31st Aug 2023, 4:33 am | #21 |
Re: Microprocessor Bus Testers
Sorry, I did mean 'Zicon' Mine is a model 701 logic analyser with an 803 probe/pod.
It looks very similar to the unit you spotted, but is not identical. Mine is also based round the 6802 processor. But I don't have the board of PIAs (?) down the right hand side. There is another board behind the front panel keypad which contains video circuitry, the 701 will display the captured data on a composite video monitor or a UHF analogue TV |
31st Aug 2023, 10:44 am | #22 |
The same seller who had the L.J.Electronics / Zicon unit, at a Rally the day before I saw the SA2. also had a Thurlby LA-160 (which I did recognise and was once a quite widely-sold fairly low-cost Logic Analyser),
It did have a cracked in half top cover / case screws etc missing, and no probe cables / modules, but I'd always wanted to try one of these and managed to get it for £10, after he'd originally asked for £15. But when I tried it, I just get all LED display segments light-up and nothing more, as though it's stuck in reset. However, there is battery-backed RAM with a dodgy? (looks to be leaking) 2.4V 100mAH PCB-Mounted NiCad battery that may well be flat and I'm wondering if that may be stopping a power rail to the RAM etc coming-up enough. So I will try removing and replacing this to prevent any (further) damage . I'm not sure if mine is the A (10MHz Max) or B (20MHz Max) version, as there doesn't seem to be a suffix on the model no. on the front / rear, although serial no. does have a -B at the end. Looking in the service manual parts list, it seems the main difference is that many of the fifty IC's - mostly logic - are 74LSxxx on the A version but faster 74Fxxx IC's are fitted to the B version. But it's not clear whether you could just swap all these to upgrade it, or whether the firmware is different. IIRC, mine does have 74LSxxx ones fitted, although not socketed, so not a quick upgrade. I have readout the firmware from mine and attached this to preserve it in case it's ever needed. There is an empty socket in mine, that the RS Data-sheet manual says is for another 2764 that gives extra-features and was a user-fit option. So it would be good to get a copy of that, to upgrade it with (once I've got it working). It would also be useful to find some more info on the external bus buffer / breakout from standard processors boards, to re-make some of these. There was also a 'Print' / Transfer to PC utility that came with a disc and a couple of EPROM's, so it looks like you needed to upgrade both the original system and the extra facilities firmware for that to work. Some info & pictures on the LA-160 can be found: http://mrtomsworld.blogspot.com/2016...alyser_64.html http://sonicsheep.com/Electronics/2-...y%20LA160.html With Manuals (also attached) / I found at: http://www.bitsavers.org/test_equipm...ing_Manual.pdf http://www.bitsavers.org/test_equipm...60_SERVICE.pdf |
31st Aug 2023, 10:50 am | #23 | |
I did, unexpectedly, see there's a 6845 CRTC IC in it. So I'd wondered about it having a proper video output, rather than requiring a'scope to display waveforms on (so like those 16ch 'scope multiplexer projects that used to be around in Electronics magazines etc) |
31st Aug 2023, 10:54 am | #24 |
I've got some photos of my Zicon logic analyser here
https://www.***********/photos/tony_d...77720303502148 |
1st Sep 2023, 2:46 am | #25 | |||
Thanks for the info and link to those photos of yours, which I've been comparing to the one I saw. The main board does look rather-similar, but whilst yours only has one (part no. 27017 Date 870114) EPROM fitted, with an empty socket above this. Whereas the one I'd found has a later (part no. 27037 Date 8?90126), plus an extra (part no. 2704? Date 890126?) EPROM fitted above that. - So maybe that extra EPROM provided extra facilities / was for the additional expansion board? It does seem that the extra expansion board on the one I saw, is connected in place of one of the (many!) original 6821 PIA's, and has even more on this board (+ some RAM IC's?). So I'm wondering if this provides extra channel inputs? Unfortunately, there doesn't seem to be much info on the 'net about either Zicon or L.J.Electronics (unlike the Thurlby LA-160, with both manuals online and websites like sonicsheep.com + mrtomsworld.blogspot/2016/08 having some useful info on these) Although I've found the Zicon 801 model (with built-in Green-screen CRT), does seem more-common than the 701 you've got. And I've seen similar-looking Interface pod modules people have for their 801, to your 803 one - So maybe the 803 was also originally intended to be used with the 801, and they'd retained the same connector (Like Polar B2000 & B200A etc). I did find the L.J.Electronics Ltd. model SA 1 (/ Zicon Model 632) Service Manual is also held here: https://elektrotanya.com/l.j.-electr.../download.html - Which can be a bit-easier to download from. Where I see that on the manual's front, it says 'Distributed by L.J.Electronics' (in Norwich). And 'Designed & Manufactured by Zicon Instruments Ltd' - also in Norwich (but at a different address / 'phone number). The elektrotanya.com website also described the SA 1 / L.J. Electronics 632 as a 4MHz Clk Logic Analyzer 1981. So it looks like that was an older / slower version and lacked the video display (plus built-in disassembler etc?) that the Zicon 801 (L.J. Electronics SA 3 ?) (and Zicon 701 / L.J. Electronics SA 2 ?) had. That SA 1 / Zicon 632 manual also has a schematic for their 16ch Input Buffer Pod, which they may have carried-on using with later ones. Last edited by ortek_service; 1st Sep 2023 at 3:00 am. |
