27th Mar 2021, 6:42 pm | #21 |
Re: Telpro C561
This is the new loptx fitted
And to show the old loptx with a hole in the overwind |
28th Mar 2021, 9:44 am | #22 |
Re: Telpro C561
I can just imagine the old one sizzling! Hope it's successful Chris.
All the very best, Tas |
29th Mar 2021, 11:00 am | #23 |
Re: Telpro C561
I wouldn't connect the tripler just yet. It looks like the LOPT failed for its own reasons, but you never know! It's nice to find a reason the set was retired as then most other panels (except the msiing one, of course!) will probably be OK.
29th Mar 2021, 10:32 pm | #24 |
Re: Telpro C561
Hi!
Update on the replacement PSU board for the OP Chris Field – my design is now virtually all complete apart from the two +25V and the –35V smoothing caps – I've only to measure the original caps, make the PCB footprints and drop them in! Final job is to email the OP a paper template to measure up against his chassis and then once confirmed the size is correct it can go for manufacturing! Chris Williams
10th Apr 2021, 10:19 pm | #25 |
Re: Telpro C561
Hi!
Replacement PSU and AF Panel design for the OP Chris Field's Telpro C561 now complete and ready to send for manufacturing! I'll post the Gerber files once I've had confirmation from the OP that it's the correct size! I've laid it out using original Bradford components, so hopefully everything will fit OK! Chris Williams PS! I made provision on this board for both revisions of the PCL82 Audio Circuit that Decca used in their Bradford chassis, as I am of the opinion that running the pentode anode of the PCL82 direct from the main 300 V h.t. line is far too much for this valve, so included provision for both the main h.t. feed resistor R82 (1k8 9W fusible), the main decoupler C84 (33uF 400V), and the additional screen-grid/triode anode decoupling components R83 (4k7, 1W) and C83 (4uF 400V).
It's an enigma, that's what it is! This thing's not fixed because it doesn't want to be fixed! Last edited by Chris55000; 10th Apr 2021 at 10:37 pm. |
18th Apr 2021, 10:09 pm | #26 |
Re: Telpro C561
Hi!
Circuit diagram to which the PCB has been designed now attached! Chris Williams
25th Apr 2021, 8:51 pm | #27 |
Re: Telpro C561
Hi!
Panel manufacture now complete and on it's way to me! Chris Williams
27th Apr 2021, 5:32 pm | #28 |
Re: Telpro C561
Keep keeping us updated Chris! Plenty of Deccas about but next to no Telpros.
7th May 2021, 6:09 am | #29 |
Re: Telpro C561
Hi!
New PCB now arrived and ready for assembly, which I'll get started on this weekend! My grateful thanks to Member "Davidh1041" who furnished me with a spare Decca Bradford PSU for the transformer, etc! The PCB was designed and laid out using "Easy PC", but it should be possible to replicate this type of panel using the free "Design Spark" software as it is not necessary to use an "autorouter" – the AR in D.S. is absolute rubbish! I have already provided the TTFs for the "Radio Constructor" style lettering used on the silkscreen printing elsewhere on this forum, by the way! Once assembly is complete I'll test it and get it posted to the OP later next week! Chris Williams PS! Gerber Files and a ready–made PCB available from me on application via PM!
5th Aug 2021, 12:26 pm | #30 |
Re: Telpro C561
Wow Chris! That PCB looks fantastic. How are you getting along with it?
5th Aug 2021, 8:54 pm | #31 |
Re: Telpro C561
Hi Taz , still waiting to hear from Chris about the power supply board ,
Last I heard he was fitting parts that was back in June , I don’t like to ask in case the dreaded COVID has been a problem Chris |
6th Aug 2021, 11:18 am | #32 |
Re: Telpro C561
Ah, okay. He's probably inundated with all sorts! We'll just have to wait.
11th Aug 2021, 8:43 pm | #33 |
Re: Telpro C561
Hi!
