Old 10th Nov 2021, 9:42 pm   #1
Stevemor
Default Smiths street Clock which seems to have a stop/start problem.
Not sure if I’m doing this correctly but here goes. I’ve a doubled sided Smiths street Clock which seems to have a stop/start problem. It’s big & heavy around 36” dia but I’d love to get it back up and running smoothly
Stevemor is offline
Old 10th Nov 2021, 10:57 pm   #2
Tractorfan
Tractorfan's Avatar
Smile Re: Smiths street Clock which seems to have a stop/start problem.
Some early electric clocks were not self starting. So, when they were powered up, a knob on the back needed a little push and a spin to set it going.
Hope this helps.
Cheers, Pete.
"Hello?, Yes, I'm on the train, I might lose the signal soon as we're just going into a tunn..."
Tractorfan is offline
Old 11th Nov 2021, 1:13 am   #3
bionicmerlin
bionicmerlin's Avatar
Default Re: Smiths street Clock which seems to have a stop/start problem.
It’s not uncommon for some types of clock to have the the hand time set knob pulled down and let go to start the clock. It was also not uncommon for them to require this done more than once as they could be stubborn. Not sure if this applies to your clock.
If your not technically minded do the motors hum. It could be very quite but it will prove the motors are ok Andy
I bet that car doesn't have a suppressor.
bionicmerlin is offline
Old 11th Nov 2021, 7:49 am   #4
thermionic
thermionic's Avatar
I’ve never considered this before, but how did they adjust the time on these large wall mounted street clocks? Was is a matter of getting up a ladder and adjusting the hands, or was there some mechanism for adjusting remotely?
Regarding the comments above regarding possible manual starting, then I would imagine that having to restart and adjust a large clock with a ladder would be tiresome!
Cheers.
SimonT.
The honesty of imperfection..........
thermionic is offline
Old 11th Nov 2021, 9:20 am   #5
Mike Phelan
Mike Phelan's Avatar
Hi Steve,
Have you a picture of the open movement?
If we see what sort and age it is we can give you much more info. Self-starting clocks only came into being in the 1930's.
Mike.
Mike Phelan is offline
Old 11th Nov 2021, 3:20 pm   #6
Robsradio
Cheers.
SimonT.
Some were slave clocks which were driven by a master inside the building, others had the movement and hand adjuster inside the building with a shaft drive for the hands going through the wall to the dials.
Robsradio is offline
Old 12th Nov 2021, 7:51 am   #7
thermionic
thermionic's Avatar
Thanks Rob, that makes sense. I’m interested to hear more about the OP’s clock now, to see how his unit was adjusted & started.
Thanks.
SimonT.
Old 12th Nov 2021, 10:41 am   #8
Heatercathodeshort
Heatercathodeshort's Avatar
Could it have been as simple as waiting for the correct time that was displayed on the clock and just turning it on? J.
Heatercathodeshort is offline
Old 12th Nov 2021, 1:46 pm   #9
Stevemor
Hi everyone thanks so much for your help and positive input much appreciated. as mentioned previously the clock is a 1960/70s double sided street clock around 30" dia it starts to run with a humming sound and then stops perhaps a good mechanism lubrication is all that needed? have pics but can't see how I can add them can someone please advise..?
Stevemor is offline
Old 12th Nov 2021, 5:20 pm   #10
Graham G3ZVT
Graham G3ZVT's Avatar
Follow (a different) Graham's guide here
Graham.
G3ZVT
Graham G3ZVT is offline
Old 12th Nov 2021, 6:01 pm   #11
thermionic
thermionic's Avatar
John …. 🥴. You may have it nailed! Simple but effective! Although, being a public clock I can image that the inconvenience of having to wait 11 hours to restart the clock when the hour goes forward would be best avoided.
( trying to defend my stupidness!)
Cheers. SimonT.
Old 12th Nov 2021, 8:11 pm   #12
Nickthedentist
Nickthedentist's Avatar
That's certainly the way our huge 1940s Smiths clock on the front of the school hall was set.
Nickthedentist is offline
