads ‘none’ and when you scroll down to it, it skips over the hdd entryso you cannot select it. I suppose that’s because it doesn’t see one. A blank hdd results in a message operating system not found and changing to a known good hdd with a Linux operating system that works on my other cf-27, it boots into it but doesn’t work properly and freezes. There is no bios password so it’s not locked. I’ve played with the bios settings but the same error appears. I suspect a motherboard or bios fault. Any thoughts please. I might try and flash the bios if I can find a file.
terrybull is offline
Old 24th Feb 2021, 10:15 am   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: Panasonic cf-27 problem.
CMOS backup battery?
Nickthedentist is online now
Old 24th Feb 2021, 1:47 pm   #3
terrybull
That seems okay Nick and the ram is good too.
Old 27th Feb 2021, 4:31 pm   #4
John123
Is this of any use? Different make/ model, I know..
Regards,
John
John123 is offline
