Old 30th Aug 2020, 12:43 pm   #1
acollins22
Default Need a clue on a Z80 wait-state generator.
Hi Folks,
I'm going back to one of my old Z80 machines and tinkering with a cf card reader. I would like to introduce a wait-state or two when reading it as I suspect timing is at the bottom of a problem I am having.
In fact, a wait state on any I/O read would be fine.
I have looked around the web for clues but I haven't found what I'm after and don't quite know enough to spin my own.
Does anyone out there know of a suitable snippet of a schematic they could point me at please?
Thanks,
Andy.
acollins22 is offline
Old 30th Aug 2020, 4:03 pm   #2
Default Re: Need a clue on a Z80 wait-state generator.
I am rather surprised that a Z80 needs wait states for a CF card, those cards are quite fast. If needed why not reduce the clock frequency?
Old 30th Aug 2020, 6:20 pm   #3
Mark1960
You could try the example for adding wait states to M1 cycles from the mostek z80 technical manual. Page 69. But use /Iorq instead of /M1.
http://nascomhomepage.com/pdf/z80-mostek.pdf
The above will stop working correctly as the clock frequency is increased due to setup time on /WAIT input, but should be ok up to 10-14MHz.
Its unlikely to be a solution to the problem with the compact flash.
I would suggest taking a look at the retro-comp google group, recent thread on CP/M unstable on SC114, but many other threads with a similar solution posted by Bill Shen and verified by many others.
https://groups.google.com/g/retro-comp/c/p02uSv8olyU
RC2014-Z80 might also be worth looking at for z80 info.
Mark
Mark1960 is online now
Old 30th Aug 2020, 9:46 pm   #4
acollins22
Thank you Mark,
I didn't think to RTFM! I'll try that.
You may well be right about the wait states and CF cards but someone who knows this stuff better than me suggested I give it a try, so I will*.
Cheers,
Andy.
*This doesn't apply to everything people tell me to do. I wouldn't have reached this ripe age if I'd done that!
Old 5th Sep 2020, 4:21 pm   #5
Slothie
Look at Grant Searle's CP/M on a breadboard computer, he uses a Compact Flash card as disk drive.
http://www.searle.wales/
Slothie is offline
