Old 14th Jan 2023, 12:44 pm   #1
Michael Maurice
Michael Maurice's Avatar
Default Dynatron HFC38 cassette section
I am restoring this music centre which is fitted with the SRX26 chassis and a modified Philips N2505 cassette recorder.
Someone has cut the Din plug cable that goes from the cassette deck to the main chassis.
There is a separate PCB which is not a Philips one that sits in the corner, There are no diagrams for this.
Does anyone know where it connects to, or better still does anyone have one that they could photograph for me.
Forum Moderator
Michael Maurice is online now
Old 14th Jan 2023, 4:39 pm   #2
DMcMahon
DMcMahon's Avatar
Default Re: Dynatron HFC38 cassette section
Are there no clues in the SRX26 Service Manual ?
DMcMahon is offline
Old 15th Jan 2023, 12:17 am   #3
Michael Maurice
Unfortunately not
Forum Moderator
Old 15th Jan 2023, 11:05 am   #4
vinrads
Hi Michael are you saying that it was hard wired originally, I would have thought there would have been some remnant of the cable if it was cut. Mick.
vinrads is offline
Old 15th Jan 2023, 3:47 pm   #5
Edward Huggins
Might this be some kind of simple attentuator/pre-amp that matches the Philips record/replay electronics to the Dynatron's audio section input?
Edward.
Edward Huggins is offline
Old 16th Jan 2023, 3:30 pm   #6
Michael Maurice
The panel doesn't appear to have any active components but it does have a slide switch, I'll have to see what actuates it.
The original cable was a short 4 core screened cable, hard wired to the machine and terminating in a 5 pin din plug.
Forum Moderator
Old 23rd Jan 2023, 5:36 pm   #7
dazzlevision
Here are some phone camera shots of the relevant HFC38 service manual relating to the tape interface board and wiring.
ID:	272072   Click image for larger version
ID:	272073   Click image for larger version
dazzlevision is online now
Old 24th Jan 2023, 1:02 am   #8
Michael Maurice
Thank you Dazzlevision, but for some reason the board on mine has a switch operated in playback. I.m going to look into it a bit further.
Forum Moderator
