7th Sep 2020, 10:57 pm | #1 |
Location: London, UK. Bury, Lancashire quite regularly :)
Hacker Mayflower II.
Evenin' all
Would anyone care to hazard a guess as to why C25 (2uF polarised electrolytic) is rated in the manual at 150v? (Apart from the possibility that it was all they had in the parts bin.) I can't see any reason why it would need to be in that position in the ratio detector. The manual describes it thus: "C25 is to provide a steady DC potential across the diode loads R21,R22." It needs replacing - as do an awful lot of other parts - but that's another story. TIA. CCT extract attached.
Thermionic Emission, warms the cockles of your tubes. |
7th Sep 2020, 11:39 pm | #2 |
Re: Hacker Mayflower II.
As a tyro, I'd say because it's between an anode and a cathode, so surely one end is close to HT?
8th Sep 2020, 6:02 am | #3 |
On a strong FM signal you can easily have 40 to 50 volts across that capacitor maybe more. On a Ferranti T1032 on a simple wire dipole behind the set I have as about 35volts. The circuit in that set is slightly different but it does the same task.
The 150volt rating would be one of the preferred values at the time, The steady voltage it provides is an aid to AM suppression in the ratio detector.
Frank |
9th Sep 2020, 9:30 am | #4 |
Thanks for the explanation.
Apropos of nothing in particular, I wonder where Hacker sourced their resistors from? Literally every single one of them is outside tolerance, some WAY outside. I'm having to replace them all. I've had dog bones in 1930's Murphys keep their marked value better.
9th Sep 2020, 9:38 am | #5 | |
9th Sep 2020, 9:42 am | #6 |
The first one of these I restored needed loads of resistors replacing, as many were >50% high.
Obviously, in some bits of the circuitry, it's more important than in others. There's a thread with a good contribution by Hacker expert Mark Hennesey about this. It refers to the Serenade radiogram, but it's very similar to a Mayflower: https://www.vintage-radio.net/forum/...d.php?t=125398 Nick |
9th Sep 2020, 12:27 pm | #7 | |
Thanks for the thread link btw, interesting reading. N.B. For any who might be interested or care, the Hacker group and it's associated files are now at https://groups.io/g/Hackerradiogroup and not Yahoo.
Thermionic Emission, warms the cockles of your tubes. Last edited by Nanozeugma; 9th Sep 2020 at 12:30 pm. Reason: Addendum. |
10th Sep 2020, 12:39 pm | #8 |
Mayflower II another enquiry (sorry.)
V6, one of the pair of ECL86 triode / pentodes has a grounded thin sheet copper shield erected between the pins of the valveholder (image attached.)
Initially, I thought this might have been retrofitted by a repair technician at some point in the past to correct a problem. A bit of Googling has thrown up an image of another unit however, and you can clearly see the same shield (image attached.) One must therefore conclude it was fitted during manufacture. The only reason(s) I can think of that would make this necessary would be to cure instability or hum (?) I would welcome others perspective on this. T.I.A.
10th Sep 2020, 4:06 pm | #9 |
Owners of HM2s may be interested in this thread where I fitted an external 'module' that greatly improves the frequency response of the set given its single speaker (contemporaries had up to three or even four) and single treble tone control.
https://www.vintage-radio.net/forum/...d.php?t=110877
10th Sep 2020, 10:19 pm | #10 | |
Re: Mayflower II another enquiry (sorry.)
A “belt and suspenders” artifice in the aid of stability seems to be at least a possibility. The amplifier is of “compact” (or “economical”) design, with V6a (triode) directly driving V6b (output), and receiving the main feedback loop at its cathode. V7a (triode) inverts the signal from V6a to drive V7b (output). So there is a lot going on under the base of V6, such that any stray coupling is probably undesirable. And UL amplifiers apparently have more potential oscillation modes than non-UL types, although that is more connected with output transformer design. V7 would appear to be less critical in that there is no feedback connection to it. As I understand it, and for comparison, in the Mullard 2 x ECL86 amplifier, each output section was driven by its own triode, and the main feedback loop went to the cathode of the preceding EF86 stage, so there would have been less concatenation of the signal and feedback loop wiring. Cheers, |
14th Sep 2020, 5:23 am | #11 |
That “compact” push-pull amplifier arrangement in fact appears to have been reasonably common in higher performance radio receivers, where I imagine that valve count was somewhat constrained as compared with audio equipment. But it typically involved four valve envelopes, for example as in the Pye PE80 and FenMan II, and Murphy A188C and TA160. If output stage instability was in fact a potential problem in the Hacker Mayflower, then having that kind of amplifier arranged around just two valve envelopes, with resultant closeness of wiring, may well have been a contributory factor.
Cheers, |
