Old 7th Feb 2021, 5:01 pm   #1
IKC2E51R8
Default Philips GR2.2 Contrast Dims/Sound Cracks
Hi all,
Two days ago I was using my Philips Gr2.2 set to watch some music videos, Normally the picture on this set is fantastic but I noticed an issue that seems to be developing, If the scene changes from a dark scene to an all white scene the contrast dims temporarily and then returns to normal a second later, when this happens the sound also cracks.
One of the videos had camera flashes every few seconds that filled the screen white and after this the contrast got slightly dimmer then returned to normal.
I then noticed that if i turn on teletext and turn it off the same thing happens.
Ive seen on another forum a similar issue present on an L6.1 set.
Where should i start looking to resolve this? Can anyone advise?
Any help appreciated, its not a major issue as normally the picture is excellent but i want to avoid it becoming a bigger issue down the road.
Cheers,
Luke
IKC2E51R8 is offline
Old 8th Feb 2021, 11:53 am   #2
Welsh Anorak
Welsh Anorak's Avatar
Default Re: Philips GR2.2 Contrast Dims/Sound Cracks
Start with the simple things - check the earthing of the CRT's aquadag.
Glyn
www.gdelectronics.wales
Welsh Anorak is offline
Old 8th Feb 2021, 8:21 pm   #3
IKC2E51R8
Good Idea, I was thinking it was somthing to do with the beam current limiter but best to start with the simple stuff, the aquadag earth never even crossed my mind. I'll take a look.
Cheers,
Luke
Old 8th Feb 2021, 10:45 pm   #4
IKC2E51R8
Only had a quick look and i do think its something in the beam current limiter, just by the way its behaving, I let it run and then turned the text on, when text is on the page number gets darker after a minute, then when text is turned off the whole screen goes dull as if the contrast is turned all the way down affects the whole screen including the OSD, then a second later it returns to normal brightness (Does the same in picture mode if rapidly going from a bright to dark image and vice versa so I think (maybe) a bad cap is drifting in value a bit in the BCL. I'll have to have a proper look when ive more time and energy. Pin 15 of IC7309 is the control pin for the BCL so i might temporarily disconnect it and see if it behaves the same way or not to confirm.
Cheers,
Luke
Old 9th Feb 2021, 10:35 am   #5
ben
ben's Avatar
Measure the HT line to the line o/p stage, could be very revealing.
Regards,
Ben.
ben is offline
Old 10th Feb 2021, 9:59 pm   #6
IKC2E51R8
HT is at 100.5v
Cheers,
Luke
Old 10th Feb 2021, 10:46 pm   #7
ben
ben's Avatar
Is it steady from switch on until set is fully warmed up? No fluctuation when fault occurs?
Regards,
Ben.
ben is offline
Old 10th Feb 2021, 11:07 pm   #8
IKC2E51R8
bang steady at 100.5
Cheers,
Luke
Old 15th Feb 2021, 6:03 pm   #9
IKC2E51R8
does anyone have any other suggestions. I temporarily disconnected Pin 15 of the video IC to see if its in the beam limiter and its not, same result. I also changed the Peak drive storage cap and same result. Could it be the video processor itself is failing, its a TDA4680, you guys would know more than me what their reliabilty was like.
or should i be looking somewhere completly different?
Cheers,
Luke
Old 27th Feb 2021, 10:24 am   #10
samjmann
samjmann's Avatar
Bit late to the party...
I had a GR2.4 that did similar. The picture would dim in steps, and then clear. This set was ex- rental but only 18months old at the time.
The fault was the CRT... I simply lived with it. The set with its gull wing tube gave a great picture. The rest of the family barely noticed it, just me.
If you've got access to a scope, monitor the RGB cathode waveforms, this should show if its the drive that's varying. You can use just a meter, but judgement is more difficult.
In some cases a very gentle tap the the CRT neck can bring the fault on. SJM.
It's never been right since we've had it...
samjmann is offline
Old 27th Feb 2021, 11:00 am   #11
Heatercathodeshort
Heatercathodeshort's Avatar
It could be as simple as a dry joint on the LOPT. J.
