7th Sep 2020, 12:14 pm | #1 |
PDF transfer from old computer.
Hello there,
I have been trying to transfer some files from an old windows 98 laptop to a windows 10 desktop, it has been quite difficult because laptop has a USB connection but won't recognise any of my USB drives,it only recognises my USB mouse. I'll try using a free dial-up internet provider but that hasn't worked either, there is also a floppy disc drive but I don't have any other computers with a floppy drive. I will attach pictures below of the laptop in question as well as information about it in Windows. Tom |
7th Sep 2020, 12:22 pm | #2 |
Re: PDF transfer from old computer.
USB mass storage support was only added in W98SE.
The easiest solution would be to buy an IDE to USB interface cable and use it to connect the laptop HD to a newer computer. You can buy such things for a few quid on eBay. |
7th Sep 2020, 12:32 pm | #3 |
if it has an ethernet port could you use a crossover cable, or add it to a home network if your router has more than one port?
Kevin |
7th Sep 2020, 12:42 pm | #4 |
Email them to yourself?
7th Sep 2020, 12:53 pm | #5 |
Just to answer a few questions for you:
No the computer does not have an ethernet port. I am unable to remove the hard drive from the computer. Would I be able to move the files using a USB to 9-pin serial cable? Tom (below I have provided a photo of the ports on the back of the computer but can also provide the side ones if needed, I have also tried burning them to a DVD and that hasn't worked either) |
7th Sep 2020, 1:05 pm | #6 | |
HyperTerminal is also available for Windows 10, as are many other serial communication programs (my favourite is TeraTerm) which should be able to receive the file and save it. Chris
7th Sep 2020, 1:41 pm | #7 |
I still use an old Win98SE laptop to control my PCB milling machine. I found that the USB port 'does' support USB memory sticks but only the older ones with fairly limited memory size.
I think the biggest memstick I use with it is 512Mb. I also use a 256Mb and a 64Mb and a 16Mb with it. I may have had to install a driver for the 512Mb memstick but I can't remember now. I use the USB memstik to transfer PCB design files to and from the old Win98SE laptop.
Regards, Jeremy G0HZU |
7th Sep 2020, 1:42 pm | #8 |
If the worst comes to the worst, put the files on one or more floppies and post them to me. I don't have a computer with an FD in everyday use, but I should be able to lash something up.
As I said earlier, limited USB mass storage support arrived with W98SE. If the laptop has the earlier W98 it won't be able to use pendrives of any size. |
7th Sep 2020, 1:48 pm | #9 |
You could install the Win98 USB storage driver and transfer your files via a USB stick. I used this driver with a '98 Toshiba and it worked well.
I copied the .exe onto a floppy disk and ran in from there. |
7th Sep 2020, 1:55 pm | #10 |
7th Sep 2020, 2:01 pm | #11 | |
7th Sep 2020, 2:07 pm | #12 |
You're right Jeremy, I didn't look closely. In that case it should be OK with pendrives of 2GB or smaller.
7th Sep 2020, 2:16 pm | #13 |
Hello,
I've just gone on to eBay and ordered one of these: https://www.ebay.co.uk/itm/163959544565 (apologies if I'm not allowed to post links) as soon as it arrives I will start transferring the files, should be here by Wednesday/ Thursday. |
7th Sep 2020, 2:29 pm | #14 |
It might be easier if you just bought a small memory stick, like one of these: https://www.ebay.co.uk/itm/64MB-USB-...e/254599349951
The cable that you have ordered is just a physical interface. You still need to sort out the software required to transfer files. This isn't particularly difficult, but it sounds as if you don't have a lot of expertise in this area. |
7th Sep 2020, 3:04 pm | #15 |
I've just done this very thing, recovering nostalgic data from a very old laptop. I zipped up everything I needed so there was just one file to transfer, then I used Zmodem in Terraterm to send the zip over a serial cable to a 'modern' laptop. Took a while, even at 115200, but worked great. It subsequently cost me a week of my life reminiscing over old projects
7th Sep 2020, 3:23 pm | #16 |
You could try using Kermit with your serial cable http://www.kermitproject.org/index.html
I have many happy memories of deploying software from a VAX to VAX back in the day by using kermit over modems... Its still available, still free and appears to work on Windows 95+ |
7th Sep 2020, 3:27 pm | #17 |
A few months ago I installed Win98SE on a previously WinXP laptop just for programming GAL chips. My notes from the install said that I needed to install the files nusb33.exe and nusb36.exe in order to get USB pen drive support. It recognises 2GB pen drives and possibly 4GB, I am not absolutely sure on the latter. I found both the files just by Googling for the file names.
Regards, Roger |
7th Sep 2020, 3:30 pm | #18 |
It's easy to forget that Data is Data. What we usually see are interface standards, but they all do the same thing in reality, you just have to get them talking.
7th Sep 2020, 4:15 pm | #19 |
Do you have a digital camera? Before USB memory sticks became available at a reasonable price I used to transfer files between work and my Win 98 2nd edition PC using the camera, which looks just like another drive to the computers. The camera came with a CD containing the necessary drivers for Win 98. I now have a couple of 1GBit CF memory cards for my digital camera, and use them for transferring files.
I had to install memory-specific drivers to get USB memory sticks to work with Win 98. Is the driver at #9 a generic one that should work with most USB memory sticks? The two different ones I installed, do not work with my other other sub-GBit drives. |
7th Sep 2020, 6:08 pm | #20 |
Another option. Write the data to a floppy, and use a USB floppy drive on your newer machine. I can't see why any version of newer windows wouldn't recognise a USB floppy drive.
