Old 13th Nov 2012, 5:23 pm   #81
julie_m
Default Re: BSR record player deck identification.
Originally Posted by Jimmyhaflinger View Post
The BSR decks automatically disengage the idler wheel whenever the function lever is in the off position instead.
Since the UA12, they have. Earlier ones had a "neutral" position on the speed change knob, which disengaged the idler, and you had to remember to turn the speed changer to "N" after listening.
julie_m is offline   Reply With Quote
Old 13th Nov 2012, 8:56 pm   #82
Nickthedentist
Nickthedentist's Avatar
I think the UA6 doesn't even have a "neutral" position at all, though the UA8 does.
N.
Old 20th Nov 2012, 8:51 pm   #83
Jimmyhaflinger
Jimmyhaflinger's Avatar
Here's the BSR C123 deck fitted in my Sanyo music centre
Jimmyhaflinger is offline   Reply With Quote
Old 6th Dec 2012, 10:06 am   #84
Ekcoman
Ekcoman's Avatar
Default Re: BSR Record Player Decks
Originally Posted by Tom_I View Post
That will be the UA12, introduced before the UA14, and intended as a 'de luxe' alternative to the UA8 for use in more expensive items like radiograms.
Was there two versions? One had a cut away end to arm for barrell roll cart while another had a blocked off for flip over.
"I really am seriously downsizing "
Ekcoman is offline   Reply With Quote
Old 15th Dec 2012, 11:24 am   #85
Jimmyhaflinger
c198 deck from 1979
ID:	73962   Click image for larger version
Old 15th Dec 2012, 11:31 am   #86
Jimmyhaflinger
C123 deck from a 1977 Sanyo JXT-4404 music centre.
The deck in my 1972 Sanyo G-2601KCA music centre is also a C123 but looks completely different
ID:	73964   Click image for larger version
ID:	73965   Click image for larger version
Old 26th Dec 2012, 7:05 pm   #87
Refugee
Refugee's Avatar
Some P182 pictures.
ID:	74342   Click image for larger version
ID:	74343   Click image for larger version
Refugee is offline   Reply With Quote
Old 20th Jan 2013, 4:42 pm   #88
custardpot
Some Pictures of BSR C123R2-C-6 Turntable in a Ferguson 34574.
Christine
Name:	Ferguson 34574 picture 3.jpg
ID:	75197   Click image for larger version
Name:	Under turntable 2.jpg
ID:	75198   Click image for larger version
ID:	75199   Click image for larger version
ID:	75200   Click image for larger version
Name:	red label.jpg
custardpot is offline   Reply With Quote
Old 13th Mar 2013, 8:33 am   #89
Ekcoman
Ekcoman's Avatar
Just wondered if anyone could put any dates to these decks? Especially curious about those early one from UA6-UA16.
Old 18th Mar 2013, 12:44 am   #90
Fidelity Fan
UA8 circa 1958-9.
UA14 circa 1961.
UA16 circa 1964-65.
UA25 1965 -1968.
Fidelity Fan is offline   Reply With Quote
Old 17th Jun 2013, 10:29 pm   #91
Ekcoman
Ekcoman's Avatar
Another one not yet mentioned is the UA25, very common in cheaper record players in the mid 60s. Maybe someone has a better picture?
It's strange as have one of these in a Dansette Bermuda (Mk 1 design). The Bermuda originally came with UA14, UA16 but then why UA25? Big jump in numbering but not in years. Happy to be corrected.
Old 18th Jun 2013, 10:25 am   #92
david freeman
The UA25 was a cheaper deck than the UA15/16 series and was really the successor to the UA14.
All the Dansette models which had previously used the UA14, ended up using the UA25 prior to being changed. These included the Bermuda, Conquest Auto, Monarch, Stereophonic A35 and Senator. All of these had used the UA15/16 decks as well just to cause confusion!
