Old 27th May 2020, 12:51 pm   #1
ben
ben's Avatar
Default LOEWE 5281 TV chassis 110Q23
This, my main set, gave a bright raster with retrace lines upon powerup this morning. Measuring across the RGB o/p stage rectifier on the CRT PCB I'm only getting some 60v. No obvious burnups. Resoldered a few suspicious looking joints to no avail.
I'm working blind here as have no schematic despite a few web searches. The supply voltage appears to be derived from the LOPTmr pin 4, via R547 but it's a crowded board and not that easy to trace. Ring any bells for anyone?
Regards,
Ben.
ben is offline
Old 27th May 2020, 2:21 pm   #2
Maarten
Default Re: LOEWE 5281 TV chassis 110Q23
The rectifier should be on the chassis, as far as I remember Loewe.
The 110Q23 is also called Q2300, maybe this helpsin searching for a schematic.
Does it have a Philips ESF/ERF tube?
Maarten is offline
Old 27th May 2020, 3:37 pm   #3
1955APREN
1955APREN's Avatar
Hi Ben
Can you locate the point were the 200v ( apr) Arrives at the crt base, try tacking a 4.7uf 250v from this point to chassis if this clears the fault look for
oc cap after the diode from the lopts . I might have circuit in my shed I will look after
Regards
Derrick
1955APREN is offline
