Old 14th Sep 2020, 4:24 pm   #1
Sinewave
Sinewave's Avatar
Default Bush AC41
A little while ago I picked up an AC41. Rather than just switch it on, I made a few checks inside, then brought it up slowly on the variac. Being aware of the live chassis possibility, I did some searching and from what I've found, I believe that this isn't a live chassis set? However, I didn't reach full voltage when bringing the set up on the variac as I stopped when I were measuring 50v on the chassis.
There were some glowing valves, so some signs of life!
Avometer, vintage Fluke and Marconi collector. Also interested in vintage Yaesu and KW.
Sinewave is offline
Old 14th Sep 2020, 4:29 pm   #2
Freya
Freya's Avatar
Default Re: Bush AC41
Where did you have your probes ?
It's not live chassis as it has a mains transformer
Stephen
Freya is offline
Old 14th Sep 2020, 4:32 pm   #3
HamishBoxer
HamishBoxer's Avatar
Not a live chassis.
HamishBoxer is online now
Old 14th Sep 2020, 4:35 pm   #4
Sinewave
Sinewave's Avatar
I went from the chassis to the earthed casing of my variac, then that's when I realised something may not be quite as it should, so it's on the bench in Sinewave Laboratories...
If fact the drawing extract you've posted looks a little different to the one I have here.
Sinewave is offline
Old 14th Sep 2020, 4:41 pm   #5
Freya
Freya's Avatar
The dotted line on the schematic showing the transformer core to Chassis may have something to do with it, if a winding is breaking down to the laminations.
Stephen
Freya is offline
Old 14th Sep 2020, 4:43 pm   #6
music-centre
Definitely not a Dac41 with an Ac41 back transferred to it? over the years like they do!
Steve.
music-centre is offline
Old 14th Sep 2020, 4:45 pm   #7
Sinewave
Sinewave's Avatar
Will test the winding to chassis in a moment.
Sinewave is offline
Old 14th Sep 2020, 5:04 pm   #8
Sinewave
Sinewave's Avatar
Steve.
Here's the front
Sinewave is offline
Old 14th Sep 2020, 5:12 pm   #9
music-centre
It would look the same from the front but in the case of this model if you have a mains transformer it would be an AC41 as the DAC 41 uses a dropper type strip.
Steve.
Old 14th Sep 2020, 7:43 pm   #10
John10b
What valves are fitted?
John
John10b is offline
Old 14th Sep 2020, 8:10 pm   #11
Herald1360
Herald1360's Avatar
If the AC 41 chassis isn't earthed, a DVM or other high resistance meter could show a significant reading simply from the stray capacitance in the transformer between its mains winding and core/screen.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 14th Sep 2020, 8:13 pm   #12
Sinewave
Sinewave's Avatar
All Mullards
  • ECH42
  • EBF80
  • EL41
  • EZ40
Sinewave is offline
Old 14th Sep 2020, 8:33 pm   #13
Sinewave
Sinewave's Avatar
Ok, tested the mains TX, the windings are fine, nothing down to chassis.
Sinewave is offline
Old 14th Sep 2020, 8:41 pm   #14
Sideband
Sideband's Avatar
Yes indeed. A DVM can measure sometimes over 100V but this is a capacitive coupling as noted above. It isn't actually 'live'.
Sideband is offline
Old 14th Sep 2020, 8:53 pm   #15
Sinewave
Sinewave's Avatar
I did wonder if it was induced voltage with not enough current behind it.
I'll touch it and see how many buzzes I get
I've got some three core cable I can replace the twin with.
Sinewave is offline
Old 15th Sep 2020, 2:15 am   #16
Herald1360
Herald1360's Avatar
That dotted line is actually the usual symbol for an electrostatic screen and as such definitely has something to do with it breakdown or not!
....__________
Old 15th Sep 2020, 9:47 am   #17
John10b
This is part of the AC41 circuit I’ve got, slightly different to the other one shown.
John
John10b is offline
Old 15th Sep 2020, 10:36 am   #18
HamishBoxer
Bit of capacity coupling?
Old 15th Sep 2020, 11:35 am   #19
Herald1360
Herald1360's Avatar
John
Looks like exactly the same circuit just drawn differently with a chassis symbol on the 0V end of the HT secondary.
....__________
Old 15th Sep 2020, 12:21 pm   #20
AC/HL
AC/HL's Avatar
Post 2 is the Trader iteration, post 17 the Bush original. Same set, although the Trader drawing style looks much older.
AC/HL is offline
