Reply
Old 7th Apr 2021, 9:00 pm   #2321
Default Re: The Audiophoolery Thread.
I am proud to be an engineer, and am sticking with calculated designs and measured results.
Old 8th Apr 2021, 1:10 pm   #2322
Beobloke
As am I.
However I'm also proud to be an audiophile who appreciates superb sound and realises that, unfortunately, you have to spend decent money to get this and that not everything expensive is simply bling boutique tat designed by cynical opportunists to empty your wallet and do little else.
Beobloke is offline   Reply With Quote
Old 12th Apr 2021, 10:52 pm   #2323
Buzby123
Buzby123's Avatar
BBC Archive 1959
https://fb.watch/4QufdKuV2Y/
Buzby123 is offline   Reply With Quote
Old 12th Apr 2021, 11:23 pm   #2324
joebog1
Love that!!!! It especially sounds good with 17 1/2 plums in the announcer's mouth.
Joe
joebog1 is offline   Reply With Quote
Old 13th Apr 2021, 12:22 am   #2325
Craig Sawyers
Craig Sawyers's Avatar
Well nowt has changed that much in over 60 years, that is perfectly clear
Craig Sawyers is offline   Reply With Quote
Old 13th Apr 2021, 12:37 am   #2326
Radio Wrangler
Radio Wrangler's Avatar
True. But it leaves the problem that many people can read a price tag, but far fewer can assess a design.
It is also far easier to put a high price on a piece of low performance gear than it is to put high performance in a piece of low price gear.
Who said the universe had to be fair? Or symmetrical?
Radio Wrangler is online now   Reply With Quote
Old 13th Apr 2021, 9:08 am   #2327
Valvepower
Valvepower's Avatar
Hello,
I have done exactly that.
Recently we designed an amplifier with both a good technical and sonic performance with an entry level price tag (that’s the sales name for it) which had to be entirely made in the UK.
We did it, but it wasn't that easy – can’t say it did our nerves any good though.
Sadly, we didn’t have the budget for a symmetrical design
Ps. And there was EMC compliance to do as well... augh
Regards
Terry
Valvepower is offline   Reply With Quote
Old 29th Apr 2021, 6:16 am   #2328
Keith956
Keith956's Avatar
Every hifi needs a gold plated plug with... a gold plated fuse!
https://www.mcru.co.uk/product/mk-to...s-available-3/
Keith956 is offline   Reply With Quote
Old 29th Apr 2021, 7:16 am   #2329
Craig Sawyers
3.5 times the price of a standard MK toughplug. Given that they have to be disassembled, sent for gold plating, reassembled, and a profit made, I'd argue that the price of £24 is not price gouging. Whether or not it makes any difference to the sound quality is another thing.
There are far more ridiculous mains components out there https://www.futureshop.co.uk/brands-...uk-mains-plugs
And £155 for a mains fuse https://www.futureshop.co.uk/synergi...slow-blow-fuse . The US manufacturers of that fuse are the crew that say they have been treated with 1,000,000 volts, which we've correctly ridiculed earlier in this thread.
Craig
Old 29th Apr 2021, 7:49 am   #2330
Radio Wrangler
Presumably the cryogenics crowd also get in on the act for perhaps a further 50% mark-up?
But which should be done first? the 1,000,000 volt treatment or the 77 Kelvin one? Would liquid helium treatment sound even better?
Skilled listeners with the goldenest of ears need to find out and tell us.
Old 29th Apr 2021, 9:25 am   #2331
Craig Sawyers
Oddly enough we used 77K treatment as part of the machining process at Oxford Instruments. Rough machine the magnet former, lower it by crane into a huge bucket dewar filled with LN2. When fully cold hoik it out and leave it to warm. Then final machine.
Without the cryogenic annealing process, the final machining had enough inbuilt stress to be out of true when at LHe temperature and the superconducting magnet would fail to reach field.
So does 77K treatment change the structure of a mechanical part? Yes it does.
Craig
Old 29th Apr 2021, 9:34 am   #2332
Craig Sawyers
And we used to use Allen Bradley 100 ohm carbon composition resistors. Turns out that they had very predictable temperature coefficient of resistance at low temperature.
So we had a variable temperature insert where we could take the temperature of the business end from 77K and upwards, with the control made with reference to a traceable standard. At the bottom were a whole load of the AB resistors.
There was a major panic when AB discontinued their carbon composition manufacture. We cornered around 10,000 of them to make sure we could continue to supply calibrated sensors into the future.
Nothing to do with use of this type of resistor in audio, which is apparently sought after by the valved crew.
Craig
Old 23rd May 2021, 2:27 pm   #2333
Craig Sawyers
Here we go. The Quantum Burning Technology device for burning in audio cables to improve their performance.
https://telos-audio.com.tw/qbt-cable-run-in-machine/
The price to you, gullible sir, is 20,000 smackers.
And that is just one of the daft things he sells for big money. Have a look around his website. Quantum this, quantum that. Does no one tell these people that quantum phenomena have an inherent uncertainty?
Craig
Old 23rd May 2021, 2:32 pm   #2334
Craig Sawyers
Yes - Quantum Damping https://telos-audio.com.tw/quantum-damping/
"The quantum spacer is a film made of 11 different chemical materials mixed with silicone.
The main components are graphene, rare earth and various materials that produce far infrared rays."
Well, it will only do that if it is not in thermal equilibrium with the environment. And if not in thermal equilibrium heat will either flow into this nonsense or be radiated by it according to the laws of thermodynamics.
Old 23rd May 2021, 3:02 pm   #2335
I note the use of mF for micro Farad.
Old 23rd May 2021, 3:22 pm   #2336
knobtwiddler
In my experience, TosLink softens the bass, adds treble hardness, and congeals the soundstage.
Taken from: https://wathifi.com/
There are plenty of other quotes on that site. Recommended reading for any 'phool.
knobtwiddler is offline   Reply With Quote
Old 23rd May 2021, 3:24 pm   #2337
Herald1360
Herald1360's Avatar
Clearly those microfarads are 1000x better than the ordinary everyday ones
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline   Reply With Quote
Old 23rd May 2021, 4:57 pm   #2338
Well it is Tos*** anyway.
Old 23rd May 2021, 6:37 pm   #2339
Radio Wrangler
One of the broken symmetries of the universe is that it is easier to sell a human a stupid idea than it is to convince him that it is stupid.
Old 26th May 2021, 11:14 am   #2340
knobtwiddler
“It's Easier to Fool People Than It Is to Convince Them That They Have Been Fooled.” – Mark Twain
Reply
