11th Feb 2020, 10:08 pm | #1 |
Phone batteries
Hi all
Thought I had a great idea to use redundant lithium ion Mobile phone batteries to power my vintage radio valve heaters, via a regulator of course, question is will the battery have to be in a phone to charge it or Can i connect it to a phone wall charger directly or is there something in the phone that is part of the charging process, I think there is a thermistor in the battery on the third terminal to monitor temperature but that can't control the simple two terminal wall charger,if I do it direct am I likely to loose a few fingers,any ideas .keith. |
11th Feb 2020, 10:55 pm | #2 |
Re: Phone batteries
It needs a stabilised current limited voltage to charge. 4.0 to 4.1V (in no case higher than 4.2V) and limited to about 1/5C just to be safe.
12th Feb 2020, 8:37 am | #3 | |
Re: Phone batteries
Peter |
12th Feb 2020, 12:11 pm | #4 |
Re: Phone batteries
Standard mobile phone batteries are just a single lithium cell and can be charged by a charge controller chip using two connections. You can buy charge controller modules from Chinese eBay sellers for pennies which work with a standard 5V USB charger.
e.g. https://www.ebay.co.uk/itm/2PCS-TP40...e/202851920328 I use such a module to charge scavenged 18650 cells which I use to power workaday radios. |
