4th Mar 2012, 1:19 am | #1 |
1975 Hitachi SDT -2690R Record Player, speaker troubles
I recently inherited this awesome piece of equipment, it hasn't been played for about 5 years but hadn't been moved either until recently. Unfortunately I didn't inherit the manual and have absolutely no idea how to attach the speakers
Please help... |
4th Mar 2012, 1:38 am | #2 |
Re: 1975 Hitachi SDT -2690R Record Player, speaker troubles
Has it not got a row of those little sprung wire clamps with coloured toggles on its rear? If so there'll be two per channel; you just lift the toggles, insert the bare-ended 'speaker wires and flip the toggles down again. I'm not familiar with the 2690R though and I think some Hitachi efforts used a DIN type 'speaker connection. If this post doesn't help, or other members can't, post a picture of the rear of the machine and we can then soon tell you. |
4th Mar 2012, 3:20 am | #3 |
Darren,
The cords themselves have a two-prong head that fits into the back of the record player, but it's the end to the speakers I'm having trouble with. They're just split copper wire (about 12 tiny wires in each) and at the speaker is two holes (horizontally) with screws in them. How is this supposed to go in? |
4th Mar 2012, 3:32 am | #4 |
I've done some research and it's a female 2 pin DIN socket and a male 2 pin DIN cord with just exposed copper wire at the end of the cord. How do I fit this into two holes in a speaker?
4th Mar 2012, 10:00 am | #5 |
I think the speaker sockets are the DIN type ,you can get the plugs either solder or screw type.
Try Ebay there are loads on there both types. Last edited by vinrads; 4th Mar 2012 at 10:06 am. |
4th Mar 2012, 10:39 am | #6 |
Whatever type of connections are used, it's important that the two speakers are connected in phase. The leads should be colour coded with a red and black core or a tracer colour. Both speakers must be connected the same way round otherwise the bass will be lacking and the stereo "image" will be absent. Apologies if I'm stating the obvious. If your not sure, you can reverse the connection to ONE of the speakers and see which sounds best. If you use a mono record or radio station, the sound will appear to come from a point mid way between the speakers when they're correctly phased. Hope this helps, Cheers, Pete
"Hello?, Yes, I'm on the train, I might lose the signal soon as we're just going into a tunn..." Last edited by Tractorfan; 4th Mar 2012 at 10:43 am. Reason: More info. |
