Old 5th Apr 2021, 4:51 pm   #21
slidertogrid
slidertogrid's Avatar
Default Re: Charlton TV Tubes
That is interesting. Is the phosphor thin in places ? Or is it that small dot size areas are dull? They probably didn't rescreen the tube when they re-gunned it... I was told many re-builders didn't as they thought the phosphor was good for at least one more go! Can the missing dots be seen on the screen when the set is off or just when it has a picture on it?
I often saw the odd 'dot' missing on re-gun colour tubes . Often it was a speck of grot clogging the hole in the shadowmask and if the set was tilted backwards and the screen clobbered with a rubber mallet they would clear. ( our service manager always went for the cheapo re-guns and wouldn't hear that it was false economy ...) The tubes often flashed over taking out sound output transistors or frame...
I hadn't heard of it on a mono CRT well not until today! Probably because we didn't buy mono re-guns we got the Unitra ones with the "gravely" phosphor!
slidertogrid is offline
Old 5th Apr 2021, 5:27 pm   #22
murphyv310
murphyv310's Avatar
Hi.
Nothing is visible when the set is on, looks totally clear. In fact they are virtually impossible to see with the Pye smoked implosion screen in place.
Trevor.
murphyv310 is offline
Old 6th Apr 2021, 12:05 am   #23
sexton_mallard
sexton_mallard's Avatar
Location: Ellesmere, Shropshire, UK & Co. Cork, Ireland.
I think I see what you mean...dark freckle effects on the faceplate of the CRT in the photo.
Dom
Less snakes...more ladders!
sexton_mallard is offline
