Old 3rd May 2021, 5:42 pm   #1
onewatt
onewatt's Avatar
Default Early EPROM programmer. (Softy 2)
Hi All,
As per the heading.
Is this just an early programmer?
Vy bst
Chris
BVWS, VMARS, RSGB, DEHS, RAOTA
Nothings too big or too heavy, otherwise it wouldn't be where it is!
onewatt is offline
Old 3rd May 2021, 5:56 pm   #2
TonyDuell
Default Re: Early Eprom programmer.
Isn't that a Softy-2?
TonyDuell is offline
Old 3rd May 2021, 6:26 pm   #3
ortek_service
ortek_service's Avatar
Yes, It does look very-much like the Softy-2, here:
http://www.computermuseum.org.uk/mac...n_softy_2.html
https://www.worthpoint.com/worthoped...mmer-307527523
Although the Keypad looks to be slightly-different and Dataman seemed to usually use White vacuum-formed plastic covers / casing.
So maybe an early prototype / was a rebadge sold under a different name?
ortek_service is offline
Old 3rd May 2021, 7:31 pm   #4
Timbucus
Fascinating - it does look like the Softy-2 - I assume the clips will need to be removed really carefully to look inside but, I would hope to find an SC/MP and some lost firmware....
Is this a machine you currently have?
Timbucus is offline
Old 3rd May 2021, 7:58 pm   #5
ortek_service
Although with the Softy (1 & 2?), you can transfer its firmware to RAM to view / program another 2716 etc from. Which can then readout via a PC-based one etc. - Assuming it works (at least these don't require as complex a Power-Supply as the original Softy-I, as they only work with single-rail EPROM's).
There was some (quite-rare) pictures 'under the hood' of the Softy-2, on another Softy (1) thread, about reading-out its firmware (+ the building of a Replica by ChrisOddy) in this Zip file: https://www.vintage-radio.net/forum/...4&d=1610220783
(from: https://www.vintage-radio.net/forum/...=167741&page=5 )
The Softy-2 does appear to be very-much based on the original Softy-1 (mostly a different form-factor layout, twice the RAM, and supporting larger - single-rail only EPROM's). And uses the same SC/MP CPU with it's 4K memory page limitations
- Before they finally ditched that on the S3, for a full 64K-addressing low-power Z80 uC with custom-ROM
So circuitry is quite similar, but I don't think there's a copy of the circuit or the firmware on the 'net, as very little published info on it (There was / plus is now a lot more on the Softy-1)
Old 3rd May 2021, 9:55 pm   #6
onewatt
onewatt's Avatar
Hi All,
Thank you for the rapid response. Yes, I picked it up with a few other eprom & eeprom surplus gear, so really interesting links and info.
I will see if I can remove the top and take another pic to confirm the insides.
Thanks again, much appreciated.
Vy Bst
Chris
onewatt is offline
Old 3rd May 2021, 10:04 pm   #7
Slothie
The PCB even has the "S4.1" marking of the one in the first of ORTEK's links, so I'd guess a prototype or revised version.
Slothie is offline
Old 4th May 2021, 12:01 am   #8
SiriusHardware
Onewatt, I don't know if you can hear that sound.... it's the sound of everyone here barely containing their excitement at someone having turned up here with one of these units. Expect to be asked lots of questions later...
SiriusHardware is offline
Old 4th May 2021, 9:15 am   #9
onewatt
onewatt's Avatar
Hi SiriusHardware
It’s an integral part of this super forum to find interesting things and share them, but my knowledge is limited, so Let’s hope I can answer the questions.
I’ll forward an internal pic later today, and may get another visit to where it came from and just might if I’m lucky find some paperwork (at least I’ll give it a go)
Vy Bst
Chris
onewatt is offline
Old 4th May 2021, 11:20 am   #10
Timbucus
Default Re: Early EPROM programmer.
Thanks onewatt for following up - the other integral part is how everyone chips in to answer the questions when presented with scraps of information so we can all learn - photos like you will take are devoured to create knowledge. It is that aspect of archeology here I love, as information is readily available on the wider net for so much but, here you realise what is missing and could be lost if we do not preserve it.
Timbucus is offline
Old 4th May 2021, 3:22 pm   #11
onewatt
onewatt's Avatar
And a picture of the insides!
onewatt is offline
Old 4th May 2021, 3:38 pm   #12
Slothie
That's in excellent condition.
Slothie is offline
Old 4th May 2021, 4:23 pm   #13
Timbucus
Yes it is in good condition, although would it be possible to get a hi-res copy as the reduction on the forum is difficult to see the chips.
By the way the Black case may not have been a one off - the Ad from PCW Oct 1981 shows it in Black...
Timbucus is offline
Old 4th May 2021, 4:44 pm   #14
Mark1960
In a black and white advert?
But now we also need to add Menta to the list of machines to find out about, I don’t remember ever seeing that one before.
Mark1960 is offline
Old 4th May 2021, 5:02 pm   #15
Timbucus
This is not a case of "For those watching in Black and White the Red ball is the one behind the Green"...
I knew that would start a conversation and indeed the Menta seems to be in a solid Black case as well... I would stake a bet we don't find many of those unless some of the schools up north testing them kept one!
Timbucus is offline
Old 4th May 2021, 5:35 pm   #16
SiriusHardware
Rephrased for onewatt: Would you please place your original full sized photo from #11 in a .zip file and attach it to a post? The forum crunches all attached images down to 800 * 600 no matter how large the original was, which leads to loss of detail. You can get around that problem by attaching the original as a .zip file.
It certainly looks in beautiful condition. Of particular interest are the EPROM and the labelled smaller IC up in the upper left quadrant - that is likely to be a programmed bipolar PROM which looks as though it is soldered to the PCB.
Old 4th May 2021, 9:05 pm   #17
onewatt
onewatt's Avatar
Did that work?
Chris
....your making my brain work.....!
onewatt is offline
Old 4th May 2021, 10:01 pm   #18
Slothie
Originally Posted by onewatt View Post
Did that work?
Chris
That's brilliant, so Hi-res you can almost smell it!
Slothie is offline
Old 4th May 2021, 10:03 pm   #19
Mark1960
Looks really good quality picture
Mark1960 is offline
Old 4th May 2021, 10:28 pm   #20
Timbucus
Wow - I had to open it in GIMP - that really is Hires!
Timbucus is offline
