Old 21st Jun 2021, 8:35 pm   #1
Goldieoldie
Default Sony mains clock motor
Hi
I have a Sony mains clock motor which has an issue.it does not run
If I heat it with a hair dryer it then works for a short time and is noisy
I guess the grease had gone hard
I have drilled a hole and put some penatrating oil in with little improvement
The front seems to be sealed with glue
Is the next step to remove the glue and take it apart ( assuming it will ) ? Anyone know about these
Pete
ID:	236203   Click image for larger version
Goldieoldie is offline
Old 21st Jun 2021, 8:41 pm   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: Sony mains clock motor
Not quite the same but see here:
(https://www.vintage-radio.net/forum/...d.php?t=107051)
Nickthedentist is online now
Old 22nd Jun 2021, 11:39 am   #3
Goldieoldie
Thanks Nick
Old 22nd Jun 2021, 5:53 pm   #4
PaulR
PaulR's Avatar
I am not sure where you drilled the hole but I (and others) have had success by drilling one in the outer edge then filling it with switch cleaner. This got it running for me. After a while I shook the switch cleaner out and put as much sewing machine oil as I could. It ran quite noisily for a while and quietened down over a period of 24 hours.
It will twist and pull out of the magnet poles to make things a bit easier. I tried but never managed to get one apart.
Paul
PaulR is offline
Old 24th Jun 2021, 8:39 pm   #5
Goldieoldie
After oiling via the hole it still did not run so to bits it is !
I had to lever the sides to get the mech out ( not a pretty sight )
I then cleaned and oiled it .
Still would not run . I found if I put the mech back in the case but not all the way in ( about 1 mm ) It would run !
Don’t know why this is but it’s working .
Still noisy but at least the numbers go round .
ID:	236388   Click image for larger version
Old 25th Jun 2021, 8:25 am   #6
steve102
This looks like a Telechron Type S rotor. You will find more information here:
https://telechronclock.com/page6.html
https://prepostmodern.com/rotors/
steve102 is offline
Old 26th Jun 2021, 9:54 pm   #7
Goldieoldie
Thanks Steve