The Viva only ever used the UA25, as did the Trent stereophonic which replaced the A35.
david freeman is offline   Reply With Quote
Old 18th Jun 2013, 2:29 pm   #93
ben
ben's Avatar
Originally Posted by david freeman View Post
The UA25 was a cheaper deck than the UA15/16 series and was really the successor to the UA14. .
I suppose the c-109 was in turn the successor to the UA25- 4 speeds, same plastic arm minus the turnover hole.
Name:	bsr UA25small.jpg
ID:	80972   Click image for larger version
ID:	80973   Click image for larger version
Name:	bsr c109 cream.jpg
Ben.
Old 19th Jun 2013, 7:40 am   #94
Ekcoman
Ekcoman's Avatar
I suppose Ben the UA25 at least had a metal turntable but the c-109 went with a plastic one which always became marked when stored with mains cable laying on top. The auto drop record size application had became non automatic and had to be set manually. Not a fan of these late BSR decks but can just about live with the UA25.
Old 28th Jan 2014, 3:45 pm   #95
Merseygull
Hi, anyone got any idea which model this is??
2 off installed in a Hurricane disco console, made by NJD sometime way back when....
They're belt drives, but the (plastic) platters are solid - ie there's no hole to get ny finger through to attach the drive belt to the motor spindle...
Any help?
ATB,J.
Name:	P1050733 (Small).JPG
ID:	88352   Click image for larger version
Name:	P1050731 (Small).JPG
ID:	88353   Click image for larger version
Name:	P1050732 (Small).JPG
Merseygull is offline   Reply With Quote
Old 30th Jan 2014, 9:21 pm   #96
Nickthedentist
Originally Posted by Merseygull View Post
They're belt drives, but the (plastic) platters are solid - ie there's no hole to get ny finger through to attach the drive belt to the motor spindle....
You were meant to remove the platter, fit the belt to the rim on its underside and over a little hook.
You then replace the platter positioned so that the hook is lined-up with the motor pulley, and rotate clockwise. The motor pulley then grabs the belt from the hook, and hey presto, you're threaded up and ready to play! Takes a few tries sometimes though.
Horrid decks though IMHO!
Nick
Old 31st Jan 2014, 12:23 am   #97
ben
ben's Avatar
The dreaded P-267. Fitted cartridge usually by Tetrad.
Ben.
Old 26th Apr 2014, 7:18 am   #98
annefromla
Thanks so much for compiling all of this information on BSR's.
I thought I had a UA15 but the UA15 schematic shows the raising bracket that attaches the idler wheel arm assembly to the raising pillar to be partially above and partially below the chassis (or do you call it the deck?) The raising bracket for my turntable is all below the chassis.
So either it is a UA15 that at some time was altered or its not a UA15 but a different model. Any ideas?
Name:	nadias hack1.jpg
ID:	91997   Click image for larger version
Name:	pivot from below.jpg
ID:	91998   Click image for larger version
Name:	missing spring 53.jpg
ID:	91999   Click image for larger version
ID:	92000   Click image for larger version
Name:	small majestic image.JPG
annefromla is offline   Reply With Quote
Old 27th Apr 2014, 7:11 pm   #99
annefromla
Mystery solved. Found a Symphonic portable player with what I think is a UA14 but it has the same raising bracket assembly. So I just copied it and now I have two working UA somethings.
Old 3rd May 2014, 7:36 am   #100
annefromla
Originally Posted by Audio1950 View Post
After the UA15 comes the UA16, which is identical in appearance, but has a longer spindle, and a higher arm mounting, to enable ten records to be stacked, as against the UA15's six.
The UA15 and UA16 also have a different raising pillar assembly and raising bracket position. The UA16's raising bracket stays completely below deck and attaches to the raising pillar via a spring and R clip. The UA15's raising bracket is partially above deck and does not have a clip holding the raising pillar spring. Here are two details from the schematics.
Name:	ua16 raisingpillar detail.jpg
ID:	92344   Click image for larger version