Heatercathodeshort is offline
Old 2nd Mar 2021, 4:50 pm   #12
Maarten
Even if it's the tube, the drive will probably vary since it uses a closed loop system for cathode bias.
Maarten is offline
Old 11th Apr 2021, 5:34 pm   #13
IKC2E51R8
Quick Update, I still havnt solved this but after My IKC2 Ordeal I think it might be an earthing problem, the symptoms are similar, though not the exact same, the picture on the philips wobbles too but only when the volume is pushed way up, the philips is able to go much louder than the Ferguson.
I'll have to go snooping at the board and see if theres any hairline cracks or bad grounds
Cheers,
Luke
Old 7th May 2021, 12:01 pm   #14
3CX15000A7
Hi!
Did you check the 14V supply? As both a part of the video section and the sound module works on this voltage, derived from the LOPT.
Measure the 14V at the CRT panel and at the sound module, are those both steady when the fault occurs? Are the capacitors around the LOPT for the 14V supply good?
Also, a fault on the CRT panel maybe cause a dip in the 14V with can causes the audio crack . .
It also can be a fault in the cut-off circuit (also using the 14V) . .
3CX15000A7 is offline
Old 8th May 2021, 2:42 pm   #15
IKC2E51R8
Hi
I havnt checked the 14v supply yet, just been looking through the manual and the 14v feeds a lot so theres definatly a something in there that could be bad, when I have some spare time I'll get the meter out and test the 14v line and see if i can narrow down the fault. thanks for the tip
Cheers,
Luke
Old 22nd Feb 2022, 8:25 am   #16
IKC2E51R8
Default Philips GR2.2 Contrast Dim + Sound Crack
Hi All,
Now that the 51K5 is sorted and in place of my GR2.2 I have time to go back to this issue with the Philips... The goal is to fix the Philips and put it back into service and retire the 51K5 and put it safely into storage as I want to keep it in working condition and I reckon if i keep it in service it'll fail again and I don't have the mental patience to go routing for more ICC5 faults.
Back to the Philips...So the story is whenever there is an all white or all black image on the screen the contrast dips and once the scene clears the contrast comes back up, for example there's a music video with camera flashes in it and when that scene is playing the contrast dims ever so slightly and the sound cracks...
If i turn on the teletext the contrast goes down and then comes up a second or two later once the teletext is turned off.
The sound only cracks on an all white image.
Someone in the previous thread suggested checking the HT supply and its steady at 100.5v.
It was also suggested to look at the 14v supply as this feeds part of the audio and the video stages and also the cut off.
the 14v supply is coming up at 17.5v without the fault condition and 17.7/17.9 when in the fault condition.
no idea why its high can anyone suggest what might be causing it?
Possibly related when the volume is turned half way up noise can be heard from the speaker, nothing specific just a noise (like air escaping)
Cheers,
Luke
Old 22nd Feb 2022, 10:15 am   #17
3CX15000A7
Default Re: Philips GR2.2 Contrast Dim + Sound Crack
Originally Posted by IKC2E51R8 View Post
Hi All,
I think we need to measure starting to check the PSU's
- TDA4680 pin5 (8,5V)
- CRT print C2432 (12V)
- CRT print +190V
Also check C2354, C2365 around TDA4680 and all electrolytic caps on the CRT PCB.
Old 22nd Feb 2022, 2:12 pm   #18
Maarten
Especially if they're somehow involved in the beam limiter. If all supply voltages are steady during the dip, I would suspect something like that.
Maarten is offline
Old 23rd Feb 2022, 4:28 pm   #19
slidertogrid
slidertogrid's Avatar
Are there any IC holders on any of the plug in modules? I remember a similar fault caused by a holder on an earlier chassis causing problems. We used to remove them and solder the chip directly into the board. Just a thought....
The rotation of the earth really makes my day...
slidertogrid is offline
Old 23rd Feb 2022, 8:31 pm   #20
slidertogrid
Originally Posted by slidertogrid View Post
Are there any IC holders on any of the plug in modules? Just a thought....
Sorry scrub that... Brain in neutral ! wouldn't cause sound problems...
