10th Apr 2021, 7:30 am | #1 |
Help with a Triumph CTV 8000 Colour TV/monitor.
Hi.
I wandered if anyone knows any more info on these? I've seen some tvs listed as Grundig/Triumph but I can't find any info on the net about these. The screen is Orion branded see photos. I have 2, 1 works fine, the other has sound no picture, the screen did come on once, I knocked the left hand side of the casing with the other one accidentally. I will be looking for any bad connections or failing solder joints etc. The one that works has scuffed plastics and broken aerial mount, so this one I plan to install a generic retro console inside to make a portable retro arcade. But I would like the other one working first. Regards. Brian. |
10th Apr 2021, 12:10 pm | #2 |
Re: Help with a Triumph CTV 8000 Colour tv/monitor
I have the Mastercare service manual for the Triumph CTV8000, which I could scan and email to you if it helps. Send me a PM (private message) with your email if interested.
Dave
10th Apr 2021, 12:44 pm | #3 |
That would be awesome, thanks.
13th Apr 2021, 12:37 pm | #4 |
Re: Help with a Triumph CTV 8000 Colour TV/monitor.
As far as I remember these were made by Orion who supplied badged sets to Currys and Dixons. They were pretty good with few serious faults. As you suggest, the cleaner one probably has dry joints, and I'd resolder the line driver transformer's connections first as that was a weak spot on Orion TVs of that era.
As they are getting on now, it's worth checking the wedges that hold the scan coils in place. The silicone used to fix these on 14" Orion tubes used to rot the coils. You can see a big white blob of adhesive on your fourth picture. You can carefully remove the wedges and clean the area if necessary and reattach with a non-acetic silicone. Hopefully you won't need to. |
13th Apr 2021, 4:51 pm | #5 |
Hi to all,
Great Thanks ! to G6ONEDave for great Scans of the service data. As most of you know, i collect miniature B&W & colour TVs. USA/Eu/UK. The Triumph CTV-8000 is a pretty iconic set of the mid-eighties. It exists under a variety of labels (TMK, Orion, Irradio, Triumph...) and with its distinctive upright/narrow presentation appeared in most European B/G, I markets as well as in the USA/Japan. The design evolved through time with several iterations going from RF/Antenna-only reception to full Monitor status with A/V inputs and outputs. An interesting design of miniature Solid-State colour TV history, and doesn't take up much floor space for collectors and today's young retro-gamers. Best Regards jhalphen Paris/France |
14th Apr 2021, 3:40 am | #6 |
I believe that Triumph was an own-brand of Comet.
But like many other own-brands, it was probably one of many re-badges of a common Manufacturer. |
14th Apr 2021, 6:19 am | #7 | |
Cheers. Brian |
14th Apr 2021, 6:24 am | #8 | |
Thanks jhalphen for the info, both of mine have A/V in and out. I'll see if I can find more by looking for those names mentioned. I love them, the picture quality is actually very good, the colours are great too. Thanks agian. Brian |
14th Apr 2021, 6:25 am | #9 | |
Brian |
14th Apr 2021, 8:52 am | #10 |
What a lovely neat set that is, Brian. Very 80's!
Andy G1HBE. |
14th Apr 2021, 11:15 am | #11 |
I think Triumph were from Currys. Comet used Proline, Wharfedale and a few others. Of course I could be wrong...
You'll notice this TV was made in Japan so its reliability was excellent. One Triumph TV set we saw quite often was a badged Toshiba 22" in a basic grey-fronted cabinet. True to form, the only part that gave trouble were the (non-Toshiba) customer controls. |
14th Apr 2021, 1:36 pm | #12 |
I am confident you are not. Triumph was a Currys in house brand (as was Westminster). When Dixons took over Currys in the early 1989s, Triumph was dropped in favour of Matsui (as it sounded Japanese - with the association of quality and reliability). Dixons already used Saisho (they previously used Prinz).
14th Apr 2021, 1:48 pm | #13 |
Thanks Andy.
I did love the 80's. Brian |
17th Apr 2021, 3:53 am | #14 | |
I now have 2 fully working Triumph CTV 8000's Brian. |
19th Apr 2021, 3:47 pm | #15 |
The association of the brand name Triumph to Grundig is probably from the Grundig ownership of office equipment maker Triumph Adler. I think they sometimes had radio or TV sets with Triumph as a model name as well.
Both obviously unrelated to the house brand Triumph used on this (Orion made?) set. Last edited by Maarten; 19th Apr 2021 at 3:57 pm. |
20th Apr 2021, 5:37 am | #16 | |
That makes sense now, no wonder I drew a blank searching. Brian |
20th Apr 2021, 1:06 pm | #17 |
I thought the name was to give the impression of a reliable British name as in the motorcycles. However it was (is?) also the name of an equally reliable bra manufacturer! Well, would you want a Playtex TV? The brand was soon dropped in favour of Matsui.
21st Apr 2021, 12:11 am | #18 |
Hi to all,
Hi Lyndjonny, You might be interested in following this US VK thread. Talk is about CANDLE JCTV 0502 and JCTV 0500, both 5" colour NTSC transistorized TV of the mid-eighties. I believe, from experience, that OTAKE of Japan was the OEM. Look them up. They started 5" color TVs, big heavy horizontal tabletop chassis circa 1985. Sold a bunch as 625 PAL B/G German models then with SECAM L modified for France. Re-labelled, world-wide under a bunch of private labels (Irradio in Italy for instance). Lots of ORION brand TVs in Germany. Except for the very early models, they all have that slim vertical aspect similar appearance. Some are TV only, some have AM/FM Radio. Some later models have A/V inputs, earlier ones don't. Nice ! high-res photos of the innards for your Micro-TV photo archives : http://www.videokarma.org/showthread.php?t=273675 Best Regards jhalphen Paris/France |
21st Apr 2021, 5:19 am | #19 | |
Thank you jhalphen, I've messaged him to see if I can use his photos. Brian |
21st Apr 2021, 1:15 pm | #20 |
I'm pretty sure Orion is the OEM for Otake, and not the other way around.
Pictures of late 1990's models show typical Orion type labels on Otake branded equipment. Radiomuseum.org seems to classify various Otake models under Orion, though I don't know which evidence was used for that. I'll look into it a bit more. |
