Old 21st May 2020, 1:01 pm   #181
philoupat83
Default Re: Recreating the Bywood Scrumpi
Thank you for this comment but it is good to know to be supported and helped by people as passionate as us. remains to define the pine of the two latch I compare the holes and my diagram there is discordance and I hesitate on some choice made on the original?
it remains to this memory of the creator of this computer a visionary dead too young
young student I dreamed in front of this jewelry appeared in advertising but my means did not allow access
Name:	scrumpi latch.jpg
ID:	206379   Click image for larger version
Name:	scrumpi latch1.png
philoupat83 is offline
Old 21st May 2020, 1:03 pm   #182
philoupat83
it remains to this memory of the creator of this computer a visionary dead too young.
Old 22nd May 2020, 12:49 am   #183
Timbucus
Indeed just knowing others are reading and checking the work is enough... I will be adding some cajoling in the book to come and join us and perhaps help with the 2 and 3 project...
Phil I will take another look at the IO stuff tomorrow after work as I have sketched out a layout myself but, still not worked out how they are actually supposed to work.
Not sure what you mean on the R3 and R4 being reversed?
They are definitely 74C04 as not 07 as I previously thought because the low driver sinks the current it lights the LED when it is at Logic 0 which needs an inverter so the LED lights when the bus is at one - I had forgotten about this inversion that would happen.
On the board itself my RAM is still "in transit" in China so I threw caution to the wind and ordered two from Little Diode due in about a week.
...then last night as I was lying awake I thought I wonder what happens if I unplug the flying lead from the OE to NRDS on my 9111 - guess what - the chip releases the bus and I can program anything I like... I am now wondering if the 2112 will have a similar issue and maybe the LOAD switch does more than it seems somehow - anyway as soon as the other 2112 chips arrive I can find out and we have one of the last pieces of the puzzle sorted.
Timbucus is offline
Old 22nd May 2020, 9:03 am   #184
Slothie
The 2112 doesn't have an OE pin so you should be safe! It's a simple chip
Slothie is offline
Old 22nd May 2020, 10:47 am   #185
SiriusHardware
It still irritates me that the pin on the 2111 is actually called 'OD' (Output Disable) when it is used like an active low _OE pin, potentially confusing. Or maybe that's only on the data sheet for one particular manufacturer's version?
SiriusHardware is online now
Old 22nd May 2020, 12:35 pm   #186
philoupat83
Hello
tim it is not to cajole but to be objective and to put forward Mr John Miller-Kirkpatrick we are only forgers
For R3 R4 R5 it is important that your list is identical to the pcb that must be identical to the original (main subject) for the latch I have my idea but more solution exists I would take yours.
must have signed the pcb? (TIM/PHIL April 2020)
for SLOTHIE the specialist kicad of questions
I transferred the pcb to kicad to modify the text (eagle is not flexible)
can make name and value disappear so that only the text is retained in the gerber
for mm2112/11 I have posted the data
OD is a nonexistent disable output on mm2112
for power I found in my pull a 7907.
question or found you the mm2112 I received my AM9112 to replace them
thanks to tim for it’s mock-up so of the 7404
Old 22nd May 2020, 12:51 pm   #187
philoupat83
for choice and layout?
ID:	206451   Click image for larger version
Old 22nd May 2020, 12:54 pm   #188
Slothie
Working from memory if you edit any label (using the edit option) there is an option to hide it. Alternatively you can create a new footprint in a custom library with the features you want, then in Pcbnew you can use "change footprint" to change to the new footprint. This is useful too if you wish to have custom lengths for resistors etc.
Slothie is offline
Old 22nd May 2020, 1:06 pm   #189
philoupat83
thank you other question if I make name value invisible on which layer I should put the text how to create the gerber (I’m too used to eagle!)
Old 22nd May 2020, 1:17 pm   #190
philoupat83
Other thing they didn’t escape you that I use a translator who at times does ....... I apologize.
reading English and for me easier than writing it harder
Old 22nd May 2020, 1:19 pm   #191
philoupat83
the plan!!!
Old 22nd May 2020, 2:10 pm   #192
Slothie
There is a layer called 'Comments' which for the purpose gerber generation is ignored, edge lines go on a layer called 'Edge.Cuts' Which I think is where Kicad gets the dimensions from when plotting the Gerbers. How it copes with non rectangular boards I have no idea!
Don't apologise about your English, my French would be worse and I can usually work out what you mean, I hope you can do the same with me!
Slothie is offline
Old 22nd May 2020, 2:46 pm   #193
philoupat83
thanks
Old 22nd May 2020, 9:56 pm   #194
philoupat83
the pcb
ID:	206482   Click image for larger version
Old 22nd May 2020, 10:20 pm   #195
Timbucus
Cest magnifique
Timbucus is offline
Old 22nd May 2020, 10:21 pm   #196
Timbucus
I notice the label for R4 is in the wrong place but, otherwise it looks perfect.
Timbucus is offline
Old 22nd May 2020, 10:25 pm   #197
philoupat83
precise or and r4
wants me to sign.
TIM/PHIL
April 2020 on tracks
Old 22nd May 2020, 10:25 pm   #198
philoupat83
bottom
Old 22nd May 2020, 10:29 pm   #199
philoupat83
for latch I put all the holes except connection 1-2 8-9 no connection between the two latch
Old 22nd May 2020, 10:31 pm   #200
philoupat83
check the circuit before I do it by jlpcb (one for you )
