Old 28th Jul 2007, 5:28 pm   #1
Brian R Pateman
Brian R Pateman's Avatar
Default Survey of R&TVS
Following in from Station X's idea in this thread
https://vintage-radio.net/forum/showthread.php?t=19242
Who has which versions of this valuable resource?
Eventually I'll pop all the data into a spreadsheet if there's enough to merit it.
I'll start off
I have a red 5 volume set and then separate volumes up to 1974/75.
The publishers are as follows;
Five volume set and year books 1957/58 to 1963/64 are Newnes.
(My 1964/65 has gone missing but I think that was Newnes as well)
1965/66 to 1968/69 Pergamon Press
1969/70 ILSC (International Learning Systems Corporation Ltd)
1970/71 to 1974/75 (the last one I have) Macdonald Publishing.
Over to the rest of you.
Brian
Brian R Pateman is offline
Old 28th Jul 2007, 5:36 pm   #2
ppppenguin
ppppenguin's Avatar
Default Re: Survey of R&TVS
ISTR an article in the BVWS Bulletin a few years ago which gave a good history of the different series of RTVS. It was a confusing history if I remember correctly.
ppppenguin is offline
Old 28th Jul 2007, 5:52 pm   #3
Dave Moll
Dave Moll's Avatar
I have the following:
two-volume set (published 1952)
six-volume set:
1: pre-1953 radios
2: pre-1953 radios (contd.)/televisions
3: pre-1953 televisions (contd.)
4: 1953-54
5: 1955-56
6: 1956-57
30 annual volumes (starting with 1957-58 and ending 1986-87)
index of volumes to 1986 (a copy of which is referenced earlier in this thread)
Publishers:
George Newnes Ltd up to 1965
Pergamon Press Ltd 1965-69
ILSC 1969-70
Macdonald 1970-74
Macdonald and Jane's 1974-79
Macdonald 1979-86
Macdonald Orbis 1986-87
edit: I forgot to mention colour: all maroonish red (although 1980 onwards have blue dust jackets)
and authors:
up to 1959: Malloy & Poole
1959-66: Hawker & Reddihough
1966-70: Harris (asst. Ferrier & Wainwright)
1970-71: Wainwright (asst. Harris)
1971-87: Wainwright
Dave Moll is offline
Old 28th Jul 2007, 6:45 pm   #4
chipp1968
chipp1968's Avatar
my red newnes books vol 1 to 6 . must date to 1960/1 as 1960is covered in the 6th .Being a late run must be why the first one doesnt have receivers like tv12 and tug 12 , but does have tv22
I also have one red volume marked 1959 /60 models this is identical to vol 6 as far as i can see but must be meant to be bought yearly.
I didnt realise i had the 6th volume untill now , thought there was only 5
chipp1968 is offline
Old 28th Jul 2007, 7:04 pm   #5
dave walsh
Will be able to check my northern selection in two or three weeks if you have any enigmas still by then. Dave
dave walsh is offline
Old 28th Jul 2007, 8:25 pm   #6
Paul_RK
Paul_RK's Avatar
Five-volume set here:
1: Pre-1953 radios, Ambassador to K.B.
2: Pre-1953 radios, McCarthy to Vidor.
3: Pre-1953 TV, Alba to K.B.
4: Pre-1953 TV, McMichael to White-Ibbotson
5: 1953-54.
Annual volumes thereafter, starting with 1955-1956, continuous to 1974-1975.
Paul
Paul_RK is offline
Old 29th Jul 2007, 4:17 pm   #7
Brian R Pateman
Thanks to all who have contributed so far - keep them coming!
Dave (M)
Thanks for the note on editors, I'd meant to include that but I forgot.
This could become another of my minor obsessions (no wonder Helen worries about me).
Brian
Old 29th Jul 2007, 4:51 pm   #8
Dave Moll
Dave Moll's Avatar
mine are as follows:
1: radios, Ambassador to Marconiphone
2: radios, Masteradio to Vidor; televisions, Alba to Ferguson
3: televisions, Ferranti to White-Ibbotson
Old 29th Jul 2007, 5:16 pm   #9
ISBNs (International Standard Book Numbers) might be useful, as I believe these identifty a book uniquely. There are certainly different ISBN numbers for hard and soft cover versions of the same book. Probably for each edition and reprint too. Of course early books won't have them. They were introduced in 1970.
