23rd Feb 2021, 3:59 pm | #1 |
Etronic RA640. Not working on one waveband!
I’ve had an Etronic RA640 radio sitting in the workshop shelf for some time and thought I’d better get round to finishing it. I won’t bore you with the details of what I’ve done so far but suffice to say, the IF is all aligned and it’s working well on Long Wave and Short Wave. I’ve been using this circuit to check values: https://www.************************...onic-ra640.pdf
This should be easy to sort but I’m stumped. The radio just goes very quiet when MW is selected. My first thought was that the local oscillator was dying on MW but it’s running and tuning perfectly. My next issue is that the circuit doesn’t seem to match what’s built. For example R17 (150k) brings the AGC line back to the mixer oscillator V1 but on the circuit it’s only connected via the cold end of the MW coil whereas in the radio (which doesn’t appear to have been tinkered with) it’s connected to the band change switch as well. The voltages are similar under no signal conditions on V1 except the screen grid voltage drops a little when switching to MW. My next thought was a failure in L4 but the resistance of the various coils seems reasonable and I haven’t got the data sheet fit a QGA532 to know exactly what they should be. I’ve checked for no shorts having developed across any of the trimmers and all seems fine. There's so little to go wrong I'm stumped as to why MW is dead. Sorry if this is long winded but has anyone got any ideas where I should look next. |
23rd Feb 2021, 4:02 pm | #2 |
Re: Not working on one waveband!
Sorry for the strange typos. They have been introduced every time I use an apostrophe for some reason.
23rd Feb 2021, 4:31 pm | #3 |
Re: Etronic RA640. Not working on one waveband!
I’ve checked the voltages again and the voltage on the screen of V1 is 120 volts when receiving R4 LW and drops to 62 volts when I turn to MW and rises slightly to 75 volts on SW. I think this merely reflects the fault and the change in the screen current rather than the fault itself.
23rd Feb 2021, 5:01 pm | #4 |
On the schematic as drawn, the circuit wouldn't work properly on MW because there's no RF grounding from the bottom of L4, it looks like they've missed out a connection dot on the schematic, also in the schematic on SW, L3 is connected to ground which would appear to suggest no AGC at least for the mixer on SW, I think it should have been drawn with at least the bottom of L4, L5 and R17 connected to C5 as well as the switch contact that shorts out the LW coil (L5) when MW is selected...so far as I can make out.
Lawrence. Last edited by ms660; 23rd Feb 2021 at 5:13 pm. Reason: correction |
23rd Feb 2021, 6:04 pm | #5 |
I’m starting to wonder if it’s got a coil missing. The MW tuning trimmer that parallels up the main tuning capacitor is open circuit the whole time and there’s a hole next to the LW coil (that gets shorted out correctly on MW). If I could find a chassis layout diagram with which trimmer and which coil is which I could compare and contrast. |
23rd Feb 2021, 6:28 pm | #6 |
I had one of these a while ago but passed it on. Just checked and sorry I don't have a photo of the underside of the chassis.
Mike |
23rd Feb 2021, 6:43 pm | #7 |
You do indeed have a missing coil, smaller than the adjacent LW coil. On my chassis
it measures 230uH, dc resistance 4.0 ohms. |
23rd Feb 2021, 6:49 pm | #8 | |
All I’ve got to do is find a 230uH coil ( I don’t expect the resistance is that critical). Easier said than done. I could do with a new glass panel for the front as well if anyone had one In good condition kicking around. (The lettering has come off a large patch of the one I’ve got. ) Last edited by john_morris_uk; 23rd Feb 2021 at 7:08 pm. |
23rd Feb 2021, 6:50 pm | #9 |
Any chance of a picture of the coil . Mick.
23rd Feb 2021, 6:54 pm | #10 |
The circuit is in the RTS book volume 1 part 1 on page 258.
Dave |
23rd Feb 2021, 7:13 pm | #11 |
This is a photo of the underchassis of the RF section atm. The large coil is the LW input tuning circuit coil and the hole next to it on the paxolin (sp?) strip is where I assume the MW coil that would look similar but smaller would sit. |
23rd Feb 2021, 7:22 pm | #12 |
Here it is;
Note on the overall pic I have transposed volume/switch and tone controls for safety. |
23rd Feb 2021, 7:52 pm | #13 |
This doesn't really help, but the best shot I have underneath an RA640.
It almost looks like your coil has never been there! Regards, SR (Sorry, I didn't see these better pictures arrive whilst I was rummaging for mine!) Last edited by Stuart R; 23rd Feb 2021 at 8:05 pm. |
23rd Feb 2021, 7:55 pm | #14 | |
Just need to find someone with a scrap chassis that’s got a suitable inductor going spare. |
23rd Feb 2021, 9:25 pm | #15 |
I have a coil that should work it reads 0.22mh on my Chinese meter ,if you want to try it you are welcome to it ,it does have a tuning slug , you just need to find out how to connect it ,Mick.
23rd Feb 2021, 10:41 pm | #16 |
That would be really helpful. I can easily find a way to connect it. How much? Shall I send you a stamped self addressed Jiffy bag? I’ll pm you.
24th Feb 2021, 10:53 am | #17 |
24th Feb 2021, 11:51 am | #18 |
My set is not the same model but the circuits are all similar.
One connection (nearest to former) goes to the lower tag linked to the 100k resistor tag. The other goes via a piece of sleeving to the trimmer capacitor tag directly underneath. Oscillator coils normally have three or four connections. |
24th Feb 2021, 11:59 am | #19 | |
24th Feb 2021, 1:20 pm | #20 | |