Not the dreaded, just a combination of eye–trouble, mislaid bits and a duffy iron! Update on this with a small confession – I've mislaid some of the small parts, which I'm slowly in the process of finding, (as I've put things away everywhere!) and I'm also having a bit of bother with my soldering iron station, and I'm in the process of waiting for a Black Jack BK2000 one I won last week, hopefully that will get my iron up and running again! Hopefully more progress soon, sorry for the delay Chris! Chris Williams PS! I'm signed off work due to eye–trouble so I've not got access to the top–notch soldering/desoldering tools at my work's fleapit that would build this really quickly!
It's an enigma, that's what it is! This thing's not fixed because it doesn't want to be fixed! Last edited by Chris55000; 11th Aug 2021 at 8:54 pm. |
26th Sep 2021, 5:26 pm | #34 |
Re: Telpro C561
Hi!
PCB now completed and handed to the OP Chris Field @ RetrotechUK this morning – my job is done & I'll hand back to the OP to carry on his tale from here! Chris Williams PS!!!! Now got my Duratool ZD915 new desolder gun and the Black Jack BK2000 soldering station that enabled me to catch up on Chris Field's PCB at long last!
It's an enigma, that's what it is! This thing's not fixed because it doesn't want to be fixed! Last edited by Chris55000; 26th Sep 2021 at 5:31 pm. |
26th Sep 2021, 10:15 pm | #35 |
Re: Telpro C561
Hi!
Design update I forgot to mention earlier – when I got the new PCB back from manufacturing I found the only preset potentiometer footprint in my Easy–PC was one of those little tiny "halfpenny size" ones, so I'll modify my PCB to use a standard Piher one – doing that only means turning one resistor round and moving some silkscreen text, and I'll add another 10 mil to the pad hole diameters so the little Erie PCB resistors go in more easily! Chris Williams
27th Sep 2021, 10:37 pm | #36 |
Re: Telpro C561
Update on the Telpro 561
As Chris Williams was designing and making the power supply panel for this set it had been put to one side for a while On Sunday at the retro tech meeting Chris delivered the remanufactured pcb to me and wow what a fantastic job he has done this it a totally professional job I would like to take this opportunity to say a massive THANK YOU to Chris for all his time and efforts in re making this power supply .👍 I had the opportunity to fit the pcb today and it worked perfectly, the rest of the set needs attention to make it perfect but the power supply is absolutely spot on . |
28th Sep 2021, 11:30 am | #37 |
Re: Telpro C561
Not much to do now!
That board is so much better than the original offering and will last far better. Imagine if this was possible in the Seventies and he re-manufactured Pye CDA panels. Everyone would have beaten a path to his door. |
28th Sep 2021, 11:35 pm | #38 |
Re: Telpro C561
Hi!
I'm currently two–thirds of the way thro' a BRC2000 h.t. regulator board that's currently proving a bit tricky in places! Don't all come rushing up at once for Pye Hybrid CDA or 697 vertical PCBs yet please, I'll not be able to keep up. . .! ✏️ ���� ✏️ ���� ✏️ ���� Chris Williams PS! PL802 valves still reasonably priced and plentiful. . . .!
It's an enigma, that's what it is! This thing's not fixed because it doesn't want to be fixed! Last edited by Chris55000; 28th Sep 2021 at 11:56 pm. |
29th Sep 2021, 10:14 am | #39 |
Re: Telpro C561
I know the one you're doing - it was a little bit awkward!
A Pye vertical PCB would be a challenge.... |
30th Sep 2021, 9:15 pm | #40 |
Re: Telpro C561
Hi!
Not impossible tho' Glyn, as long as I had the remains of an old one to get the dimensions and the edge–connector contacts correctly sized! I have had a request for a G6 s/s I.F. panel, but I would need to borrow an old one to design the outline correctly and get the spacings of the coil pins! (I think it's only panels with really awkward shaped internal cutouts may be a problem perhaps!) Chris Williams Chris