2nd Sep 2023, 7:30 am | #26 | ||
Well I later found there is some more quite-useful info, on a linked sub-page in one of the above links, at: http://sonicsheep.com/Electronics/3-LA160%20Writeup.htm Plus downloads of some versions of the firmware, at http://sonicsheep.com/Electronics/Downloads.html Although only versions 33 & 50 of the main firmware, rather than all the ones he'd said he'd copied so far: Quote:
- As well as a PC Program for later OS's, that he'd written. I've found that the unit first tests the all the display segments, but it should then start showing version info etc which I can't get it to do. The 2.4V 100mAh NiCad backup battery is flat in mine, but it hasn't failed s/c - maybe o/c, as there's 3.6V across it when powered up and doesn't draw any current if I connect a bench-PSU, set to 3.6V directly to it. So I need to do some more fault-finding investigation on this. I've also discovered that the original version (01) firmware (that I have in my early-version unit), has an A / B suffix version to go with what speed IC's etc. the h/w is using. But on later ones, it asked the user to enter A or B, if the battery-backed RAM had lost this setup config value. Plus, I found that my unit fortunately is actually the 20MHz 'B' version. So I don't need to try and de-solder 22off! 74LS etc IC's and change them to 74Fxxx / 74Sxx ones (as well as changing 4off resistors & 6off capacitor values + Crystal) - and also swap the firmware on my early-model - in order to 'upgrade' to the faster 'B' model. I do wonder if they really saved that much cost with using the 'standard version IC's, to have ever produced the 10MHz 'A' model - as it still has the same total number of parts as the the twice-as-fast 'B' version. |
9th Feb 2024, 11:28 pm | #27 | |
https://vintagecomputers.sdfeu.org/photos/Zicon/601/ I've got a couple of pods (one for Z80/6800/6502, other for 68000) but have yet to connect it up. I don't have a manual, can anyone help please? Regards, John |
9th Feb 2024, 11:35 pm | #28 |
10th Feb 2024, 1:54 pm | #29 | ||
Thanks for those good insides etc photos, as not too much info out there on these. I see there's quite a few 680x CPU's in this (as well as all the 6821 PIA's), with a 6809 and a 6802 on a daughterboard. And maybe another one on the main board, as couldn't see the part number of the one 40pin DIL IC hiding under the ribbon cable. Re: Manuals for it. It seems these are also hard to find online, but TonyDuell may well have a manual for his 701 at least, that might be quite close to the 801 model. These models do appear to have some quite good facilities for many processors - Although I wonder if anyone did one that supported the SC/MP ? (But maybe the NS LCDS etc can kind of do that?) BTW, I found that (your?) website you linked to has loads of photos up a level on many other familiar Acorn (With photos of those infamous cracking RiFA caps), Commodore, Dragon, Sharp etc systems + Monitors + the not so common Northstar, SWTPC (that I've got), Elektor Z80, even some rarer Intel programmers / Computers and the odd VCF event: https://vintagecomputers.sdfeu.org/photos/ As well as some good ones of an original MK14, I hadn't seen before: https://vintagecomputers.sdfeu.org/photos/Sinclair/ So plenty of interest to many in this forum-area. |
10th Feb 2024, 1:57 pm | #30 |
10th Feb 2024, 2:08 pm | #31 | |
However, it looks like 1980s_john is looking for operating instructions assuming his is fully-working. So it may be a case of just having a play with it to work it all out / asking others who have used these, if necessary. I wonder if these ones, being offered for sale nearly 10years ago came with manuals and if people on there could still be contacted to see?: https://forum.vcfed.org/index.php?th...nd-6800.47896/ Also one was given away here: https://www.pinballinfo.com/communit...nalyser.49501/ And a couple auctioned here: https://www2.ppauctions.com/archived...emblers-for-68 - But not clear whether any included the manuals. Plus these were also discussed here: https://stardot.org.uk/forums/viewtopic.php?t=9732 So might be worth trying to contact others with these, on those forums etc, to see if they have a copy of the manual, as Google etc hasn't found anything so far. Last edited by ortek_service; 10th Feb 2024 at 2:23 pm. |
10th Feb 2024, 2:19 pm | #32 |
Here you are, I hope they're readable.
