2nd Jun 2021, 8:42 pm | #1 |
KB WV20 Warwick - Built to last!
I collected this television last weekend from another Steve (Regentone001) down Coventry way. Nice to meet you Steve!
This set had a sorry tale to tell, having been accidentally knocked to the ground from a dining room table after Steve's Jack Russell was spooked by a firework. The blow split one end of the cabinet open and the chassis received a hefty whack, causing some distortion, but miraculously the crt escaped being necked although the plastic 'bowler hat' was damaged (luckily I have a spare). A couple of the wooden blocks on which the tuners and use controls are mounted broke free and need re-gluing. I'll probably strip everything out in order to do it properly. Despite it's accident, the KB still works very nicely, with Steve's previous restoration work holding out well. Prior to his custody I suspect it may have been a one owner set, the pre-accident condition being so good. It's fitted with a twin-panel Brimar 'Plus' A47-13W which looks to be the original and produces a really bright, well contrasted picture. I have a soft spot for these 1960s STC group sets- KB, Regentone and RGD. They produce great results and the chassis is very well engineered (and tough!) I'm not aware they have any particular weak points. The cabinets and presentation are always very attractive too. One casualty of the accident was the shatterered VHF tuner knob (main and fine tuner). I think it would have been the classic KB 'lightning flash' type. If anyone has one knocking around in a spares box I'd be very grateful! Steve |
3rd Jun 2021, 6:23 am | #2 |
Re: KB WV20 Warwick - Built to last!
They are beautiful sets. The original Brimar twin panel in my VC1 is great too. They were made about 3 miles from where I live and many retired people round here remember working for them. A friend has just given me a dismembered VC2 chassis. I will ask him if he has a tuner knob
3rd Jun 2021, 7:22 pm | #3 |
3rd Jun 2021, 7:23 pm | #4 |
great sets these we did loads of ace vv15 with the vc1 chassis at telebank . there was a mod to increase range of frame hold change a 1.8k resistor to a 6.8k . the later vc51 chassis[regentone mv818/918] used a 10k in the same position .can,t remember cct ref but was a grid resistor it was many moons ago
brian |
3rd Jun 2021, 7:45 pm | #5 |
Lovely set.
I've never actually worked on a KB/RGD/Regentone model of that era with a "thermometer" type UHF tuner channel indicator. These must have been a more expensive model than the usual VC1/2/3 sets with a rotary UHF tuner knob (with a concentric channel indicator disc), located on the RHS with the other customer controls. I see the UHF tuner is a Philips type - a new one for me on a VC1/2/3 chassis set. |
3rd Jun 2021, 9:52 pm | #6 | |
The Warwick is certainly in the de-luxe class with it's no-expense-spared use of twin speakers...! Steve |
3rd Jun 2021, 10:05 pm | #7 |
Great sets, one my bucket list to get.
Greg.
Picture, sound?, DOOR. |
3rd Jun 2021, 10:08 pm | #8 | |
4th Jun 2021, 12:31 pm | #9 |
Hi Steve
it was great to meet you and I am glad to see the set working. I still haven't come across the original coil but when I do I will send it to you Steve |
5th Jun 2021, 7:57 pm | #10 |
Hi Steve,
If your set has the VC1 chassis has the frame sync modification been done? Well worth doing if the frame hold is critical. The triode section of the PCL84 is rewired to serve as the frame sync amplifier and clipper. All subsequent chassis have the modification. VC1 has the ECC81 line oscillator, it works OK but all later chassis employ the PCF802. Triode section operates as a reactance valve the pentode as a sinewave oscillator. DFWB. |
7th Jun 2021, 9:32 am | #11 |
Hello Steve. Peter Sanders has come up with the attached KB knob. Any good for you?
7th Jun 2021, 10:28 am | #12 |
Back in the 70s, when I was a lad, I remember ITT-KB tellies with that chassis sporting a 'Hand Wired' logo. I think this implied that they were more reliable than PCBs. Or that the customers trusted them more? Cheers, Pete.
7th Jun 2021, 10:32 am | #13 |
Like this, which was first used around 1966-67:
7th Jun 2021, 2:21 pm | #14 | |
To convert the triode section of the PCL84 from functioning as a 405 vision interference limiter, to a frame sync pulse amplifier (as used in VC2 and all subsequent dual standard chassis): Using the triode section of the PCL84 in place of the OA81 diode. Components required: 680kΩ ½W 10% resistor 68kΩ ½W 10% resistor 2.2kpF 10% capacitor Procedure: 1. Remove C66, R61 and OA81 diode 2. Replace R74 10kΩ resistor by 68kΩ 3. Replace R76 1.8kΩ resistor by 10kΩ 4. Connect cathode of PCL84 triode to junction of R71 and R72 and leave grid of valve connected to chassis. 5. Connect triode anode of PCL84 to junction of R74 and C72 6. Fit 680kΩ resistor from HT line to triode anode of PCL84 7. Fit 2.2kpF capacitor in parallel with R74 For the circuit of this change, refer to the VC2 chassis circuit diagram, V7 triode section. |
7th Jun 2021, 9:27 pm | #15 |
11th Jun 2021, 6:00 pm | #16 |
I jusrt wanted to extend my very grateful thanks to Steve N for sourcing a VHF tuner knob for the KB. I didn't see the original but this one looks a perfect match. The set will need stripping out for some internal cabinet repair work, but looks a lot happier already!
Steve |
12th Jun 2021, 10:30 am | #17 |
Looks lovely!
12th Jun 2021, 11:26 am | #18 |
What a beauty Steve , they always looked modern to me with their slim cabinets.
Regards Gary. |
12th Jun 2021, 12:26 pm | #19 |
Hi Gary,
Yes, one of my 60s favourites too! Steve |
14th Jun 2021, 9:34 am | #20 |
Lovely looking set. That VHF tuner knob looks spot on too.
All the very best, Tas |
