23rd Jun 2021, 10:34 am | #1 |
Ekco U353. Wax Capacitors and resistor replacement.
Hi I need to replace 3 wax capacitors they are marked 0.01uf 400vac 1000vdc what modern eq do I need for these please. They are axial capacitors.
23rd Jun 2021, 10:39 am | #2 |
Re: Wax Capacitor
Depends where they are and what they're doing......
Are they for RF suppression? Connected across line - neutral or line - earth? Then Class X or Class Y. Detailed application info needed for relevant recommendations for any other usage.
23rd Jun 2021, 10:40 am | #3 |
Re: Wax Capacitor
The type you replace them with would depend on their circuit function.
Lawrence. |
23rd Jun 2021, 5:27 pm | #4 |
Re: Wax Capacitor
They are on an EKCO U353 I have 3 DIFFRENT service sheets for this model and not one matches exactly to this chassis. This has 3 wavebands all 3 capacitor have same value and all are connected to chassis at one end one goes to output transformer one to on/off volume and one to UCH81 VALVE BASE and all go to the chassis
23rd Jun 2021, 5:56 pm | #5 |
Re: Wax Capacitor
Can you be more precise?
Which connection on the output transformer? Is it On/off switch or volume control? Which pin on the UCH81 valve base?
Frank |
23rd Jun 2021, 6:13 pm | #6 |
Re: Wax Capacitor
I will take some photos it may help
23rd Jun 2021, 6:32 pm | #7 |
Re: Wax Capacitor
I said that one goes to valve base well it does not it goes to aerial earth point on earth connections and and chassis. The other goes from on off switch terminal to mains dropper and other from chassis to output transformer yellow speaker cable. I have pics. All are same value 0.01uf 400vac 1000vdc
23rd Jun 2021, 7:40 pm | #8 |
Re: Wax Capacitor
dont think thers anything special about those three .so normal 10n[0.01uf] 1000v dc capicitors
23rd Jun 2021, 7:42 pm | #9 |
Re: Wax Capacitor
So far as I can make out it looks like replace the one that's connected to the on/off switch with an X Class 2 type and the other two with Y Class 2 types as they look to be safety related.
Lawrence. |
23rd Jun 2021, 9:08 pm | #10 |
Re: Wax Capacitor
23rd Jun 2021, 9:31 pm | #11 |
Re: Ekco U353. Wax Capacitors.
I think there IS something special about those capacitors.
That set appears to use a live chassis.... connected to one side of the mains or the other. Two of those capacitors look to be isolators for the aerial and earth sockets. If one or other of these fails, someone could get a full mains electric shock. In current terminology, these need to be "Class Y" safety grade parts, designed not to go short circuit even if they fail. The other one looks to be an interference suppressor across the mains, if so, it should be a "Class X" part. These are designed to survive the sorts of transients found on the mains, and degrade slowly. Valves with the U prefix mean special ones designed for live chassis operation (no mains transformer so no low voltage supply for heaters) They get connected across the mains in a long string to suit the high voltage, with a series resistor to allow for mains voltage adjustment. David
23rd Jun 2021, 10:05 pm | #12 |
Manufacturer's service sheet shows:-
C1 wired chassis to signal earth socket. Replace with Class Y. (Trader Sheet C2). C61 wired across the mains supply. Replace with Class X. (Trader Sheet C60). I can't see a third capacitor which needs to be class X or Y, but no doubt someone will correct me.
23rd Jun 2021, 10:14 pm | #13 |
23rd Jun 2021, 10:19 pm | #14 |
I think I will leave the wax ones in place. Not experienced enough to know which ones to get. The radio does work just someone said it is best to replace wax capacitors
23rd Jun 2021, 10:25 pm | #15 |
23rd Jun 2021, 10:29 pm | #16 | |
The capacitors are readily available. Lawrence. Last edited by ms660; 23rd Jun 2021 at 10:53 pm. Reason: extra info |
24th Jun 2021, 1:56 pm | #17 | |
Re: Wax Capacitor
From your description I would think that one is a tone corrector (the one that goes to the yellow wire) so that can be a normal polyester type 0.01uF 1000V, the one to aerial and earth point is for isolation so that should be a 'Y' type and the one to the dropper is probably a mains filter so should be and 'X' type if across the mains or a 'Y' type if going to chassis. Positive identification from the circuit will conform this (or prove otherwise)!
There are lots of brilliant keyboard players and then there is Rick Wakeman..... Last edited by Sideband; 24th Jun 2021 at 2:03 pm. |
24th Jun 2021, 6:43 pm | #18 |
I cans seem to find these for sale anywhere. And not sure what to look for. Or where or what to ask for. Completely lost on this one.
24th Jun 2021, 6:56 pm | #19 |
Has Sideband asked, post circuit snippets.
X rated capacitors suitable for across the mains input are available from Cricklewood, but we need to be sure exactly where they are in the circuit.
Frank |
24th Jun 2021, 9:37 pm | #20 |
These are the circuit diagrams with 2 of the capacitors the capacitor going from chassis to output transformer is not shown on circuit diagram. But as I said it is the same value and power voltage as the other ones. 0.01uf 400vac 1000dc. That's all I can tell you.First is C2 and C60 mains switch tag with green wire going to dropper
