12th Oct 2020, 1:33 pm | #221 |
Re: Bodges
Funny you mention Arcs, Craig.
My late father was an industrial electrician for many years, and regularly worked on high voltage infrastructure. He was a very sensible man, and always took H&S very seriously. He did have one mishap however, which was caused by a combo of incorrect information being provided by a colleague, and as he did in those days, working very long hours. He went into a high voltage substation or switching room to investigate a fault at night, possibly a tap change problem, I cant recall the technical detail now. It wasn't supposed to be live, but it was. The arc and flash that occurred before him was enough to cause severe pain in his eyes, and temporary sight problems. He was VERY lucky, but still ended up in hospital all night, and it took some time for his eyes to return to normal after that incident. The funny part of this is when it happened, he immediately took off his hard hat and threw it down in anger. A colleague came in quickly after and said: "Thank God! You're Alive!! I saw a huge flash, heard a big bang, and then I see your hard hat rolling out the door!" |
12th Oct 2020, 2:15 pm | #222 |
Re: Bodges
At Plessey's the labs had wall sockets for a 400Hz 120V 3 phase supply for powering avionics equipment. The supply was obtained from a motor-generator set in an outbuilding, and was only run up when needed, which was not very often at the time I was working there. On one occasion it seems that the circuit breaker kept tripping when the engineer attempted to start it. Rather than investigate the reason, he wired it closed, resulting in smoke issuing from behind the metal partion in the lab where the short circuit was located!
12th Oct 2020, 2:22 pm | #223 |
Re: Bodges
No doubt, the colleague was mightily relieved that said hard hat didn't roll out with a head still inside it.
12th Oct 2020, 3:21 pm | #224 | |
Re: Bodges
andydoz.blogspot.com |
12th Oct 2020, 3:45 pm | #225 | |
Re: Bodges
Did the CO2 laser work? Martin
BVWS Member |
12th Oct 2020, 4:09 pm | #226 | |
Re: Bodges
Probably the best inspection on devices that haven't fully failed, is to look for bulged electrolytics. The primary electrolytics in switching power supplies, the secundary electrolytics in conventional supplies. |
12th Oct 2020, 4:15 pm | #227 |
Re: Bodges
Too true Maarten,sometimes the eyes are the best test equipment.
14th Oct 2020, 3:45 pm | #228 |
Re: Bodges
It's taken me a while to find the picture but the talk further back in the thread about badly wired mains plugs reminded me of the best one I've found on something I bought.
And, yes, obviously the item in question should also have had a 3A fuse fitted! |
14th Oct 2020, 4:09 pm | #229 |
Re: Bodges
Bodgers normally fit 13 amp fuses in order to be sure of a good audio output when it goes bang.
14th Oct 2020, 6:36 pm | #230 |
Re: Bodges
Crossing-over blue-and-brown doesn't really matter that much to me in the case of 2-core flex, specially when the 'thing' at the other end probably has a polarity-agnostic figure-of-8 2-pin 'cassette-lead' input anyway.
I grew up dealing with loads of things like table-lamps that had 2-core single-insulated twisted-pair power leads and single-pole switches in the lamp-fitting. Most-of-the-world doesn't fret about reversibility/polarity of 2-core power-leads and they don't seem to be getting-electrocuted at a spectacular rate. |
14th Oct 2020, 6:50 pm | #231 |
Re: Bodges
It didn’t. It had a hardwired mains lead and only a single pole power switch on the Live conductor, so definitely a bad idea.
14th Oct 2020, 6:54 pm | #232 | |
Re: Bodges
He was asked why so many bulbs and his answer was because it was very unlikely that all of them would be blown at the same time. Pretty sensible, I thought. |
14th Oct 2020, 7:02 pm | #233 | |
Re: Bodges
And yes it worked. If you want a little light (!) bedtime reading https://eprints.soton.ac.uk/393635/1/82032212.pdf I'd ditched the CO2 idea by that time though. Craog |
14th Oct 2020, 8:17 pm | #234 | ||
Re: Bodges
14th Oct 2020, 10:13 pm | #235 |
Re: Bodges
Presumably, they would have been a combination of series and parallel.
If they used, say, six in parallel - in series with a second six - that would serve for the +440V to earth. The -220V could then be checked across one set by having a centre tap. The parallel subsets would still provide that protection against a failed bulb.
15th Oct 2020, 10:05 am | #236 |
Re: Bodges
There was an old adage concerning the wiring of 15-amp mains plugs, which broadly said that, as long as the green wire went to Earth, the red and black could go either way.
Every time I mention this today, I get howls of disbelief; yet it is exactly the principle of the much-vaunted Shuko plug! |
15th Oct 2020, 6:24 pm | #237 | |
Re: Bodges
15th Oct 2020, 6:40 pm | #238 | |
Re: Bodges
With the TN-C-S and TN-S systems in use nowadays, Schuko sockets are fed by three conductors, in a TN-C-S sytem the earth (CPC) is often connected to the incoming neutral at the consumer unit, not necessarily at the DNO's service head as in the UK. There is however no steadfast rule on the polarity of Schuko sockets.
Eddie BVWS Member. Friend of the BVWTM |
16th Oct 2020, 3:15 am | #239 |
Re: Bodges
This old plug looks like it has been wired up by a vegetable.
16th Oct 2020, 6:51 am | #240 |
Re: Bodges
Perhaps somebody read the instructions where it said, This appliance must be earthed.....
