10th Feb 2020, 10:42 pm | #1 |
What were Transfilters?
Hi all,
I've just remembered something I'd forgotten all about. In ( I think )Practical Wireless, in 1967, was a project to build a "Transfilter Portable". What were they? An IFT with an inbuilt filter? Cheers Aub
10th Feb 2020, 10:47 pm | #2 |
Re: What were Transfilters?
I have a vague memory that they were ceramic filters that could be used in place of tuned IF transformers - could be wrong though.
10th Feb 2020, 10:52 pm | #3 |
Ah ok. Thanks. That sounds likely.
Cheers Aub
11th Feb 2020, 12:46 am | #4 |
They were early piezo-acoustic ceramic filters made by Brush-Clevite. I think it was their brand-name. Makes them sound a bit grander than they were. Toko and Murata took over the market.
11th Feb 2020, 1:32 am | #5 |
Frank |
11th Feb 2020, 9:33 am | #6 |
Thanks Frank. I wondered if someone would do that. Love those plastic covered batteries.
Aub
11th Feb 2020, 10:14 am | #7 |
They improved selectivity by using a bypass filter in the emitter circuit of an IF amp instead of just a capacitor. I understand how that works, just never thought about it before. Or if I have seen it I have forgotten all about it which is very possible.
Frank |
11th Feb 2020, 3:32 pm | #8 |
There were at least two styles of 'Transfilter' - one was a 2-terminal device which replaced the normal emitter-resistor-bypass-capacitor. The idea being that at the series-resonant frequency of the transfilter the emitter was essentially grounded at the intermediate frequency so gicing good gain, but at other frequencies when the Transfilter wasn't resonant the gain of the transistor was reduced by the degenerative-feedback from the emitter resistor.
The other type was a 3-terminal device used as a replacement for the 'traditional' IFT between the collector of an IF amp and the base of the next-amp-in-the-chain. Their big selling-point to the receiver-manufacturers was that - unlike wound-component IFTs, there was no alignment needed, so cutting production-costs. Several Heathkit receivers of the 1960s used them. Attached is a section of the schematic for the GC1-A "Mohican' that shows both the inter-stage-coupling Transfilters and the emitter-resistor-bypass variety. |
11th Feb 2020, 4:14 pm | #9 |
Those three-terminal filters wiere used by Blaupunkt (and possibly others) in car radios both at AM and FM(VHF). They were made in 455, 460, 465, and 470kHz versions for AM, and nominally 10.7Mhz (which could be between, IIRC 10.65 & 10.75Mhz) for VHF. If replacing a ceramic filter (They did fail occasionally), obviously one of the correct frequency had to be used.. I may still have some somewhere)
11th Feb 2020, 5:32 pm | #10 |
Yes, here's some pictures of one I repaired from a Mohican - it had become 'intermittent' and responded to cleaning of the disc and contacts with IPA then reassembly with the disc rotated by 90°.
Andy
G-QRP #12697 |
