21st Mar 2023, 6:52 pm | #21 |
Re: Simon SP5 Hybrid Reel to Reel Tape Recorder Restoration
Yes an interesting yet quirky machine . Simons last gasp which by then, was under Harland Enginering ownership. I have had an SP6 model in the collection for some years and it came to me as a fully factory fitted stereo job from the off so a small number must have come out of the Kendall Place/George Street factory ready to go.
As an aside Major Frank Clarke of Clarke and Smith was a co-patentee of the EMI deck. regards, Terry
Terry Martini-Yates BVWS Committee Vice Chair |
21st Mar 2023, 10:04 pm | #22 | |
Motor capacitors that are often used with some tape recorder capstan motors are not electrolytic and are non polarised. If machine is dual frequency (50/60Hz) then there normally will be 2 run capacitors (typically in the same can). Typically when machine is switched to 50Hz the 2 capacitors are connected in parallel, when switched to 60Hz then only 1 capacitor will be connected in circuit. A good example of this is the Akai 4000DS where the 2 run capacitors are 2uF and 0.5uF, so when switched to 50Hz the parallel combination is 2.5uF, when switched to 60Hz only the 2uF is connected. The 4000DS frequency switching also does a voltage switch, in 50Hz a 100V primary winding tap of the mains transformer is fed to the 2 capacitors and also direct to one of the motor windings. In 60Hz a 120V tap is connected to the 2uF and also direct to one of the motor windings. Of course a change of frequency will normally go hand in hand with a change of mains voltage supply to the mains transformer, i.e. 60Hz would typically be 110-120 volts for USA whereas 50Hz could be 240 volts for UK as one example. David Last edited by DMcMahon; 21st Mar 2023 at 10:14 pm. Reason: Update |
22nd Mar 2023, 8:20 am | #23 | |
22nd Mar 2023, 9:05 am | #24 |
Thanks again to all of you for your information and advice.
Thanks David for clarification of the use of the dual capacitors. Lucien - I will check the date codes as I get the components out but from what I can see all the Hunts capacitors are marked H H H (spaces between each letter). I agree David that the board in the final picture is the power amplifier as the ERT Service Chart lists the 3 boards mounted on the bottom panel as Power Pack Assembly, Oscillator Assembly and Power Amplifier. |
22nd Mar 2023, 9:58 am | #25 |
16th Jun 2023, 11:23 am | #26 |
