Old 15th May 2020, 1:42 pm   #121
Freya
Freya's Avatar
Default Re: Fixing a GEC BT 302 Television
yes
what do you intend to use as a signal source.
Stephen
Freya is offline
Old 15th May 2020, 1:52 pm   #122
deepspacedaz
deepspacedaz's Avatar
I have a free view box,
deepspacedaz is offline
Old 15th May 2020, 2:09 pm   #123
Freya
Freya's Avatar
That will not work on its own, you need a 405 line standards converter to provide the final signal that you plug into the set.
The freeview (which is 625 lines) can be used to supply the video signal to the 405 standards converter
Stephen
Freya is offline
Old 15th May 2020, 3:02 pm   #124
Heatercathodeshort
Heatercathodeshort's Avatar
If you think you have mixed up the valves. Lay them all out on a white cloth and post a picture. I/we can probably identify them. John.
Heatercathodeshort is offline
Old 15th May 2020, 3:04 pm   #125
deepspacedaz
What about a dvd player will that work ?
Old 15th May 2020, 3:05 pm   #126
deepspacedaz
Yes ok i show you the valves.
Old 15th May 2020, 3:06 pm   #127
deepspacedaz
some of the valves have letters numbers it just I don't know where they go
Old 15th May 2020, 3:18 pm   #128
Freya
Freya's Avatar
No, nothing will work without a standards converter
Stephen
Freya is offline
Old 15th May 2020, 3:27 pm   #129
Cobaltblue
Cobaltblue's Avatar
Default Re: Fixing a GEC BT 330 Television
Originally Posted by Colourstar View Post
It's worth mentioning before you dive in to the repair that both your sets work on the old 405 line system, so you'll need a 625 to 405 standards converter to use them with a dvd player etc. Without a converter these sets are purely ornamental. They cost around £200 so it's worth thinking about whether you want to invest in one before you go much further.
Best of luck,
Steve
Yes thank you for the advice I have one, all my money goes into the 1950s furniture etc.
Can you tell me anything by these pictures? where shall I start etc
Right at the beginning Colourstar (Steve) told you you needed a standards converter It seems you may have understood what that was.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 15th May 2020, 3:45 pm   #130
Freya
Freya's Avatar
These will help you with the valve numbers and positions
Stephen
Freya is offline
Old 15th May 2020, 3:51 pm   #131
deepspacedaz
Thanks for the diagram any advice how I can see worn out labels on valves?
Hello yes sorry someone said I can use a free view box a while ago
Old 15th May 2020, 3:57 pm   #132
Cobaltblue
Cobaltblue's Avatar
Sorry but no they didn't
Colourstar told you in post #8 that you needed a 625 to 405 standards converter and they cost around £200
Best of luck,
Steve
Your reply was that you had one.
Post #9
Perhaps you need to read the posts more carefully?
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 15th May 2020, 3:59 pm   #133
Freya
Freya's Avatar
that requires you to lay the valves out on some plain paper and take a picture, write a number under each valve starting with 1 etc so they can be identified.
Stephen
Freya is offline
Old 15th May 2020, 4:01 pm   #134
deepspacedaz
No sorry, I don't mean someone told me here. someone I know.
Old 15th May 2020, 4:18 pm   #135
deepspacedaz
Right side Valves
Old 15th May 2020, 4:28 pm   #136
Freya
Freya's Avatar
valve 1 might be V4 or V5
valves 3 and 5 go into V6, V7
valve 4 goes to V17
not sure on number 2 yet
Stephen
Freya is offline
Old 15th May 2020, 4:33 pm   #137
deepspacedaz
In that order 1, 3 and 5 go into V5, V6, V7
valve 4 goes to V17
Old 15th May 2020, 5:01 pm   #138
Freya
Freya's Avatar
Im out of battery until i get home..
Stephen
Freya is offline
Old 15th May 2020, 5:24 pm   #139
deepspacedaz
Ok thanks for the help.
Hopefully, you can help later when you get home.
Anyone here who can help out?
Old 15th May 2020, 7:35 pm   #140
Colourstar
Colourstar's Avatar
What is the whining noise its really loud? frequency.
Hopefully that is the sound of a healthy 405 line 'whistle', which if you've never experienced a vintage television up close and personal before is perfectly normal. Thats what you- and anyone else in the house- has to live with if you want to use a tv set of that era. You should hear the frequency vary considerably in pitch as you turn the horizontal hold control. If you set the control about mid position that should in theory be about right. The 'whistle' can sound quite penetrating! Some makes/models of set were louder than others.
Like me you probably grew up watching 625-line tv sets in the 1970s/80s/90s where the frequency is much higher and hardly noticeable, but it is still there.
Steve
Colourstar is online now
