Old 1st Dec 2011, 2:18 pm   #1
musonick
Default 'Underwater' sound from valved amp.
Very quick question. Am I correct in thinking that an 'underwater' ripple sound on a valve amp is likely to be caused bad electrolytic smoothing caps?
Thanks,
Nick.
musonick is offline
Old 1st Dec 2011, 4:00 pm   #2
Station X
Station X's Avatar
Default Re: 'underwater' sound
I wouldn't think so. Bad smoothing capacitors give rise to a loud low pitched hum, which is unmistakable.
You problem is more likely down to leaky paper dielectric capacitors, dirty switch contacts, dirty valve pins or dirty potentiometer tracks.
Graham. Forum Moderator
Station X is offline
Old 1st Dec 2011, 9:34 pm   #3
Michael Maurice
Michael Maurice's Avatar
Default Re: 'Underwater' sound from valved amp.
Sounds like motorboating or instability.
Michael Maurice is online now
Old 1st Dec 2011, 9:43 pm   #4
ms660
ms660's Avatar
He could be trying to describe hum....induced before the volume control and modulating the signal. Maybe the poster can be a little more specific of the symptons.
Lawrence
ms660 is offline
Old 1st Dec 2011, 10:31 pm   #5
Station X
Station X's Avatar
"Under water ripple sound" could be many things, but I don't think hum is one of them.
Old 1st Dec 2011, 10:37 pm   #6
maninashed
Not quite sure what underwater sound means, but it may be that one of the pre-amp valves has gone microphonic causing hollow sound. More information would help.
Bill
maninashed is offline
Old 1st Dec 2011, 10:50 pm   #7
ms660
ms660's Avatar
It might or might not be in this case but a hum modulated signal can sound remarkably like someone having a gargle underwater in many instances...hum modulation in a Freq Changer/Mixer for instance or a signal level dropping to a level which is approaching the level of any residual hum in a circuit. Like I said in my previous post, more information from the poster might give us a better idea.
Lawrence.
ms660 is offline
Old 2nd Dec 2011, 12:27 am   #8
musonick
hi, the signal modulates. there is no hum
musonick is offline
Old 2nd Dec 2011, 1:30 am   #9
Station X
Station X's Avatar
What is being modulated by what?
Old 2nd Dec 2011, 2:51 am   #10
Amraduk
Hello Nick,
Can you make a short recording of the effect and post it on the forum as an MP3 file?
Regards,
Dave.
Amraduk is offline
Old 2nd Dec 2011, 5:36 am   #11
musonick
Hi, it's probably too subtle to do a recording but it's 'there'. It's the actual audio signal fluctuating.
musonick is offline
Old 2nd Dec 2011, 5:43 am   #12
mrmagnetophon
Push pull amp? Give me technical aspects, and i'll attempt to give you the things causing the problem/
-Chris
mrmagnetophon is offline
Old 2nd Dec 2011, 7:55 am   #13
crackle
It would be useful to know the make and model, it's not an Ashdown by any chance?
crackle is offline
Old 2nd Dec 2011, 9:47 am   #14
Andy Doz
Andy Doz's Avatar
Motorboating?
Andy Doz is offline
Old 2nd Dec 2011, 11:47 am   #15
SeanStevens
SeanStevens's Avatar
Is this valve amp a guitar amp or audio amp?
If it is a guitar amp it might have a tremelo (effect)
SEAN
There are only 10 types of people, those who understand the binary system, and those who don't.
SeanStevens is offline
Old 2nd Dec 2011, 3:25 pm   #16
PJL
Maybe it's because you are up at 4:36AM?
I would stop using it as it could be signs of a fault that could cause damage. Let's have a model number and pics.
PJL is offline
Old 2nd Dec 2011, 8:17 pm   #17
ITAM805
ITAM805's Avatar
Does it sound like this?
ITAM805 is offline
Old 2nd Dec 2011, 10:53 pm   #18
musonick
Cheers Mick jokes aside, it does sound a bit like that but not as exagerated.
Amp details here P.30
http://thearcadeboneyard.com/Jukebox...0Combined).pdf
Moderator's note. Warning - if you have a slow internet connection you might want to be aware that this file is 28M and will take forever to load.
Last edited by Brian R Pateman; 3rd Dec 2011 at 10:01 am. Reason: Moderator's note added.
musonick is offline
Old 3rd Dec 2011, 12:22 am   #19
PJL
Has the amp been restored recently? If not I would want to give it a full health check:
- Test output valve grids are 0V (leaky audio coupling capacitors)
- Check individual anode currents as it uses shared cathode bias arrangement
- Check voltages against schematic
As it's stereo, the obvious question is does it do the same on both channels? are the noises present when there is no input or is it just distortion of the sound? does the amount of distortion change with increased volume?
PJL is offline
Old 3rd Dec 2011, 7:44 pm   #20
musonick
hi, yes the sound is on both channels and it is only apparent with audio input. i have ordered a cap kit and will do the necessaries.
thanks, nick
musonick is offline