Station X is offline
Old 29th Jul 2007, 5:19 pm   #10
Brian R Pateman
Out of interest here is the advert card from a copy of Radio Constructor from 1960 I would think.
The seven volume set was £11.5s or £11.15s on monthly terms.
If you already had the set 1958/59 was 50/- or 52/6 on monthly terms.
Brian
Old 29th Jul 2007, 5:57 pm   #11
Brian R Pateman
OK - the first volume I have with an ISBN is 1970/71 SBN 356 03655 3
Then we have
1972/73 ISBN 0 356 04379 7
1973/74 ISBN 0 356 04916 7
From 1965/66 there is a Library of Congress record number 66-19459. This same number appears until the SBN in 1970/71.
I'm not sure what the significance of the Library of Congress record card is. I was under the impression that it was the US version of the ISBN but as it seems to be the same for all the volumes on my shelf between 1965 and 1970 it is probably of less use.
I will ask Helen - there are some advantages to being married to a retired Chartered Librarian (just don't ask here to stamp your books).
Brian
Old 29th Jul 2007, 6:20 pm   #12
Dave Moll
Dave Moll's Avatar
My findings echo those of Brian, in that the first ISBN is 1972-1973
1971-1972 has an SBN of 356 041112 3
I agree with Brian with regard to 1972-1974
The ISBNs of the subsequent volumes are as follows:
1974-75 0 356 08182 6
1975-76 0 356 08440 x (yes, an "x" rather than a digit!)
1976-77 0 354 04063 4
1977-78 0 354 04196 7
1978-79 0 354 04377 3
1979-80 0 354 04516 4
1980-81 0 354 04725 6
1981-82 0 356 07873 6
1982-83 0 356 09203 8 (£22.50)
1983-84 0 356 10259 9 (£22.50)
1984-85 0 356 10907 0 (£22.50)
1985-86 0 356 12359 6 (£25.00)
1986-87 0 356 14439 9 (£29.50)
As the last five had the price printed on the jacket flap, I have included this for comparison with Brian's prices quoted above for the early volumes. The sharp increases toward the end may have contributed to their demise in 1987. Although I bought the volumes from 1967 onwards new, I no longer have a record of what I paid for the ones prior to 1983.
Old 29th Jul 2007, 6:27 pm   #13
It seems that annual collections WITHOUT a volume number were published from 1955/56 to 1986/87.
There were also VOLUME sets published in various years.
I don't have any of these books, but the volume set held by Suffolk Libraries is as follows:-
Volume 1 Radio Servicing (Part 1) Edward Molloy ISBN GRN00 42251
Volume 2 Radio Servicing (Part 2) Edward Molloy ISBN GRN00 42250
Volume 3 TV Servicing (Part 1) Edward Molloy ISBN GRN00 42249
Volume 4 TV Servicing (Part 2) Edward Molloy ISBN GRN00 42248
Volume 5 1953/54 Models Edward Molloy ISBN GRN00 42159
The ISBNs have rather a strange format and I assume they were allocated retrospectively. I don't know if they're printed in the books.
There appears to have been no 1954/55 book.
Old 29th Jul 2007, 6:51 pm   #14
Dave Moll
Dave Moll's Avatar
As well as numbered volumes as late as 1956-57.
This is borne out by my set having sequential numbers for 1953-54 and 1955-56.
Old 29th Jul 2007, 10:47 pm   #15
Brian R Pateman
Having spoken to Helen, the situation re ISBN is as follows;
In 1970 the system was introduced as SBN (Standard Book Number) and later in 1971 or 1972 was adopted internationally as ISBN.
The ISBN number identifies a particular volume in a series and an edition of that volume (ie a first edition and second edition would have a different ISBN and a hardback a different number from the paperback edition and so on).
The Library of Congress Record number identifies the record card for a title. This explains why the early volumes have the same LofC record number. Thet would locate the card for the title and subsequent year volumes would appear as sub-sets of the same record number.
