14th Jun 2021, 3:56 pm | #21 |
Re: TELETON VX1110 12" Hybrid.
Yes your right Hamid. To be honest the warm up isn't bad compared with say an AC/DC radio especially if it has a URIC rectifier! It just feels it's taking it's time but I suspect, as you say, the sound is instant!
The 20" models gave a very good picture, nice and bright with good colour. There are two hue controls. One on the back is a preset you adjusted for minimum blinds on a yellow portion of the picture. The front user control once set did not require further adjustment. Skin tones are excellent and I must say I have seen very poor blinds on PAL D receivers especially if the decoder featured one of those blue delay lines. I think they were DL50's. They must have sold very well. The odd valves I obtained from Teleton direct or from Toshiba. I had an early Toshiba account [1972] and they would order them. Looking at the heater current I suspect that a Cossor/Emitron 185BT [18V .45a heater] would work ok as a replacement for the line output valve but some adjustment would be required to accommodate the difference in heater voltage. These things can always be overcome when your having fun with these obsolete receivers. A scan of the cover of the 20" service manual is attached. John Last edited by Heatercathodeshort; 14th Jun 2021 at 4:06 pm. Reason: Added picture |
15th Jun 2021, 8:33 am | #22 |
A couple of test card F shots from the VX1110 taken this morning. Odd camera effects aside, the PAL S decoder certainly produces a good picture. John.
15th Jun 2021, 9:56 am | #23 |
HKS wrote: "Odd camera effects aside, the PAL S decoder certainly produces a good picture. John."
Open to discussion, the fact is as long as there is no phase errors between the signal source and the receiver the vertical definition of the colour picture with a simple PAL decoder should be better than a PAL D decoder. However, when phase errors do exist the on-screen results will be a coarse "Hanover bars" effect which is made worse by interlaced scanning. From Wikipedia: https://en.wikipedia.org/wiki/Hanover_bars DFWB. |
