28th Feb 2021, 11:43 am | #21 |
Re: Reading PROMs with a Raspberry Pi
I presume these are the 0.64mm dia pins, designed to go into turned-pin sockets, so would be quite wobbly in breadboard if thinner than the average resistor lead. So the 0.64mm sides square pins would be a better fit (and also likely to provide two-sides of contact, rather than a single point, with round-pins).
Although it may also depend on quality / how well used the breadboard is, as may well suffer the problem of forcing too-large square-pins into IC sockets, which meant they wouldn't then work very-well with IC's (recently replaced one on a BBC Micro board, as ROM would fall out, without being taped down, it was that loose. So probably was one of the main faults with it). Breadboard could often be rather intermittent, but you could often take the bottom off, and remove the contact strips to compress them back again / remove the bit of wire snapped off stuck in them!) |
28th Feb 2021, 3:51 pm | #22 |
The 'Arduino jumper leads' which are widely available are primarily meant to go into the SIL sockets which are universally fitted to Arduino boards although they are rarely as snug a fit in there as I would like, and mostly a very slack fit in the average breadboard receptacle.
The 'Dupont' type, characterised by having 'hard' square connector bodies rather than rubbery round ones, are a much better friction fit in the two breadboards I have here so maybe they would be OK for the kind of breadboard lash-up I went for in my first round of experimentation. The project was really aimed at people who only have one PROM or set of PROMs to read, and who only need to be able to do it once. |
1st Mar 2021, 10:40 pm | #23 | |
You're not wrong about the jumpers. There's nothing worse than trying to do something for the first time with the wrong equipment - I really had no idea where to even start looking.
Buy cheap, you buy twice. Colin. Quote:
2nd Mar 2021, 1:10 am | #24 | |
Turns out there is some sort of problem with pins 28 (used for D0) and 31 (used for D4) on my Elegoo-branded Mega clone. It's never been hit with anything higher than 5V but those two pins are definitely out of order, they don't see a logic 1 input even when internal pullups are enabled and nothing else is connected. Annoying. Would I be having this problem if the board had been bought from Arduino? Hard to say. In theory the circuit and parts are exactly the same. Last edited by SiriusHardware; 2nd Mar 2021 at 1:17 am. |
2nd Mar 2021, 2:14 am | #25 |
Oops, I owe Elegoo a grovelling apology. Nothing wrong with the board. I took it into my head to edit the hex character lookup table because I prefer my hex to be in upper case, and somehow managed to introduce an extra character.
Code:
const char hex[]= {'0','1','2','3','4','5','6','7', '8','8','9','A','B','C','D','E','F'}; I finally twigged that although some (and only some) of the digits - sometimes the low nibble and sometimes the high nibble, sometimes both, were bizarrely offset by minus one, the checksum was always being displayed correctly - so the code had to be reading the PROM and adding the data up correctly, but not displaying it correctly. Doh! |
2nd Mar 2021, 9:42 pm | #26 |
Now that I have unbroken it, here (attached) is a slightly modified version of the Arduino Mega PROM reader sketch by OddBloke / Modified by OlivierM originally found by Slothie here:-
https://victorengineeringreloaded.wo...re-extraction/ I've added calculation and display of the 16-bit (summed) checksum, and I have also added a small function to always display 16-bit values as 4 hex digits, with leading zeros if needed. The Arduino... Code:
Serial.print(value,HEX) |