To quote Helen "I've never understood the US classification system, it's even more complicated than Dewey."
So there you have it!
Brian
Old 30th Jul 2007, 10:06 am   #16
Here's a list of all the ISBNs I've been able to find. As I said in an earlier post ISBNs didn't come into use until 1970, so I'm not sure how the pre 1970 ISBNs are derived.
1954-55 NO BOOK PUBLISHED.
1955-56 GRN 0042 271
1956-57
1957-58
1958-59 GRN 0716 127
1959-60
1960-61
1961-62
1962-63
1963-64
1964-65
1965-66 B 661 9933
1966-67 B 671 8554
1967-68 B 681 6428
1968-69 B 690 8515
1969-70 0 701 40004 8
1970-71 0 356 03655 3
1971-72 0 356 04112 3
1973-74 0 356 04916 7
Old 30th Jul 2007, 5:26 pm   #17
Paul Stenning
Administrator
Paul Stenning's Avatar
Mine were obtained in ones and twos so are not a complete set of one release. I have listed them in date rather than volume number order.
Vol I - Pre 53 part 1 (Radio Ambassador - KB) - Molloy/Poole - 496 pages
Vol II - Pre 53 part 2 (Radio Masteradio - Vidor, TV Alba - Ferguson) - Molloy/Poole - 560 pages
Vol III - Pre 53 part 3 (TV Ferranti - White Ibbotson) - Molloy/Poole - 544 pages
53-54 - Molloy/Poole - 655 pages
Vol II - 55-56 - Hawker - 584 pages
Vol III - 56-57 - Hawker - 624 pages
Vol IV - 57-58 - Hawker - 612 pages
Vol V - 58-59 - Hawker - 640 pages
59-60 - Hawker - 656 pages
60-61 - Hawker - 656 pages
61-62 - Hawker - 656 pages
62-63 - Hawker - 656 pages
63-64 - Hawker - 608 pages
64-65 - Hawker - 584 pages
65-66 - Harris - 496 pages (ILSC)
66-67 - Harris - 494 pages (ILSC)
67-68 - Harris - 527 pages (ILSC)
68-69 - Harris - 607 pages (ILSC)
69-70 - Harris - 679 pages (ILSC)
70-71 - Wainwright/Harris - 736 pages - SBN 356 03655 3 (Macdonald)
71-72 - Wainwright - 736 pages - SBN 356 04112 3 (Macdonald)
All Newnes unless stated otherwise.
ILSC = International Learning Systems Corporation
The number of pages is just the number on the last numbered page - there would be a few more if those before page 1 are counted.
Paul Stenning
Paul Stenning is offline
Old 30th Jul 2007, 5:52 pm   #18
I wonder when the last VOLUME set was published? Chip seems to have a VOLUME set dating from 1961. As the years went on a considerable amount of stuff must have been removed from VOLUME sets to keep them down to a managable size.
Presumably to cover everything you'd need the 1955 five VOLUME set and all the annual books up to 1986/7?
Old 30th Jul 2007, 5:54 pm   #19
Paul Stenning
Administrator
In a similar vein from the same publisher I also have these earlier books:
Radio Engineers' Service Manual - 1952 - Molloy/Poole - 760 pages - dark blue cover - same sort and style of content as R&TVS but with the manufacturers in random order.
Newnes' Complete Wireless volumes 1 to 4 - Molloy/Stranger - not dated but I would guess late 30s, brown covers, less consistent than R&TVS with different authors and manufacturers contributing info. I think these are quite sought after as I paid about £35 in a BVWS auction for them....
Paul Stenning
Old 30th Jul 2007, 6:25 pm   #20
Paul_RK
Paul_RK's Avatar
1932-33, Paul. It was published in 32 weekly parts with an option of having them bound: I just have most of the weekly issues in the form in which they were sold, with decorative covers and advertising matter inside. Part 32 includes an offer of a reduced price for binding Volume IV, 4/9d instead of the usual 5/6d if the parts were sent to the bindery by May 9th 1933.
Paul
Paul_RK is offline