10th Feb 2024, 2:28 pm | #33 |
11th Feb 2024, 9:49 pm | #34 | |
https://vintagecomputers.sdfeu.org/photos/Zicon/801/ I've added pictures of my 803 pod (same as Tony's, but with a 40 pin clip) and 804 pod for 68000. Also added photo of the 801 rear - odd that it has an RGB socket, this is not connected on the inside! Regards, John |
12th Feb 2024, 6:30 am | #35 | ||
I had previously spotted that DIN socket, which wasn't connected-to at all, and wondered what it was for. I guess that maybe there was an option with a (Buffer / RGB-Encoder ?) board (they seem fond of having quite a few daughter etc. boards in this) , to connect to this. And fitting an unconnected socket was easier / cheaper than making a blanking plate to fit this (Although you'd think they would have at least covered the rear-panel's labelling with some tape / blank adhesive label etcl) However, maybe video was mono-only on this model (as they've used a Green-screen monitor) and there was an intention to produce a colour version in the future that could make best-use of the RGB Output. If there isn't a PAL etc. colour encoder, then the 'Composite' (Really just Luminance?) Video-output should be sufficient if there's no Chroma signals to degrade it's Luma-signal quality. |
12th Feb 2024, 5:39 pm | #36 | |
The last couple of pages of the reverse-engineered 803 schematic give the mapping between processor signals and logic analyser inputs. I notice that the setup screen of the 701 analyser covers other processors, including the 68000. I would guess the 804 pod could be used with it. If you want a little project, try tracing out the circuit of the 804, it won't be very complicated. |
13th Feb 2024, 10:20 am | #37 |
That was me selling the Zicon logic analysers. Had quite a few of them, but interest waned because no one used the 8 bit micros, so scrapped. I did keep two for myself up until last year but needed to downsize so they were scrapped as well. Doubt I have any bits left, can't keep everything! Never had any paperwork.
13th Feb 2024, 12:23 pm | #38 |
Thanks for the info. Sad that you weren't able to find anyone to re-home them but I suppose they do take up a fair amount of space compared to the more basic LED display instruments
- although not as large as many old CRT Logic Analysers, especially the (very-deep front-to-back) HP 1611A monster I have somewhere with pictures of many of these here: https://www.hpmemoryproject.org/wb_p..._b_page_12.htm And it does seem that documentation on these mostly got lost quite early on - so now even harder to find than the increasing rare-to-find units themselves! So would be great to have on bitsavers etc, if some is ever located. |
22nd Feb 2024, 8:16 pm | #39 |
Just dropping in to say "hi". John joined our logic analyzers group in his ongoing quest for docs for this (incredibly obscure, to North American eyes) Zicon analyzer. I wasn't previously aware of it, but will be adding it (and the others discussed here) to our archive - we recently upgraded and have room to burn. So please consider joining up and keeping an eye on progress, as we're not just strictly about analyzers, but any related digital development support hardware. And - of course - you may have software and/or docs that we need.
Look forward to seeing you there! Jonathan |
23rd Feb 2024, 1:04 pm | #40 |
Hi Jonathan,
Welcome to our group. Note: It can take a while for posts from new joiners to be approved, before they appear, as an anti-spam measure. And thanks for the info - It looks like that could be an interesting group for some of us to look at / join, as well, so will have to discover it (on groups.io along with a few other useful ones some of us have joined?) Owen |
